12-21-2008, 21:23 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: The Netherlands Age: 34
Member: 666582 Status: Offline Thanks Meter: 12 | S500i CID53 Not Powering ON!! ''executing CS FS startup'' SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:*** PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:352972******* CERT:RED FLASH CID:53 COLOR:RED Model:S500i MAPP CXC article: R8BE001 prgCXC1123326_GENERIC_LY MAPP CXC version: R8BE001 Language Package:EUROPE_3 CDA article: CDA102765/120 CDA version: R2A Default article: cxc1123328 Default version: R8BE001 PROVIDER: 204-08 Network LOCKED SEARCH:C:\Documents and Settings\SACI AMIRI\Bureaublad\R8BE001_1123326_GENERIC_LY.ssw "R8BE001_CXC1123326_GENERIC_LY" CREATED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 90 secs. SIGNED MODE (USING SERVER). ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:352972******* CERT:RED FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed wrong response, break. loader fs startup failed, that is fatal PROCEDURE WAS STOPPED BY USER Elapsed: 107 secs. SIGNED MODE (USING SERVER). PRELOADER SECURITY BYPASS ENABLED. phone pre-boot failed,possible RECOVERY needed. PROCEDURE WAS STOPPED BY USER Elapsed: 2 secs. SIGNED MODE (USING SERVER). PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:352972025******* CERT:RED FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed NOW HE IS HANGING ON ''executing CS FS startup'' |
12-22-2008, 03:29 | #4 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Talk to *** and He Will Listen
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks Meter: 1,104 | flash the phone 1. signed mode ( using server ) 2. alternative sec bypass enable 3. complete phone after flash if still the same problem ( no one is GDFS problem |
12-22-2008, 10:53 | #5 (permalink) |
Member: 666582 Status: Offline Thanks Meter: 12 | Solution I have repaired my phone. I have used the next optoins: - Signed Mode - Complete phone after flash When i did this the phone didnt get through the LOADER (exucuted part etc) and started write flash! After flashing phone completly, he turned on! So now i have unlocked the phone and he didnt gave me a ''FS CS Startup failed''' THANKS FOR ALL!!!! |
6030 mobile not power on, on battery and working fine on power supply | kashif_khatri | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 09-19-2009 02:57 |
7370 power on on ufs but not power on battrey | dereje | Nokia Hardware & Hardware Repair | 0 | 05-26-2009 09:25 |
help 3310 in tornado it power on but with batterie it not power on | sofiame2006 | Nokia Hardware & Hardware Repair | 3 | 08-02-2005 08:46 |
G5600 not powers on with sim while without sim powers on :( need help | the_frightener | LG | 1 | 03-20-2005 06:18 |
t100 not power on after flash, not power on when original cable is plug | GYZMO | VLSI, Conexant, Skyworks and Old Models | 8 | 01-07-2004 00:34 |
