11-04-2009, 15:32 | #1 (permalink) |
Insane Poster Join Date: Jul 2007
Member: 552982 Status: Offline Thanks Meter: 22 | w205 unlock done SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:10100010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "C" BUTTON... EROM "R5A038" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0002 FLASH ID: "0089/8904" LOADER VERSION: "R3A011" PHONE IMEI:3548960.....09 GOT SEED:47DA1BF98401B019C2007FCC P96 AUTH PASSED Searching... SIMLOCK CHECK FOUND Writing... Unlock DONE Elapsed: 34 secs. 2. SIGNED MODE (USING SERVER) CFG:10100010000000 SERVER CREDITS LEFT/USED: 29/1 CARD COUNTERS: FLASH 252, UNLOCK 34 Elapsed: 2 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:10100010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "C" BUTTON... EROM "R5A038" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0002 FLASH ID: "0089/8904" LOADER VERSION: "R3A011" PHONE IMEI:354896.....044 GOT SEED:55FF1E9E8202001EC20078AF P96 AUTH PASSED Searching... SIMLOCK CHECK FOUND Writing... Unlock DONE Elapsed: 19 secs. |
The Following 5 Users Say Thank You to maxtele For This Useful Post: |
11-04-2009, 19:29 | #2 (permalink) |
Junior Member Join Date: Jan 2006 Location: guadeloupe
Member: 220317 Status: Offline Thanks Meter: 2 | hello! you unlocked w205 with usb cable? if yes you hold "c"button" or 2 and 5? I tryed so many times with com port I have this, when i enable only Signed mode SIGNED MODE (USING SERVER) CFG:100000000000 4 PLEASE ATTACH TURNED OFF PHONE NOW 4 PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" AID: 0001 :07 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0002 FLASH ID: "0089/8904" LOADER VERSION: "R3A011" PHONE IMEI:357838030xxxxx USERLOCK RESET TO "0000" TOTAL CALL TIME RESET Elapsed: 16 secs. I have this message when i enable "signed mode" and "perform full unlock" 4/11/2009 14:27:08 PLEASE ATTACH TURNED OFF PHONE NOW 04/11/2009 14:27:08 PRESS "POWER ON" BUTTON SHORTLY... 04/11/2009 14:27:11 04/11/2009 14:27:11 EROM "R5A038" AID: 0001 04/11/2009 14:27:11 SOFTWARE AID: 0001 04/11/2009 14:27:11 SIMLOCK STATE: "NOT_TAMPERED" 04/11/2009 14:27:11 LOADER AID: 0002 04/11/2009 14:27:24 FLASH ID: "0089/8904" 04/11/2009 14:27:24 LOADER VERSION: "R3A011" 04/11/2009 14:27:24 04/11/2009 14:27:24 PHONE IMEI:357838030xxxxx 04/11/2009 14:27:24 MINOR ERROR "MISC_ERROR (No_such_unit)" IN "MISC_CLASS" 04/11/2009 14:27:24 Checking for signature... 04/11/2009 14:27:25 Waiting for calculation process... 04/11/2009 14:27:26 remote dongle not available 04/11/2009 14:27:26 signature calculation not done,err: 144 04/11/2009 14:27:27 Elapsed: 21 secs. Thank you if you can help me |
11-05-2009, 00:36 | #5 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Donkey world
Member: 712832 Status: Offline Thanks Meter: 290 | @dinou for s1 use usb and hold c @soulja88 1 log for patch unlock ==> in setting tab chek signed mode and alternative bypass 2 logs for full unlock ==> in setting tab chek signed mode and perform full unlock |
The Following User Says Thank You to fypoi For This Useful Post: |
11-23-2009, 13:41 | #10 (permalink) |
No Life Poster Join Date: Nov 2005 Location: work Age: 11
Member: 195993 Status: Offline Sonork: 100.1653595 Thanks Meter: 128 | check "signed mode" check "enable preloader" hit "unlock/repair consumes 1 credit regards THE KOP... |
The Following User Says Thank You to mint centre For This Useful Post: |
03-04-2010, 13:11 | #13 (permalink) |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | W205 UNLOCKED SUCCESSFULL NEW SECURITY WITH 1 CREDIT LOG: RUNNING v0.915062/UNI CARD SERIAL 000XXXXX USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:110000000000 SERVER CREDITS LEFT/USED: 26/4 CARD COUNTERS: FLASH 544, UNLOCK 280 Elapsed: 3 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0002 FLASH ID: "0089/8904" LOADER VERSION: "R3A011" PHONE IMEI:35489603XXXXXX GOT SEED:33FAC5EE8100B02FC20078B0 P96 AUTH PASSED Searching... SIMLOCK CHECK FOUND Writing... Unlock DONE Elapsed: 35 secs. SIGNED MODE (USING SERVER) CFG:110000000000 SERVER CREDITS LEFT/USED: 25/5 CARD COUNTERS: FLASH 544, UNLOCK 280 Elapsed: 3 secs. MIANLINKS |
The Following User Says Thank You to mianjabbar For This Useful Post: |
05-12-2010, 13:30 | #15 (permalink) |
Crazy Poster Join Date: Mar 2010
Member: 1250956 Status: Offline Sonork: 7777 Thanks Meter: 21 | If you need unlock code means you can get the unlock code here Wicked Unlock.com- Unlock Your Phone It provides unlock code and instructions...By using this you can unlock successfully... |
W205 unlock done with setool | ..::proudcracker::.. | SETool2 | 10 | 06-09-2011 06:13 |
w205 unlock done with 1 credit log here | Master Software | SETool2 | 0 | 02-18-2010 14:13 |
w205 unlock done | nadim electro | SETool2 | 0 | 01-30-2010 13:20 |
w205 unlock done | LABOSSEF | Cruiser Suite | 2 | 01-16-2010 13:51 |
w205 unlock done | ^^^RAVI SOOD^^^ | SETool2 | 1 | 01-07-2010 09:01 |
