Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 03-29-2010, 13:57   #1 (permalink)
Member: 591385
Thanks Meter: 25
Repair GDFS V1.01
Well,
As we all know the repair GDFS can only be accomplished by using the Test Point or the new version using the Log!
This tutorial will show how to make the same without Test Point or even log a User on the server.
BeSegundo step is to perform the Recovery.
Check the option Use Server.
Clicking recovey.
Wait until the end.
Upon conclusion recovey will be an automatic downgrade is possible to work with the GDFS of that!
Then depart for tab Empty Fill & Repair and this area will do the repair.
  • Follow up the tab
  • At the select phone model [W580]
  • Select the GDFS inside the folder SeTool3
  • Add in the Selection FLASH FILE and click Flash.
Notice that I emphasized the format of the GDFS that is in SSW.
Do not forget that the entire procedure is necessary to rewrite the original imei.
Wait until the end ...
Concluding that item will return to the CID, which will be your preference, CID51, 52 or 53.
This will be done with the writing of Erom which is also located in the SeTool3.
Same procedure above.
  • Select the preferred Erom
  • Click Flash
  • Wait for the end of the process!
Completing this procedure read the information of the device.
When reading it and having this same image with everything right just apply a firmware and DONE.
Log of the same successful repair
By Michael Carvalho
The Following 24 Users Say Thank You to MaikonPhone For This Useful Post:
Old 03-29-2010, 14:44   #2 (permalink)
vistasamir's Avatar
Member: 619931
Sonork: 100.1593005
Thanks Meter: 44
after activation is it free repair GDFS
Old 03-29-2010, 15:16   #3 (permalink)
Member: 591385
Thanks Meter: 25
As you can see it is the previous version, enabling it is another situation
Old 04-26-2010, 10:35   #4 (permalink)
Member: 482670
Thanks Meter: 125
very useful.. i done alot set on repair gdfs now coz ur solution.. thanks very much brother =)
Old 04-26-2010, 11:01   #5 (permalink)
master_t2's Avatar
Member: 321796
Thanks Meter: 61
what about "w380" .there is no model in emty fill tab........so how to write???
Old 04-26-2010, 12:49   #6 (permalink)
Member: 253546
Thanks Meter: 12
@MaikonPhone
You mean to say that GDFS can be repair without activation/credits by this method?
Old 04-26-2010, 13:26   #7 (permalink)
Rhyan777's Avatar
Member: 893209
Thanks Meter: 272
W380 is PNX5230 not SUPPORTED on GDFS REPAIR,,,,
Correct me if im WRONG,,,,,,,
Br,.
Rhyan777
Old 04-27-2010, 14:44   #8 (permalink)
Member: 591385
Thanks Meter: 25
Unfortunately not yet supported, so you have information I'll post
Originally Posted by farrukhayub View Post
@MaikonPhone
Yes, this procedure does not need credit, just this version indicated
Br,.
Rhyan777
Yes!
Old 04-27-2010, 16:54   #9 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 760
with this procedure i repaired one db2020 today ...
thanks
Old 04-27-2010, 17:12   #10 (permalink)
Member: 96031
Thanks Meter: 4
this solution is nice............ to follow to every one''''''''''''''thankyou
Old 04-28-2010, 01:18   #11 (permalink)
sbitla's Avatar
Member: 108623
Sonork: 100.1615896
Thanks Meter: 64
Old 04-29-2010, 14:38   #12 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 760
help me repair my w810i
what is this error with w810i ?
Old 06-15-2010, 19:38   #13 (permalink)
Member: 1301891
all work is very good
Old 09-04-2010, 10:58   #14 (permalink)
Member: 1016080
graat sir nice,but it is old alraedy,how about w380 GDFS repair do u have the solution???
Old 09-12-2010, 03:46   #15 (permalink)
Member: 591385
Thanks Meter: 25
not possible.......
Which version Repair GDFS FREEEEE vistasamir SETool2 6 03-29-2010 22:14
v1.01 gdfs write bowei SETool2 1 03-23-2010 03:40
k800 IMEI MISMATCH ! GDFS solved by v1.01 setool charletan SETool2 8 03-14-2010 13:20
..:: 29/07/2008 - New Release - Cruiser Suite GDFS Backuper & Restorer v1.01 ::.. Mizar Cruiser Suite 42 10-12-2008 23:17
..:: Cruiser DB2020 GDFS Reader v1.01 ::.. Mainboard Cruiser Suite 82 06-02-2008 21:52
Page generated in 0.43699 seconds with 8 queries
