Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 01-31-2012, 18:34   #1 (permalink)
Member: 1225428
SE J10i2 after unlock 5 lock
After unlock SE j10i2 phone 5 lock
How to solve problem
RUNNING v 1.1203/01.12/UNI
CARD SERIAL 00011256
USBFLASH DRIVER VERSION 02.02.00.05
SIGNED MODE (USING SERVER)
CFG:100000000000
Processing script "C:\setool\backup\35480804824734\35480804824734_31 _1_2012_18_23_50.backup" ...
ChipID:F100,EMP protocol:0401
PHONE STATE: "RETAIL"
FLASH CID: 0081
OTP LOCKED:1 CID:81 PAF:1 IMEI:35480804824734 CERT:RED
LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096
LDR CAPS:SYSTEM FLASH SIGNATURE AUTH
LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096
LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA
writing TA var 0002/1062/01AE
writing TA var 0002/1063/006A
writing TA var 0002/1064/0028
writing TA var 0002/1037/042F
Elapsed: 30 secs.
CFG:100011000000
PROCEDURE WAS STOPPED BY USER
FAILED TO SETUP PHONE
Unlock FAILED
Elapsed: 2 secs.
CFG:100011000000
FLASH CID: 0081
OTP LOCKED:1 CID:81 PAF:1 IMEI:35480804824831 CERT:RED
Model (from GDFS):J10i2
MAPP CXC article: R7CA061 prg1231-1917_GENERIC_SU
MAPP CXC version: R7CA061
Language Package: CENTRAL-EUROPE
CDA article: 1235-6812
CDA version: R9A
Default article: 1229-0655
Default version: R7CA061
PROVIDER: 219-01
Network LOCKED
SECURITY UNITS BACKUP CREATED.
Elapsed: 86 secs.
CFG:100011000000
FLASH CID: 0081
Executing CSCA-based unlock.
Checking for signature ...
Waiting for calculation process ...
RESPONSE: "SUCCESS" [1038]
Backup security data ...
Erasing locks ...
DISCONNECT PHONE NOW
REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN
INSTALL PHONE MODEM DRIVERS IF NEEDED
SEARCHING FOR PHONE, "STOP" TO ABORT
PHONE FOUND AT COM257
PHONE READY TO PROCEED.
GOT SEED:00C23468
ACTIVATION COMPLETED. USERCODE RESET TO "0000"
Unlock DONE
Old 02-01-2012, 02:38   #2 (permalink)
gsmfriend's Avatar
Member: 37521
I try unlock this phone since a week but always : server error:remote dongle not available
how to do that man!
Old 02-01-2012, 03:00   #3 (permalink)
Member: 1617281
how to do that man!
please use setool, mark "signed mode", "do full unlock", "disable flash mode actiovation for semc a2"
it costs one credit
Old 02-01-2012, 04:06   #4 (permalink)
Danish Shafiq's Avatar
Member: 1118710
Sonork: 100.1604414
CID 80 & 81 try this Method..
1. Select Proper Modle From List & Go to Setting Option
2. Select Sign Mode
3. Perform Full Unlock Instead User Code Reset
4. Disable Flash Mode Activation For Semc A2 Phones
5. Press Unlock
6. when you will get message "unlock done" - do not remove cable or battery,
wait until phone automatically power on, otherwise you will get 5 locks
and need to repeat procedure.
The Following 2 Users Say Thank You to Danish Shafiq For This Useful Post:
Old 02-01-2012, 10:25   #5 (permalink)
dilshad_noori's Avatar
Member: 1293519
Sonork: 100.1596500
2. Select Sign Mode
5. Press Unlock
100% sure
Old 02-01-2012, 14:47   #6 (permalink)
manzoor300's Avatar
Member: 817733
Sonork: 100.1605504
good work bro...Danish Shafiq....
Old 02-02-2012, 14:59   #7 (permalink)
UU2
Member: 21987
Re...
FLASH CID: 0081
OTP LOCKED:1 CID:81 PAF:1 IMEI:.............. CERT:RED
No credits left.
signature calculation not done,err: 144
Unlock FAILED
Elapsed: 16 secs.
SERVER CREDITS LEFT/USED: 4/26
CARD COUNTERS: FLASH 424, UNLOCK 403
Elapsed: 2 secs.
5 log is needed for the opening you are other the problem?
Because I could so that is not going since months already the server!
Old 02-03-2012, 09:17   #8 (permalink)
UU2
Member: 21987
Nobody????????????
Old 02-03-2012, 10:34   #9 (permalink)
mobilefactor's Avatar
Member: 1560569
FLASH CID: 0081
No credits left.
Unlock FAILED
Elapsed: 16 secs.
Elapsed: 2 secs.
read your log ( No credits left. )
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 05-10-2012 14:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
SP Lock 1&4 dw Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 11 06-26-1999 06:22
Need info for unliocking 2 lock (with pic microprocesors) Tomas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-26-1999 01:00
Page generated in 0.30236 seconds with 11 queries
