Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 11-01-2010, 23:44   #1 (permalink)
romell's Avatar
Member: 252707
server error:remote dongle not available
i cant unlock via server check log please this problem since 1 week
settings:
signed mode
perform full unlock
SATIO:
RUNNING v 1.09/UNI
CARD SERIAL 00013648
USBFLASH DRIVER VERSION 02.02.00.05
SIGNED MODE (USING SERVER)
CFG:101000000000
SERVER CREDITS LEFT/USED: 6/24
CARD COUNTERS: FLASH 8470, UNLOCK 6267
Elapsed: 2 secs.
CFG:100010000000
PLEASE ATTACH TURNED OFF PHONE NOW
PRESS AND HOLD "GREEN" BUTTON...
EROM "R6A032" AID: 0001
SOFTWARE AID: 0001
SIMLOCK STATE: "NOT TAMPERED"
LOADER AID: 0004
FLASH ID: "00EC/0040"
LOADER VERSION: "R4A044"
PHONE IMEI:35681103******
Checking for signature...
Waiting for calculation process...
RESPONSE: "SUCCESS" [1048]
Unlock FAILED
Elapsed: 28 secs.
AINO:
CFG:100010000000
ChipID:F002,EMP protocol:0401
PHONE STATE: "RETAIL"
FLASH CID: 0080
OTP LOCKED:1 CID:80 PAF:1 IMEI:35681603****** CERT:RED
LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096
LDR CAPS:SYSTEM FLASH SIGNATURE AUTH
LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096
LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA
Executing CSCA-based unlock.
signature found, skipping calculation
Unlock FAILED
Elapsed: 20 secs.
AINO: after try unlock this aino 5 locks closed now i need unlock this devices customer want killme
i need answer by support team setool.
Old 11-02-2010, 03:50   #2 (permalink)
Member: 760139
PHONE IMEI:01228800024564
signature calculation not done,err: 144
Unlock FAILED
also same problem .... is server not available?
Old 11-02-2010, 09:34   #3 (permalink)
Member: 131242
No working 10 days
They sey that server no working on hollideys,sunday,meyby now go to lunch or get some girls
Old 11-02-2010, 10:11   #4 (permalink)
Member: 228703
same problem
CFG:100010000000
PRESS AND HOLD "C" BUTTON...
EROM "R7A024" AID: 0001
SOFTWARE AID: 0001
LOADER AID: 0004
FLASH ID: "00EC/220C"
LOADER VERSION: "R3B004"
PHONE IMEI:35902403382642
Unlock FAILED
Elapsed: 18 secs.
please tell us when the server working
Old 11-02-2010, 18:12   #5 (permalink)
romell's Avatar
Member: 252707
please read again before post read
say 1 week not avalaible 1 week
Old 11-02-2010, 21:59   #6 (permalink)
:Aishur:'s Avatar
Member: 1315677
Originally Posted by the laser
user should check before doing unlock of u1,u5,u8
1. s1 auth server status
2. phone AID
if phone aid=1,2,3 - you can do unlock,
if phone aid 4 and s1 auth offline - you can not do unlock
U5i unlock server?
The Following 4 Users Say Thank You to :Aishur: For This Useful Post:
Old 11-03-2010, 01:23   #7 (permalink)
medie's Avatar
Member: 181277
Originally Posted by :Aishur: View Post
SAME SAME
RUNNING v 1.09/UNI
CARD SERIAL 00058077
PLEASE UPGRADE USBFLASH DRIVER 01.01.00.0C
CFG:100010000000
llbug:COM133 open error: "The requested resource is in use"
FAILED TO SETUP PHONE
Unlock FAILED
Elapsed: 0 secs.
CFG:100010000000
PRESS "POWER ON" BUTTON SHORTLY...
SOFTWARE AID: 0001
LOADER AID: 0004
PHONE IMEI:01228800163800
Unlock FAILED
Elapsed: 30 secs.
Old 11-03-2010, 01:32   #8 (permalink)
romell's Avatar
Member: 252707
Tks for answer but not clear when server work again?
Or where see to server work or not?
Tks i need other tool or service server to unlock this devices tks
Old 11-03-2010, 02:04   #9 (permalink)
yassinek85's Avatar
Member: 938547
Sonork: 100.1591926
U10i unlock done today
02/11/2010 17:12:37 RUNNING v 1.09/UNI
02/11/2010 17:12:37 CARD SERIAL xxxxxxxxxxx
02/11/2010 17:12:37 USBFLASH DRIVER VERSION 02.02.00.05
02/11/2010 17:13:27 SIGNED MODE (USING SERVER)
02/11/2010 17:13:27 CFG:100011000000
02/11/2010 17:13:30 ChipID:F002,EMP protocol:0401
02/11/2010 17:13:30 BOOTROM MODE DETECTED
02/11/2010 17:13:30 OTP DBG: [1,81,1,01229100606200]
02/11/2010 17:13:31 OTP LOCKED:1 CID:81 PAF:1 IMEI:012291006062xx CERT:RED
02/11/2010 17:13:34 LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096
02/11/2010 17:13:34 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH
02/11/2010 17:13:35 LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096
02/11/2010 17:13:35 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA
02/11/2010 17:13:35 Executing CSCA-based unlock.
02/11/2010 17:13:35 Checking for signature...
02/11/2010 17:13:35 signature found, skipping calculation
02/11/2010 17:13:35 Backup security data...
02/11/2010 17:13:36 Erasing locks...
02/11/2010 17:13:37
02/11/2010 17:13:37 DISCONNECT PHONE NOW
02/11/2010 17:13:37 REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN
02/11/2010 17:13:37 INSTALL PHONE MODEM DRIVERS IF NEEDED
02/11/2010 17:13:37
02/11/2010 17:13:37 SEARCHING FOR PHONE, "STOP" TO ABORT
02/11/2010 17:16:07 PHONE FOUND AT COM12
02/11/2010 17:16:15 PHONE READY TO PROCEED.
02/11/2010 17:16:24 GOT SEED:00C1358C
02/11/2010 17:16:26 ACTIVATION COMPLETED. USERCODE RESET TO "0000"
02/11/2010 17:16:28 Unlock DONE
02/11/2010 17:16:28 Elapsed: 180 secs.
Old 11-03-2010, 02:05   #10 (permalink)
yassinek85's Avatar
Member: 938547
Sonork: 100.1591926
U5i unlock done today
02/11/2010 17:25:24 SIGNED MODE (USING SERVER)
02/11/2010 17:25:24 CFG:100011000000
02/11/2010 17:25:26 SERVER CREDITS LEFT/USED: 4/26
02/11/2010 17:25:27 CARD COUNTERS: FLASH 45, UNLOCK 11
02/11/2010 17:25:27 Elapsed: 2 secs.
02/11/2010 17:26:34 SIGNED MODE (USING SERVER)
02/11/2010 17:26:34 CFG:100011000000
02/11/2010 17:26:35 PLEASE ATTACH TURNED OFF PHONE NOW
02/11/2010 17:26:35 PRESS AND HOLD "GREEN" BUTTON...
02/11/2010 17:27:00
02/11/2010 17:27:00 EROM "R8A017" AID: 0001
02/11/2010 17:27:00 SOFTWARE AID: 0001
02/11/2010 17:27:00 SIMLOCK STATE: "NOT TAMPERED"
02/11/2010 17:27:00 LOADER AID: 0002
02/11/2010 17:27:09 FLASH ID: "00EC/0040"
02/11/2010 17:27:09 LOADER VERSION: "R4A012"
02/11/2010 17:27:09
02/11/2010 17:27:09 PHONE IMEI:012332005216xx
02/11/2010 17:27:11 Checking for signature...
02/11/2010 17:27:11 Waiting for calculation process...
02/11/2010 17:27:12 RESPONSE: "SUCCESS" [1048]
02/11/2010 17:27:12 GOT SEED:EBCA7C6F802C3000B05B7FA6
02/11/2010 17:27:13 OMAP P96 AUTH PASSED
02/11/2010 17:27:13 GOT SEED:B129C5186F802C3000B05B7F
02/11/2010 17:27:13 CCPU P96 AUTH PASSED
02/11/2010 17:27:16 Unlock DONE
02/11/2010 17:27:16 Elapsed: 41 secs.
Old 11-03-2010, 02:08   #11 (permalink)
yassinek85's Avatar
Member: 938547
Sonork: 100.1591926
A1/A2 signature server,A1/A2/S1 reset station,A1 csca station status: ONLINE
So use csca unlock, see below
For A2 phones
1 install modem drivers (setool\drivers\modem_drivers)
2 settings:
[x] signed mode
[x] perform full unlock instead of usercode reset
[x] disable flash mode activation for A2
3 unlock/repair
That is all
big thanks to Mr Aishur
B.R Mr Yassine
Old 11-03-2010, 07:40   #12 (permalink)
romell's Avatar
Member: 252707
This thread is about aid 0004 see and read firts post and see Phone aid 0004
and other post same phone aid 0004 read post to aishur, but i try tomorrow device Aino but satio phone aid 0004 i try and post results tks bro
Old 11-03-2010, 07:53   #13 (permalink)
sidah-gsm's Avatar
Member: 600493
Sonork: 0550106737
pls i have probleme
i try to unlock satio but setool teck credit and not unock my phone
log
RUNNING v 1.09/UNI
CARD SERIAL 04444991
PLEASE UPGRADE USBFLASH DRIVER 02.02.00.00
CFG:100010000000
SOFTWARE AID: 0001
LOADER AID: 0004
PHONE IMEI:01225100176870
Unlock FAILED
Elapsed: 40 secs.
CFG:100010000000
SERVER CREDITS LEFT/USED: 27/3
CARD COUNTERS: FLASH 1039, UNLOCK 556
Elapsed: 2 secs.
pls help me !!!!!
Old 11-03-2010, 10:12   #14 (permalink)
adelgsm's Avatar
Member: 476287
Sonork: 100.1587961
02/11/2010 17:27:00
02/11/2010 17:27:09
LOADER AID: 0002 (Unlock DONE) server ONLINE
LOADER AID: 0004 (Unlock FAILED) server OFFLINE
Old 11-03-2010, 10:18   #15 (permalink)
:Aishur:'s Avatar
Member: 1315677
Originally Posted by sidah-gsm View Post
pls i have probleme
log
RUNNING v 1.09/UNI
CFG:100010000000
SOFTWARE AID: 0001
LOADER AID: 0004
Unlock FAILED
Elapsed: 40 secs.
CFG:100010000000
Elapsed: 2 secs.
pls help me !!!!!
klek boubi
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
winlock wintesla m2bus do not work Bigbrothers2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 01-26-2000 13:31
dongle.exe Aldrin Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 01-22-2000 03:40
I will finished Dongle for Nokia WinTesla MyKy Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-14-1999 22:47
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-28-1999 14:56
Page generated in 0.74277 seconds with 11 queries
