10-20-2008, 06:06 | #3 (permalink) |
Freak Poster Join Date: Apr 2007 Location: philippines
Member: 490719 Status: Offline Thanks Meter: 4 | v0.914041/UNI CARD SERIAL: zianian Loaded 51 flash descriptors SIGNED MODE (USING SERVER). SERVER CREDITS LEFT/USED: 30/0 CARD COUNTERS: FLASH 469, UNLOCK 311 Elapsed: 6 secs. SIGNED MODE (USING SERVER). PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM104, SLAVE on COM105 Open COM port OK ChipID:7100,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 OTP LOCKED:1 CID:52 PAF:1 IMEI:357033zianian CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 Flash ID check:2010 Flash props sent ok LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E Executing CSCA-based unlock. loader startup: executed loader GDFS startup: executed loader unlock: executed Asking for EROM signature... Waiting for calculation process... RESPONSE: "QUEUE FULL, CHECK BACK LATER" (1) Error "QUEUE FULL, CHECK BACK LATER" during signature calculation signature calculation not done,err: 144 Elapsed: 37 secs. |
10-20-2008, 06:39 | #4 (permalink) | |
Freak Poster Join Date: Aug 2007
Member: 577243 Status: Offline Thanks Meter: 0 | Quote:
As Stated above QUEUE FULL, CHECK BACK LATER which means the queue is full not sertver problem !!!! | |
10-20-2008, 23:34 | #7 (permalink) |
Freak Poster Join Date: Apr 2008 Location: TO CLOSE 2 YOU!!!
Member: 756103 Status: Offline Thanks Meter: 52 | yes the codes for the format must be calculated and the server isnt down if the server was down u would get a server message this is just that the calculation process is very busy and u will need 2 try later 2 get ur code into process |
www.bb-server.eu BB Server is Down | rajinder1978 | FuriousGold | 1 | 09-10-2009 14:44 |
server is down down down..................... | foufou34 | HWK | 0 | 02-04-2009 10:50 |
server is down for maintenance ::: server ok now ::: | The_Gorr | PolarBox 3 | 1 | 01-04-2009 19:21 |
