02-24-2010, 07:28 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: punjab
Member: 271008 Status: Offline Thanks Meter: 280 | se w850 after flash still on white light blinking plz help me CARD SERIAL 00065712 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 FLASH ID:2019 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35240101765868 CERT:RED FLASH CID:52 COLOR:RED Model (from GDFS):W850i Brand:Generic Trade UK MAPP CXC article: R1KG001 prgCXC1250202_ORANGE_CY MAPP CXC version: R1KG001 Language Package: ORANGE_GEN CDA article: CDA102677/95 CDA version: R1A Default article: cxc1250489 Default version: R1KG001 PROVIDER: MULTIPLE Network LOCKED RESTORATION FILE NOT PRESENT "R1KG001_CXC1250202_ORANGE_CY" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED SECURITY UNITS BACKUP CREATED. Elapsed: 52 secs. SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35240101765868 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:2019 writing "D:\SETOOL\new files\w850i cid49red\cid52 red w850\R1ED001_1250200_GENERIC_CY.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9100 Will flash 455 blocks... writing "D:\SETOOL\new files\w850i cid49red\cid52 red w850\R1ED001_FS_S_ASIA_LEVAN_CY_RED_CID52.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 4740 Will flash 237 blocks... LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 433 secs. how can i solve this problem |
02-24-2010, 07:34 | #2 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: IT POINT Ankleshwar
Member: 756719 Status: Offline Thanks Meter: 80 | Quote:
The Following 2 Users Say Thank You to jasperali For This Useful Post: |
02-24-2010, 07:40 | #4 (permalink) | |
Freak Poster Join Date: Nov 2007
Member: 640135 Status: Offline Thanks Meter: 40 | W850 Solution Quote:
Bro, do what this man said thats true you can can flash as many times as you want until you do that is when your problem is solved. its hardware problem don't waste your time by flashing again. Thanks bro. | |
02-24-2010, 07:52 | #6 (permalink) |
Freak Poster Join Date: May 2008
Member: 772941 Status: Offline Sonork: 112 Thanks Meter: 349 | Brother first change your flex cable 2nd try to change upper circuit bord 100% tested solution. |
The Following User Says Thank You to raseelmsm For This Useful Post: |
1661 after flash still on white light | neeraj1st | MT-BOX | 3 | 12-29-2009 14:11 |
k 810 after flash still in white blinking help log here | Master Software | SETool2 | 1 | 12-02-2009 09:55 |
w830i after flash stay on white light plz help | neeraj1st | SETool2 | 0 | 02-17-2009 10:14 |
zv10 flashing complet but set blinking plz help me | ..:::Gsm india:::.. | UST Pro II | 0 | 10-07-2007 05:59 |
X700 white light only plz help me | amanhalwara | Samsung Hardware Repair | 1 | 08-15-2007 06:41 |
