02-06-2011, 07:07 | #1 (permalink) |
No Life Poster Join Date: Apr 2010
Member: 1276771 Status: Offline Thanks Meter: 33 | s500 cant flash 1 recover 2nd write gdfs after then when i flash it gives this error i ticked mark olny sign mode USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35908501877879 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\setool flash file\s500\R6BC002_1123326_GENERIC_LY.ssw" CURRENT FLASH FILE CID: 52 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 9 secs. can any one tell me where do i mistake??????????? |
02-06-2011, 17:20 | #3 (permalink) |
Member: 1276771 Status: Offline Thanks Meter: 33 | SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35908501877879 ACTIVE CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E writing "C:\Documents and Settings\javeed\My Documents\Downloads\R6AC003_1123326_GENERIC_LY.ssw " CURRENT FLASH FILE CID: 52 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 16 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111100000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M packet not acknowledged (0D) FAILED TO SETUP PHONE Elapsed: 108 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111100000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35908501877879 ACTIVE CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed can't get packet start. FS startup failed,error is 00 [ 0] loader fs startup failed, that is fatal Elapsed: 209 secs. where is my mistakes???????????? |
04-30-2015, 14:52 | #6 (permalink) |
Major Poster Join Date: Feb 2010
Member: 1237241 Status: Offline Thanks Meter: 4 | W580i CID 53 color red Done by this process RUNNING v 1.1411/01.15/UNI CARD SERIAL 00128323 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 PROCEDURE WAS STOPPED BY USER CAN'T LOAD IDENTIFICATION LOADER. Elapsed: 1 secs. CFG:000000000000 llbug: read error: "The device does not recognize the command" ChipID: 9900, EMP protocol: 0301 PHONE DOMAIN: "RETAIL" PHONE CID: 0052 SPEED: 921600 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLASH ID: 2019 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35651402160375 CERT:RED ACTIVE CID: 52 COLOR: RED Model (from GDFS): W580i MAPP CXC article: R8BE001 prgCXC1123474_ORANGE_LA MAPP CXC version: R8BE001 Language Package: ORANGE_GEN CDA article: CDA102774/18 CDA version: R11A Default article: cxc1123364 Default version: R8BE001 NETWORK LOCKED PROVIDER: 234-33 SECURITY UNITS BACKUP CREATED. Elapsed: 30 secs. CFG:000000000000 ChipID: 9900, EMP protocol: 0301 PHONE DOMAIN: "RETAIL" PHONE CID: 0052 SPEED: 921600 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:35651402160375 CERT:RED CURRENT CID: 52 COLOR: RED LDR: 061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR: 080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 Downgrading security ... DETACH CABLE FROM PHONE, THEN CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 921600 RESET: 070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA GOT SEED: 625276C42380A27025702727 P96 AUTH PASSED Restarting ... DETACH CABLE FROM PHONE, THEN CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 921600 LDR: DB2020 LOADER FOR SETOOL2 CURRENT CID: 49 COLOR: BROWN Setting up GDFS ... failed to setup GDFS Unlock FAILED Elapsed: 69 secs. CFG:000000000000 llbug: read error: "The device does not recognize the command" ChipID: 9900, EMP protocol: 0301 PHONE DOMAIN: "RETAIL" PHONE CID: 0053 SPEED: 921600 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLASH ID: 2019 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35651402160375 CERT:RED ACTIVE CID: 53 COLOR: RED Model (from GDFS): W580i MAPP CXC article: R8BE001 prgCXC1123474_ORANGE_LA MAPP CXC version: R8BE001 Language Package: ORANGE_GEN CDA article: CDA102774/18 CDA version: R11A Default article: cxc1123364 Default version: R8BE001 NETWORK LOCKED PROVIDER: 234-33 SECURITY UNITS BACKUP CREATED. Elapsed: 27 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111000000000 ChipID: 9900, EMP protocol: 0301 PHONE DOMAIN: "RETAIL" PHONE CID: 0053 SPEED: 921600 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:35651402160375 CERT:RED CURRENT CID: 53 COLOR: RED FLASH ID: 2019 Downgrading security ... DETACH CABLE FROM PHONE, THEN CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 921600 RESET: 070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA GOT SEED: 138CD3D72380A27025702727 P96 AUTH PASSED Restarting ... DETACH CABLE FROM PHONE, THEN CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 921600 LDR: DB2020 LOADER FOR SETOOL2 CURRENT CID: 49 COLOR: BROWN Setting up GDFS ... WRITING CLEAR SIMLOCK UNITS ... SIMLOCK CODES SET TO "47868712" SIGNING ... Unlock DONE Elapsed: 41 secs. |
04-30-2015, 14:52 | #7 (permalink) |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Nokia Flash Content. | Phantom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-01-2000 23:28 |
