09-03-2009, 08:13 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Noise City
Member: 889564 Status: Offline Thanks Meter: 336 | SE W610i Strange Flashing problem I have this W610i that freaks me out!!!!! The phone had this problem-when press power button,the set switch on white screen and stuck!!I tried to flash it but Setool gave me this error can't get packet start. FS startup failed,error is 00 [ 0] loader fs startup failed, that is fatal At first i tried with different flashes but nothing happens for good.Next i wrote GDFS but same thing,I rehooted all ICs that are not glued....nothing again...I thing that Im goin' in circle and can't figure it out so I need somebody's help!!Here is the flash log. v0.915040/UNI CARD SERIAL: ******** Loaded 51 flash descriptors SIGNED MODE (USING SERVER) CFG:10001000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:357***********CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing "G:\SonyEricsson\SETOOL\FLASHES\W610\CID52\R6B C002 _1250747_GENERIC_NA.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... SSW loading returns:0 writing "G:\SonyEricsson\SETOOL\FLASHES\W610\CID52\R6B C002 _FS_MEDITERR_NA_RED_CID52.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 3620 Will flash 181 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed can't get packet start. FS startup failed,error is 00 [ 0] loader fs startup failed, that is fatal Elapsed: 755 secs. |
09-03-2009, 08:16 | #2 (permalink) |
Member: 889564 Status: Offline Thanks Meter: 336 | Here is the phone info v0.915040/UNI CARD SERIAL: ******** Loaded 51 flash descriptors SIGNED MODE (USING SERVER) CFG:10001000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:357******** CERT:N/A FLASH CID:52 COLOR:RED Model (from GDFS):W610i Brand:Generic MAPP CXC article: R8BA024 prgCXC1250747_GENERIC_NA MAPP CXC version: R8BA024 Language Package: RUSSIA CDA article: CDA102295/1 CDA version: R2A Default article: cxc1250755 Default version: R8BA024 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 10 secs. |
T630 Strange Flashing Problem | celluniversal | Old Ericsson Phones & Sony Phones | 1 | 02-08-2007 07:57 |
6030 strange flashing problem | celluniversal | Nokia Digital Core Technology 4 ( DCT-4 ) | 10 | 01-13-2007 22:23 |
Nokia 2300 strange flash problem | murtaza_nns | Nokia Hardware & Hardware Repair | 5 | 10-31-2006 05:57 |
Strange flashing problem | pnganga | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 05-31-2006 07:36 |
GD 93 strange flash problem | NBG | Panasonic | 0 | 04-11-2002 23:51 |
