07-30-2011, 11:19 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: spain
Member: 662869 Status: Offline Sonork: diopinfor Thanks Meter: 27 | SE e15 after unlock no services red thank all frens for this forum .............! SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" BUTTON... EROM "R8A029" AID: 0001 SOFTWARE AID: 0001 LOADER AID: 0001 FLASH ID: "002C/00BC" LOADER VERSION: "R4A045" PHONE IMEI:01256000220810 REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAS ANDROID 2.x FIRMWARE WARMING UP... GETTING ROOT ACCESS ... APPLYING ROOT RIGHTS ... PROCESSING ... FINALIZING ... Unlock DONE Elapsed: 164 secs. |
07-30-2011, 11:37 | #3 (permalink) | |
Member: 662869 Status: Offline Sonork: diopinfor Thanks Meter: 27 | Quote:
Checking for signature... Waiting for calculation process... recv error [10054] signature calculation not done,err: 144 Unlock FAILED Elapsed: 8 secs. | |
07-30-2011, 11:54 | #5 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,126 | did you tick these 3? SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED tick perform full unlock instead of usercode |
The Following User Says Thank You to Mr.3. For This Useful Post: |
07-30-2011, 11:55 | #6 (permalink) | |
No Life Poster Join Date: Dec 2003 Location: UNSHAKEABLE LIFE
Member: 45656 Status: Offline Thanks Meter: 31 | Quote:
07-30-2011, 12:02 | #8 (permalink) | |
No Life Poster Join Date: Aug 2005 Age: 47
Member: 175544 Status: Offline Thanks Meter: 198 | Quote:
good luck | |
The Following User Says Thank You to zolla For This Useful Post: |
07-30-2011, 16:47 | #10 (permalink) | |
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,126 | Quote:
Check this thread for info http://forum.gsmhosting.com/vbb/f473...cking-1318088/ | |
08-01-2011, 10:13 | #11 (permalink) | |
SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" BUTTON... EROM "R8A029" AID: 0001 SOFTWARE AID: 0001 LOADER AID: 0001 FLASH ID: "002C/00BC" LOADER VERSION: "R4A045" PHONE IMEI:01256000220810 MODEL (from GDFS): E15a SOFTWARE VERSION: 1236-9291_2.0.1.A.0.47 FILESYSTEM VERSION: WORLD-1-2-5_2.1.1.A.0.6 CUSTOM VERSION: 1241-3974_R3B SERIAL NO: CB511RFVHB Elapsed: 16 secs. thanks all frens ..........................! | |
08-01-2011, 15:16 | #12 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: philippines
Member: 448980 Status: Offline Thanks Meter: 136 | Quote:
power on phone without simcard, if menu has come even without sim, it's mean your phone is android 2.x already. ps_tech | |
08-01-2011, 22:14 | #13 (permalink) |
No Life Poster Join Date: May 2004
Member: 64893 Status: Offline Thanks Meter: 221 | U20i no signal tested by me. Working ok after Box 1, 2 and 5. Code: RUNNING v 1.1099/01.12/UNI CARD SERIAL ????????? USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" BUTTON... EROM "R8A029" AID: 0001 SOFTWARE AID: 0001 LOADER AID: 0001 FLASH ID: "00EC/00BC" LOADER VERSION: "R4A045" PHONE IMEI:0124680024XXXX REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAS ANDROID 2.x FIRMWARE WARMING UP... GETTING ROOT ACCESS ... APPLYING ROOT RIGHTS ... PROCESSING ... FINALIZING ... Unlock DONE Elapsed: 108 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 SERVER CREDITS LEFT/USED: 20/10 CARD COUNTERS: FLASH 1353, UNLOCK 973 credits consumption for full signature unlock: S1 v1 4 credits ( OFFLINE ) S1 v2 10 credits ( OFFLINE ) S1 OPEN 6 credits ( AID 004 OFFLINE ) A1 phones 6 credits A2 phones 6 credits ( DO NOT USE FOR J108 ) W100,W150 codes 4 credits X10i,E10,E15,E16,U20 alternative bypass 4 credits current setool2 version: 1.1099 Elapsed: 9 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" BUTTON... EROM "R8A029" AID: 0001 SOFTWARE AID: 0001 LOADER AID: 0001 FLASH ID: "00EC/00BC" LOADER VERSION: "R4A045" PHONE IMEI:0124680024XXXX Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1187] REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAS ANDROID 2.x FIRMWARE WARMING UP... GETTING ROOT ACCESS ... APPLYING ROOT RIGHTS ... PROCESSING ... FINALIZING ... Unlock DONE Elapsed: 122 secs. |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 | andrew bennett | Main Sales Section | 0 | 07-09-1999 10:41 |
