07-31-2015, 00:31 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: at ...
Member: 219093 Status: Offline Thanks Meter: 14 | SE v640i dead OTP: LOCKED:1 CID:52 PAF:1 IMEI:35880101155026 CERT:RED LDR: 2010-03-02 17:53 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 17:54 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA [A2_loader] hdr err: 1022 [A2_loader] bad result [01/11] Elapsed: 11 secs. |
08-01-2015, 18:34 | #3 (permalink) |
Member: 219093 Status: Offline Thanks Meter: 14 | Thanks freinds to reply the phone is revive with the k630 flash but now when i put the sim card (configuration error please contact your network operator or service center) and i can't flash it for second time |
08-02-2015, 12:00 | #4 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: England
Member: 193192 Status: Offline Thanks Meter: 327 | Quote:
if having difficulty connecting with C button, try using 2 and 5 pressed together instead | |
The Following User Says Thank You to moshman For This Useful Post: |
08-02-2015, 17:45 | #5 (permalink) | |
Member: 219093 Status: Offline Thanks Meter: 14 | Quote:
-R1DA038_APP_SW_1200_4911_GENERIC_JI_REDBROWNBLUE_C ID52_49_DB3150 -R1DA038_FS_APAC_ANZ_JI_REDBROWNBLUE_CID52_49. and no i can't connect the phone with C or 2+5 | |
08-02-2015, 23:24 | #7 (permalink) |
Member: 219093 Status: Offline Thanks Meter: 14 | RUNNING v 1.1416/01.12/UNI CARD SERIAL 00xxxxxxx CFG:001000000000 PROCEDURE WAS STOPPED BY USER CAN'T LOAD IDENTIFICATION LOADER. Elapsed: 82 secs. CFG:001000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 50 secs. CFG:001000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 61 secs. CFG:000000000000 RECOVERY MODE STARTED PROCEDURE WAS STOPPED BY USER Elapsed: 36 secs. PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:001000000000 RECOVERY MODE STARTED PROCEDURE WAS STOPPED BY USER Elapsed: 99 secs. PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:001000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 133 secs. CFG:000000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 7 secs. PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:001000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 97 secs. PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:001000000000 RECOVERY MODE STARTED PROCEDURE WAS STOPPED BY USER Elapsed: 67 secs. PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:001000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 46 secs. PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:001000000000 RECOVERY MODE STARTED PROCEDURE WAS STOPPED BY USER Elapsed: 52 secs. I used two fonction, with the SEMC A2 and Empty Fill & repair.. |
08-03-2015, 01:02 | #8 (permalink) |
Freak Poster Join Date: Jul 2007 Location: deveselu
Member: 543935 Status: Offline Thanks Meter: 59 | I think you need to repair GDFS and then update/unlock. I haven't many times same problems. Enviado desde mi iPhone con Tapatalk |
The Following User Says Thank You to cocosel For This Useful Post: |
08-03-2015, 08:32 | #9 (permalink) |
Member: 193192 Status: Offline Thanks Meter: 327 | ORIGINAL flashing log required please. Not attempts made after Why did you make Empty fill repair ? |
