03-15-2010, 07:54 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: CLOUD Age: 40
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | s500 flashing error Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35912202081413 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\MISS MY LOVE\Desktop\v1.01\Flash File\s500\cid53\r8e001\R8BE001_1123326_GENERIC_LY. ssw" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 31 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110101100000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35912202081413 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\MISS MY LOVE\Desktop\v1.01\Flash File\s500\cid53\r8e001\R8BE001_1123326_GENERIC_LY. ssw" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 11 secs. |
The Following User Says Thank You to mohit_kripalu01 For This Useful Post: |
03-15-2010, 07:58 | #3 (permalink) | ||
No Life Poster Join Date: Jul 2005 Location: philippine
Member: 159757 Status: Offline Thanks Meter: 461 | Quote:
then at SEMC option FLASH main and fs br. | ||
03-15-2010, 08:13 | #4 (permalink) | |
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | Quote:
Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35912202081413 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\MISS MY LOVE\Desktop\v1.01\gdfs_in_ssw_format\db2020\s500_ gdfs_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "71250236" SIGNING... Elapsed: 225 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35912202081413 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\MISS MY LOVE\Desktop\v1.01\eroms\db2020\DB2020EROM_BROWN49 _BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 80 Will flash 4 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "82413404" SIGNING... Elapsed: 44 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35912202081413 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\MISS MY LOVE\Desktop\v1.01\Flash File\s500\cid53\r8e001\R8BE001_1123326_GENERIC_LY. ssw" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 19 secs. | |
03-15-2010, 08:24 | #5 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Somewhere there Age: 14
Member: 567723 Status: Offline Thanks Meter: 314 | Quote:
Just check "signed mode " on setting tab and press recovery, after this write gdfs in ssw format and reflash your phone br >>> GsmFreeShop <<< | |
03-15-2010, 09:53 | #6 (permalink) | |
SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:115200 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 897E GOT SEED:5083240F2380D27A2550E013 P96 AUTH PASSED OTP: LOCKED:1 CID:51 PAF:1 IMEI:35912202081413 CERT:N/A PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 21 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35912202081413 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\MISS MY LOVE\Desktop\v1.01\gdfs_in_ssw_format\db2020\s500_ gdfs_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... Elapsed: 217 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35912202081413 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\MISS MY LOVE\Desktop\v1.01\Flash File\s500\cid53\r8e001\R8BE001_1123326_GENERIC_LY. ssw" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 20 secs. | |
03-16-2010, 10:24 | #9 (permalink) |
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | RUNNING v1.0/UNI CARD SERIAL 00048752 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35912202081413 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\MISS MY LOVE\Desktop\v1.01\eroms\db2020\DB2020EROM_CNV_RED 49_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 80 Will flash 4 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "88876178" SIGNING... Elapsed: 52 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35912202081413 CERT:N/A FLASH CID:49 COLOR:RED Bypass loader not responding ! Elapsed: 37 secs. |
03-16-2010, 10:26 | #10 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,053 | Wrong EROM Flashed Code: writing "C:\Documents and Settings\MISS MY LOVE\Desktop\v1.01\eroms\db2020\DB2020EROM_CNV_RED 49_BROWN_CID49_DB2020.ssw" |
03-16-2010, 10:47 | #11 (permalink) | |
CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35912202081413 CERT:N/A FLASH CID:49 COLOR:RED Bypass loader not responding ! Elapsed: 20 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35912202081413 CERT:N/A FLASH CID:49 COLOR:RED Bypass loader not responding ! Elapsed: 20 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35912202081413 CERT:N/A FLASH CID:49 COLOR:RED Bypass loader not responding ! Elapsed: 20 secs. | |
03-16-2010, 10:55 | #12 (permalink) |
Member: 890926 Status: Offline Thanks Meter: 2,053 | Repeat Reset Procedure Mate Code: OTP: LOCKED:1 CID:51 PAF:1 IMEI:35912202081413 CERT:N/A FLASH CID:49 COLOR:RED |
N96 Weird Flashing error | javakiller | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 10-10-2010 11:55 |
1650 flash error | nilesh_patel717 | Nokia Hardware & Hardware Repair | 3 | 03-29-2010 14:03 |
s500 flashing error | rohit50 | SETool2 | 7 | 11-15-2009 11:25 |
s500 flashing error | jmustufa | SETool2 | 2 | 07-02-2008 07:36 |
S500 Problem: Error during the sector download | Anno | Trident/AGERE Platform | 1 | 05-26-2004 21:15 |
