04-18-2009, 19:31 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | <<< S500i flashing problem- need help >>> thanks in advance. v0.915034/UNI CARD SERIAL: xxxxxx Loaded 51 flash descriptors SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35683301427536 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT Can't read IMEI (COM9) Can't read IMEI (COM9) PHONE FOUND AT COM9 Phone not responds to AT #1, retry 1 Phone not responds to AT #1, retry 2 Phone not responds to AT #1, retry 3 Phone not responds to AT #1, retry 4 Phone not responds to AT #1, retry 5 Elapsed: 299 secs. |
04-19-2009, 06:08 | #2 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | I think u have selected wrong options in setting tab. for flashing just tick 2 option, use signed mode and complete phone after flash... |
The Following User Says Thank You to zeel_zeel For This Useful Post: |
04-19-2009, 09:12 | #3 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 339455 Status: Offline Sonork: 100.1589401 Thanks Meter: 86 | ok! you have mistak in setting chose options tick this boxes in settings tab: Signed mode(server used.....) compleat phone after flash these are only needed chooses for your work. |
The Following User Says Thank You to mazmaz1 For This Useful Post: |
04-19-2009, 13:05 | #4 (permalink) | |
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | Quote:
<<<<<<<<<<full flash>>>>>>>>>>>>>> v0.915034/UNI CARD SERIAL: 00092666666 Loaded 51 flash descriptors SIGNED MODE (USING SERVER) ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:356833055555555 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing "C:\Documents and Settings\Administrator\Desktop\s500i setool flash file\R8BA024_1123326_GENERIC_LY.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 writing "C:\Documents and Settings\Administrator\Desktop\s500i setool flash file\R8BA024_FS_S_ASIA_LEVAN_LY_RED_CID52.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is:3620 Will flash 181 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed writing "tpa/preset/custom/C3_PCA_G3v2.cer" writing "tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm" writing "tpa/preset/custom/customize.xml" writing "tpa/preset/custom/DESKTOP_HOOK_2.itm" writing "tpa/preset/custom/Entrust.net Root Certificate.cer" writing "tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt" writing "tpa/preset/custom/FM_PICTURES_HOOK_3.itm" writing "tpa/preset/custom/FM_SOUNDS_HOOK_3.itm" writing "tpa/preset/custom/FM_THEMES_HOOK_3.itm" writing "tpa/preset/custom/FM_VIDEOS_HOOK_3.itm" writing "tpa/preset/custom/GAMES_HOOK_3.itm" writing "tpa/preset/custom/GTE_CyberTrust_Root.cer" writing "tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt" writing "tpa/preset/custom/Root.cer" writing "tpa/preset/custom/SEMC_E2E_Root_CA.crt" writing "tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm" writing "tpa/preset/custom/ThawtePremium.der" writing "tpa/preset/custom/ThawteServerCA.cer" writing "tpa/preset/custom/Utiroot.cer" writing "tpa/preset/custom/VeriSignClass3Root.cer" writing "tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt" Phone detached Elapsed: 442 secs. SIGNED MODE (USING SERVER) ChipID:9900,EMP protocol:0301 <<<<<<<<< unlock >>>>>>>>>>>>> PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35683366666666 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed USERCODE RESET TO "0000" Elapsed: 31 secs. | |
04-19-2009, 19:22 | #5 (permalink) |
Cheater -Don't Deal with him- Join Date: Mar 2006 Location: Who am i ?.....
Member: 240342 Status: Offline Sonork: 100.1576037 Thanks Meter: 852 | after complete phone still have problem ? did you flash it the exit version ? it can be hardware falt too !! br WINK SHAFEEQ GEO MOBILES |
04-20-2009, 05:47 | #6 (permalink) | |
Member: 339455 Status: Offline Sonork: 100.1589401 Thanks Meter: 86 | Hello Quote:
flash it with another version file Are you see Identify of phone befor flashing(phone's version).? Are you flash another phones befor this, with this file ? Is phone compleatly died or you feel vibra after power key pressing? test with fully charged battery. post result bro. | |
<<< every N70 not flashing Please Need Help >>> | Faisal_Computer | MT-BOX | 3 | 01-15-2008 10:39 |
flash problem..need help cruiser team | alanchao | Cruiser Suite | 4 | 07-14-2005 21:50 |
C62 Flashing Problem Need Help Please | vinz4ever | NON Siemens Brand (ODM Phones) | 0 | 04-26-2005 20:01 |
6310i flash problem need help | gsm_style | UFS2 + UFS3-Tornadoflasher | 8 | 10-30-2004 08:50 |
V200 Flashing Problem-need help urgent. | dominik | Trident/AGERE Platform | 2 | 07-19-2003 18:13 |
