Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2009
Member: 984046 Status: Online Thanks: 0
| Rest files general question...? Are rest files CID dependant? Whw on my Setool installation, main software does not recognize rest files additionally placed in my Setool /rest files folder... ??? It happen to me on 2 different installation, so must be that I am doing something wrong, since didn't seen any such report here... After I produce that rest file (which appears same/name/size as one I placed in to rest folder) than it works O.K. ???! (Setool finds it) Are rests created with 9.xxxx40 (some old ver) different than one that 1.01 reckognizes? BR Haltec |
| | #2 (permalink) |
| Code: RUNNING v 1.01/UNI CARD SERIAL 00075xxxx USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35223902077xxx CERT:RED FLASH CID:52 COLOR:RED Model (from GDFS):K770i Brand:T-Mobile HR MAPP CXC article: R8BA024 prg1201-7602_TMOBILE_VI MAPP CXC version: R8BA024 Language Package: T_MOB_INT_B CDA article: 1202-4158 CDA version: R4A Default article: 1201-7603 Default version: R8BA024 PROVIDER: 219-01 Network LOCKED RESTORATION FILE NOT PRESENT "R8BA024_1201-7602_TMOBILE_VI" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED SECURITY UNITS BACKUP CREATED. Elapsed: 11 secs. SIGNED MODE (USING SERVER) PRELOADER SECURITY BYPASS ENABLED CFG:101000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35223902077xxx CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM26 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 STARTING BOOTLOADER... INT LDR:DB2020_PRELOADER_FOR_SETOOL2 LDR:DB2020 LOADER FOR SETOOL2 FLASH ID: 897E FOUND VERSION "R8BA024_1201-7602_TMOBILE_VI" can't open file "C:\Documents and Settings\Haltec\Desktop\v1.01\rest\R8BA024_1201-7602_TMOBILE_VI" USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. Unlock FINISHED Elapsed: 283 secs. ? BR Haltec Last edited by Haltec; 09-22-2010 at 23:51. Reason: phone dead - off course... (but that's no issue) |
| | #4 (permalink) |
| No... File is o.k., but it is not rest - it's Bypass package reckognized as rest? It's 3Kb (2.18) large file as compared to generated rest of ~500-600 Kb BR Haltec |
| | #5 (permalink) | ||
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2007 Location: Talk to *** and He Will Listen
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks: 1,695
| Quote:
open gui then add main /fs and then identify. Rest file will be present. XTRACT FISRT BEFORE PASTE INTO REST FOLDER DONT PASTE WINRAR INTO REST FOLDER | ||
| | #6 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2006 Location: INDIA Age: 27
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks: 8
| HERE IS THE REST FILE THAT U NEED UNZIP IT AND PASTE IT IN REST FOLDER RapidShare: 1-CLICK Web hosting - Easy Filehosting WBR sahil2000ind |
| | #7 (permalink) |
| Thx guys, really. But I know how to make REST. Problem is here: FOUND VERSION "R8BA024_1201-7602_TMOBILE_VI" can't open file "C:\Documents and Settings\Haltec\Desktop\v1.01\rest\R8BA024_1201-7602_TMOBILE_VI" And if that 3Kb file is bypass package - why is not detected as so, during "Identify"? (which obviousely IS) This is not actually a problem - phone is o.k & unlocked. BR Haltec Last edited by Haltec; 09-23-2010 at 13:56. Reason: Thx sahil2000ind - that's the CORRECT rest I was needed. |
| | #10 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks: 0
| Man it's November 2010 ! Since march 2010 there is no need rest to unlock DB2XXX phones. Please read faq and apply directly reset procedure. ps. no need gdfs neither BR Max_B |
| | #11 (permalink) |
| Is it working with <1.01 ??? And user data need intact. I flashed other Main only and unlock it with it... (was tired & didn't come up with that on spot) thx tough BR Haltec |
| | #12 (permalink) |
| Too bad on this forum everyone misdirects anyone. Yes working without activation Just perofrm Reset procedure without gdfs write No need rest No data loss Delay = 15 seconds Read about reset operation : http://support.setool.net/showathrea...1-BASED-PHONES BR Max_B |
| | #13 (permalink) |
| Well... When someone name setup options, with verb/word difference (Alternative sec bypass & Preloader sec bypass) easilly to loose will for FAQ reading... About: http://support.setool.net/showathrea...1-BASED-PHONES http404 Altough irrelevant, but you hurt my feelings ![]() BR Haltec p.s. thx for your answer. |
| | #14 (permalink) |
| HOW TO WORK WITH A1-BASED PHONES if not F.A.Q.. Recovery Settings = Signed mode 10000000 erom flash = none 00000000 BR Max_B |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Change Bin-file in Nokia..possible?? | BiG | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 11-20-1999 15:56 |
| 5110 ver 5.24 scr file | friendlypirate | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 11-06-1999 04:04 |
| how can we use *.scr files to unlock | shadow77 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 10-27-1999 03:13 |
| Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 09-26-1999 14:31 |
| Question about 51xx/61xx | Comic | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 07-06-1999 23:47 |
