09-10-2008, 08:29 | #1 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 438 | repair GDFS PROBLEM K800i please help Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 ATTACH TP #2 AND PRESS "READY" Trying to launch embedded bootloader... TP #2 LOOKS OKAY RELEASE TP #2 AND PRESS "READY" INT LDRB2020_PRELOADER_FOR_SETOOL2 STAGE #2 PRELOADER NOT STARTED Elapsed: 50 secs. |
09-10-2008, 08:44 | #3 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 438 | Tp 1 was already done for tp 2 i was having problem then finally i remove chip and make connection !!! If now i presson tp1 nothing happens !! in version 37.. when using version 39 it writes: TESTPOINT REPAIR STAGE #1 STARTED Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35908701613981 CERT:N/A FLASH CID:0 COLOR:N/A COLOR NOT SUPPORTED Elapsed: 11 secs. |
09-10-2008, 08:46 | #4 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 438 | when using version 37 : v0.914037/UNI CARD SERIAL: 00069943 Loaded 51 flash descriptors TESTPOINT REPAIR STAGE #1 STARTED Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35908701613981 CERT:N/A FLASH CID:0 COLOR:N/A Elapsed: 9 secs. |
09-10-2008, 08:59 | #6 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 438 | Easy TP i couldnt do it.. can you post the easy TP? its near the 2capacitors? I put the needle there but nothing happs... shoould i press? HARD or scratch it first? DID get any good guide fr this SOLUtion... now what is the solution of the above error..... |
The Following User Says Thank You to zakiyyboss For This Useful Post: |
09-10-2008, 11:18 | #7 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 438 | WHEN PRESS TP1 again: TESTPOINT REPAIR STAGE #1 STARTED Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35908701613981 CERT:N/A FLASH CID:0 COLOR:N/A COLOR NOT SUPPORTED Elapsed: 17 secs. |
09-10-2008, 11:23 | #8 (permalink) |
03-26-2009, 00:37 | #9 (permalink) |
No Life Poster Join Date: Apr 2008 Location: karachi .. Age: 38
Member: 749969 Status: Offline Sonork: 100.1581886 Thanks Meter: 771 | Is it necessary to resold again both resistors near tp2 after tp.. and if i do wrong tp2 then is it necessary to start again whole process like first tp1 then tp2 or just start from tp2? my last question is is there any way to repair redblink with out opening phone in cid52 or above?? |
How Can I Repair Gdf For W200 Please | Gsmboutique.ma | DreamBox | 7 | 05-30-2010 17:29 |
Cant Repair GDFS for w200i, please help me.. | yeerk05 | Cruiser Suite | 1 | 09-15-2009 11:48 |
Repair GDFS S500i failed please help me | Tamansu | D-Unlock Suite | 3 | 04-27-2009 19:28 |
k810 repaire gdfs problem | ahmed14 | DreamBox | 1 | 03-30-2009 23:58 |
K530i unlock repair gdfs write failed PLEASE ADVICE ME! | gsm8g | DreamBox | 2 | 05-12-2008 08:19 |
