09-15-2011, 08:56 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: In my country Age: 56
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | R800a no detected with TP Help please I have a problem with R800a on the unlock procedure. At the first step the sw detected ok. But at the 2nd step with TP cant detected I make step by step the instructions but I cant ! I try with 1.1101, 1.1107 and with the last 1.1108 and nothing... Can anyone help me please ? Many thanks and regards |
09-15-2011, 09:13 | #3 (permalink) |
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Hi, thanks for your fast reply, I make the same TP that to post, but I cant connect the phone after make a TP After connecting tp and holding back button and connecting cable computer don't detect the phone but when i disconnect the phone i get error. Maybe is the driver problem, but I dont know what I do ! SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" BUTTON ... RUNNING S1_EROM VER "R9A021" SOFTWARE AID: 0001 LOADER AID: 0001 FLASH ID: "002C/00B3" LOADER VERSION: "R4A069" PHONE IMEI:35730304027897 Checking for signature ... signature found, skipping calculation DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCEDURE WAS STOPPED BY USER Unlock FAILED Elapsed: 175 secs. br |
09-15-2011, 09:18 | #4 (permalink) |
No Life Poster Join Date: Jul 2005 Location: player /-GSM-\ Field
Member: 161115 Status: Offline Sonork: Here you can find it... Thanks Meter: 3,039 | q: how to unlock s1 android based phones using alternative security bypass using testpoint? a: first, that is ONLY applicable to phones, based on msm8255 chipset - lt15,mt15,r800, some upcoming models. Here is procedure. 1. prepare for testpoint operation. check testpoint location for your phone model in dist\docs\ open testpoint for access get some needle with wire, connect it to phone gnd ( battery minus ) or to usb cable shield, etc. 2. select proper phone model. on settings check signed mode, use alternative security bypass, do full unlock instead usercode reset fill login/password and check if account valid. press unlock 1.when prompted, execute steps in EXACT order: 2.remove cable from phone, 3.remove battery from phone, 4.attach testpoint 5.press "ready" 6.insert cable to phone, HOLDING TESTPOINT 7.install drivers from dist\drivers\USBFlash_driver\ 8.when prompted detach testpoint 9.press "ready" |
09-15-2011, 09:21 | #5 (permalink) |
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Hi, I make all the instructions step by step. But dont detect. No ask me for install the drivers. For this I think that is this the problem. The same problem like this link: look plz http://forum.gsmhosting.com/vbb/f473...7/#post7717317 |
09-15-2011, 13:28 | #8 (permalink) |
No Life Poster Join Date: May 2007 Location: GSM WORLD
Member: 510122 Status: Offline Sonork: 100.1606547 Thanks Meter: 1,822 | Try to uninstall and install again driver.... I'm tested this type case many times .... Its driver problem not android problem |
The Following User Says Thank You to amar181 For This Useful Post: |
09-15-2011, 20:45 | #9 (permalink) |
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | As I imagined. Problem was the Zeus drivers. Probe on a virgin machine and it worked well. Sorry, and many thanks at all friends that help me. Best regards, |
09-24-2011, 00:15 | #10 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Portugal Age: 47
Member: 522693 Status: Offline Thanks Meter: 135 | DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" BUTTON ... RUNNING S1_LOADER VER "R4A062" LOADER AID: 0001 FLASH ID: "002C/00B3" LOADER VERSION: "R4A069" PHONE IMEI:3573020xxxxxxx Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1256] FINALIZING ... Unlock DONE Elapsed: 181 secs. unlock done xperia r800i (paly) |
12-31-2011, 11:37 | #11 (permalink) |
Freak Poster Join Date: Sep 2008 Location: peja KOSOVA Age: 46
Member: 856869 Status: Offline Sonork: +37744510000 Thanks Meter: 30 | sucssesfull unlock with out problem R800a RUNNING v 1.1202/01.11/UNI CARD SERIAL 00030524 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_LOADER VER "R4A069" LOADER AID: 0001 FLASH ID: "002C/00B3" LOADER VERSION: "r4A069" PHONE IMEI : 3573030******* Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1256] WRITING SEMCBOOT ... Unlock DONE Elapsed: 218 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 credits consumption for full signature unlock: S1 v1 05 credits ( OFFLINE ) S1 v2 10 credits ( OFFLINE ) S1 OPEN 05 credits ( AID 004 OFFLINE ) A1 phones 05 credits A2 phones 05 credits ( DO NOT USE FOR J108 ) S1 v2 alternative bypass 05 credits W100,W150 codes 05 credits current setool2 version: 1.1203 SERVER CREDITS LEFT/USED: 15/15 CARD COUNTERS: FLASH 1327, UNLOCK 1028 Elapsed: 3 secs. |
05-30-2012, 18:53 | #13 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_LOADER VER "R4A069" EROM_AID : 0001 LOADER_AID : 0001 HWCONF_AID : 0001 ACTIVE_LOADER_AID : 0001 DEVICE ID: 63C396B723F9EE8D09DAA071AE2B96506112B07D FLASH ID: "002C/00B3" LOADER VERSION: "r4A069" PHONE IMEI : 35730204561096 Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1256] WRITING SEMCBOOT ... Unlock DONE Elapsed: 294 secs. |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
