06-18-2011, 15:33 | #61 (permalink) |
No Life Poster Join Date: Apr 2010 Location: U.K. / INDIA
Member: 1283682 Status: Offline Thanks Meter: 304 | ELM unlock done ...... S1 v1 4 credits ( OFFLINE ) S1 v2 10 credits ( OFFLINE ) S1 OPEN 6 credits ( AID 004 OFFLINE ) A1 phones 6 credits A2 phones 6 credits ( DO NOT USE FOR J108 ) by codes 4 credits current setool2 version: 1.107 Elapsed: 10 secs. SIGNED MODE (USING SERVER) CFG:100011000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0080 OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403318786 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1038] Backup security data... Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM35 PHONE READY TO PROCEED. GOT SEED:00438E49 ACTIVATION COMPLETED. USERCODE RESET TO "0000" Unlock DONE Elapsed: 152 secs. |
The Following User Says Thank You to C Singh For This Useful Post: |
06-19-2011, 12:19 | #64 (permalink) | |
Member: 1283682 Status: Offline Thanks Meter: 304 | Quote:
Earlier when u unlocked ur semc A2 based phones or semc based server is not taking credits (because server is offline so kind of a discount from setool ) ... but from yesterday its again start taking credits and still server is offline ........ | |
06-19-2011, 19:22 | #65 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: BEST COUNTRY
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | Quote:
06-20-2011, 09:55 | #66 (permalink) | |
J10_ELM J20-HAZEL W20_ZYLO X5_XPERIA_PURENESS these r A2 based phones who need credits to unlock ..... | |
06-20-2011, 11:27 | #69 (permalink) |
Member: 1283682 Status: Offline Thanks Meter: 304 | |
06-20-2011, 11:29 | #70 (permalink) | |
06-21-2011, 13:25 | #72 (permalink) |
No Life Poster Join Date: Sep 2001 Location: United Kingdom Age: 48
Member: 6524 Status: Offline Thanks Meter: 246 | credit not deducted, but 4 locks it did not deducted credits but activation problem now w20i cid 81 BOOTROM MODE DETECTED OTP DBG: [1,81,1,01253000xxxxxx] OTP LOCKED:1 CID:81 PAF:1 IMEI:01253000xxxxxxx CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation Backup security data... Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM16 Phone not responds to AT #1, retry 1 Phone not responds to AT #1, retry 2 Phone not responds to AT #1, retry 3 Phone not responds to AT #1, retry 4 Phone not responds to AT #1, retry 5 CSCA UNLOCK FAILED driver allready installed but geting error why? |
06-21-2011, 14:34 | #73 (permalink) |
No Life Poster Join Date: Apr 2006 Location: .:Islam:.:Peace:.Pakistan:. Age: 48
Member: 266874 Status: Offline Sonork: 100.1581444 Thanks Meter: 97 | RUNNING v 1.107/UNI SIGNED MODE (USING SERVER) CFG:100011000000 SERVER CREDITS LEFT/USED: 10/20 CARD COUNTERS: FLASH 27, UNLOCK 36 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01238200619639 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1038] Backup security data... Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PROCEDURE WAS STOPPED BY USER Can't find attached phone with IMEI 01238200619639 CSCA UNLOCK FAILED Unlock FAILED Elapsed: 998 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 llbug:blk write fail.fatal [A2_loader] can't send NET packet [A2_loader] bad result [01/11] can't load APPLICATION CPU preloader Can't load ID loader ! Elapsed: 19 secs. SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 4/26 CARD COUNTERS: FLASH 27, UNLOCK 36 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,01238200619639] OTP LOCKED:1 CID:81 PAF:1 IMEI:01238200619639 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 Model (from GDFS):W20i MAPP CXC article: R7CA061 prg1234-6570_ORANGE_TO MAPP CXC version: R7CA061 Language Package: ORANGE-SIGN CDA article: 1236-9993 CDA version: R12A Default article: 1232-9909 Default version: R7CA061 PROVIDER: 000-00 SIMLOCKS NOT DETECTED Elapsed: 8 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01238200619639 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation server error:remote dongle not available Unlock FAILED Elapsed: 11 secs. SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 4/26 CARD COUNTERS: FLASH 27, UNLOCK 36 Elapsed: 2 secs. my mistake or what I Lost my 6 Credits |
06-21-2011, 14:57 | #74 (permalink) |
Member: 6524 Status: Offline Thanks Meter: 246 | w20i free!! no need credit cid 81 done today!! After erase lock did not deducted credit(6 log) from account.but not connecting for activation " phone not found" then i reflash with R7CAO58 then unlock again..then successfully unlock with out 6 credit.. |
06-22-2011, 15:10 | #75 (permalink) | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Tdb4 emulator wanted | Fk2 | Wanted Products | 0 | 06-01-1999 09:45 |
