11-01-2008, 14:32 | #1 (permalink) |
Product Supporter Join Date: Feb 2008 Location: Jat-Chi-Bangladesh Age: 46
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | A2 (db3150) phone, which was unlocked /SE-TOOL special service usb cable. pinout a: you need setool2 version >=v0.95 for that. 1. go to a2 tab 2. select correct model, that is important. 3. go to settings tab. 4. mark "use signed mode" , "use alternative security bypass" 5. go back to a2 tab 6. set "retail" domain 7. press unlock 8. follow program instructions 9. your phone is converted to "retail" state. you do not need credits for that procedure. q: how to unlock/repair a2 phone (db3000,db3150,db3210) using altbypass option? what problems can i encounter and how to avoid them ? how many credits i need ? a: you need setool2 version >=v0.95 for that. first, you can repair ANY software problems for currently released A2 phones. for that, you need to do several simple steps: 1. go to a2 tab 2. select correct model, that is important. 3. go to settings tab. 4. mark "use signed mode" , "use alternative security bypass", "unlock after flash" 5. go back to a2 tab 6. set desired domain ("retail" is best choice) 7. if you want to flash phone, add neccessary firmwares to firmware area and select correct custpack 8. if you selected firmwares, press flash, otherwise press unlock. 9. follow program instructions 10. your phone is repaired and unlocked (and flashed) you do not need credits for that procedure. if phone is totally damaged (foreign trim area), you required to write gdfs package from normal phone and make unlock again. q: What is filemanager ? how to run it? why i can't read files ? a: you need setool2 version >=v0.914042 for that. filemanager is visual tool to play with files. create script (text files) with one string Code: fsManager: note ! you can check only "signed mode", it will run filemanager fast, but you will not be able to read files, only write. in order to read files, you need: for db2000,db2010 phones <= cid49 - uncheck ALL settings for db2010,db2020,pnx5230 phones <= cid53 - check "use signed mode","use alternative security bypass", "use preloader security bypass" for a2 phones (db3150,db3210) <=cid52 - "use signed mode", "use alternative security bypass" and set domain to "r&d" or "factory" to rename file/directory press F2 or select "rename" from popup menu to delete file/directory press DEL or select "delete" from popup menu note, that directory should be empty in order to delete it. to write file/directory, drag-and-drop it from windows explorer to desired directory on phone. to read file/directory press F5 or select "read" from popup menu. note, that files/directory will be save to %setool2%\ph_out directory,existing files overwriting without notice. q: i want to service j132 phone, but it not have fastport connector, only minuUSB. what to do ? a: you need setool2 version >=v0.914042 for that. you should create connector yourself: select either ufs or com modification (pinout discovered by rockerdongle team) please note, that if you will create cable with 3 pins only, you should manually press power on button on phone when program displays "powering..." q: for curiosity i have flashed ROM image in my lg ku580/kf75x/kt52x. phone goes dead. i unlocked it and it came back to life, but i have no network. what to do ? a: you need setool2 version >=v0.95 for that. you need write gdfs package from working phone. just select correct model, add to misc. edit gdfs package and press "write gdfs". q: i can not connect lg ku580/lg75x/kt52x/sagem my805c to setool2 with supplied USB cable. phone simple turns on and setool2 don't recognize it. a: you need setool2 version >=v0.95 for that. you should use special service usb cable. pinout and conversion of supplied cable to "service" is attached conversion for ku580/kf75x/kt52x usb cables: conversion for sagem my850c cable BR: TUR@n ALAM Last edited by TUR@N ALAM; 11-01-2008 at 14:41. |
The Following 5 Users Say Thank You to TUR@N ALAM For This Useful Post: |
Special RJ45 + USB cable for LG3G | milanbarros | FuriouS II | 0 | 07-14-2005 10:06 |
X65 USB Cable PinOut and Drivers for SST | ednacell | S-Gold Based Phones | 12 | 01-30-2005 12:09 |
Usb cable pinout for v220 needed | stlan88 | Motorola P2k | 5 | 12-19-2004 14:48 |
i need usb cable pinout for gx-30 | Platijet | Sharp | 2 | 10-21-2004 09:10 |
Help!!! Heed e365 usb cable pinout. | veso | Motorola ODM | 0 | 12-17-2003 07:17 |
