Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 02-07-2009, 16:11   #1 (permalink)
Member: 936896
Thanks Meter: 14
Help Unlocking SE w350i
Hi everyone
Im new to the unl;ocking world ... i have setool box and wanted to know how to unlock the se 350i, i mean is it there any turorial that does explain how to use setool and plus i heard that for some mobiles is required to have some files to unlock them ,, what do i require for se w350i and where can i get it?
Old 02-07-2009, 16:20   #2 (permalink)
Member: 370506
try looking at http://www.setool.net/video/index.php
there are guides for unlocking on SEtool.
Old 02-07-2009, 16:36   #3 (permalink)
Member: 936896
Thanks Meter: 14
Thank you mate , i didnt get it , in my case that i have to unlock a mobile which one of them do i have to use ?
the mobile to unlock is w800i
Old 02-08-2009, 00:57   #4 (permalink)
Member: 936896
Thanks Meter: 14
Help me guys , is it there any good tutorial to start using setools and a site where I can get all the files that are used to unlock,flash etc mobiles using setool 3
Thanks
Old 03-11-2009, 07:57   #5 (permalink)
zeeshan tayyab's Avatar
Member: 828294
Sonork: 100.1615866
Thanks Meter: 124
try to use setool's own support site,everything is there, mate.
Old 03-11-2009, 08:21   #6 (permalink)
Member: 41976
Thanks Meter: 33
hi!
if you are using setool for the first time then you should download rest file from support.
also download usb driver for w350 and for any other cyber shot fone u want to flash or unlock.
switch your fone on,then connect ur usb cable and install driver.
on setool,identify then see wat cid your fone is,if rest file is present or not and if bypass package is present or not.
if both rest file and bypass package present then in settings just choose signed mode,alternative bypass and security bypass then unlock.u must of course have test sim to insert it when it ask you too or use use original sim.
if rest file not present and bypass package present then have to make rest file,in settings just choose alternative bypass and preloader bypass.then click identify so it will make rest file then unlock.
if bypass package not present then have to full flash fone(main + fs).to flash choose signed mode and complete fone after flash in settings.then unlock.
good luck
The Following User Says Thank You to wearephones For This Useful Post:
Old 03-11-2009, 11:48   #7 (permalink)
Member: 936896
Thanks Meter: 14
Thank you mate you have been vfgery generous to post the whole instructions to be followed.
Thanks
Old 03-11-2009, 11:48   #8 (permalink)
Member: 936896
Thanks Meter: 14
Thanks
Old 03-11-2009, 13:15   #9 (permalink)
nishaon's Avatar
Member: 225229
Thanks Meter: 90
For W800i, you can follow the W550 tutorial.
Old 06-28-2009, 17:41   #10 (permalink)
Member: 892389
Thank u very much for this tutorial for w350 i flashing. iam very very happy.because first time iam doing the flashing of sony ericsson aone again thankful to u sir.
Old 06-27-2013, 15:11   #11 (permalink)
Member: 1867931
Sonork: 100.1625521
Thanks Meter: 36
unlock done
sony w350 free unlock ok by setool
CARD SERIAL: 00025968
Loaded 51 flash descriptors
SIGNED MODE (USING SERVER).
ChipID000,EMP protocol:0301
PHONE IS RED RETAIL PRODUCT
FLASH CID detected:53
skipping empty loader...
OTP LOCKED:1 CID:52 PAF:1 IMEI:35586502844776 CERT:RED
Model:W350i
Brand:Vodafone ES
MAPP CXC article: R10BA015 prg1205-7402_VODAFONE_JH
MAPP CXC version: R10BA015
Language Package:VFE_LIVE_1
CDA article: 1208-9089
CDA version: R7A
Default article: 1204-3119
Default version: R10BA015
PROVIDER: 214-01
Network LOCKED
RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE
SECURITY UNITS BACKUP CREATED.
Elapsed: 39 secs.
ALTERNATIVE SECURITY BYPASS ENABLED.
PRELOADER SECURITY BYPASS ENABLED.
Speed:921600
LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER
Flash ID check:897E
Flash props sent ok
LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER
loader startup: executed
loader GDFS startup: executed
loader filesystem startup: executed
loader unlock: executed
DISCONNECT PHONE NOW
INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN
BE SURE THAT YOU SET PHONE IN "PHONE MODE"
IF ASKED, INSTALL PHONE DRIVERS
SEARCHING FOR PHONE, "STOP" TO ABORT
PHONE FOUND AT COM158
PHONE READY TO PROCEED
EXECUTOR STARTED
REMOVE CABLE FROM PHONE
REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
THEN PRESS "READY"
Speed:921600
Trying to launch embedded bootloader...
INT LDR:PNX5230_PRELOADER_FOR_SETOOL2
Flash ID check:897E
Flash props sent ok
FOUND: R10BA015_1205-7402_VODAFONE_JH
Restore from:R10BA015_1205-7402_VODAFONE_JH
full sig complete.
USERCODE RESET TO "0000"
Searching...
Firmware SIMLOCK check determined.
Unlock DONE
Elapsed: 321 secs.
how unlock SE w350i? defcon2 DreamBox 5 03-30-2009 23:51
Need Help Unlocking SE W580i! Please Help! babycafe Seking Server 1 01-18-2008 01:35
** Help unlocking SE K700i with Semctool or Usbsmart Jonny B SonyEricsson (USB-Smart) 12 05-27-2006 01:13
Hi FuriousTeam PLEASE HELP UNLOCK SE T616 simclub1 FuriouS II 1 03-15-2006 14:49
Page generated in 0.21801 seconds with 9 queries
