10-15-2007, 23:51 | #18 (permalink) |
Freak Poster Join Date: Mar 2007 Location: Planet Earth
Member: 473763 Status: Offline Thanks Meter: 56 | I read the instructions for unlocking cid52. I got to know that it cost 10 credits. So, is it like .. 1. Normal server can be used for this unlocking. 2. Phone MUST be connected with the SE tool dongle for this whole period ( max 72 hrs ) 3. SE Tool program should not be closed for this whole period. 4. The computer should not be turned off. 5. Internet connection should be always in connected mode. Please clarify above queries. |
10-16-2007, 02:56 | #20 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Salvador - Bahia - Brazil Age: 48
Member: 172567 Status: Offline Thanks Meter: 90 | 1) you use normal server 2) No, you just send the solicitation, when the calculation is aveilable just reconect and unlock. 3) Of course you can shout it down. Process is on server, not in your computer. 4) Same as 3 5) Same as 3. When you make the solitication, and to unlock, you'll need it, but not in the mean time. |
10-16-2007, 06:24 | #23 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Pakistan
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | unlocking in 2 steps 1- When press unlock button your signature calculation in server queue and that take no long time and take 6 logs 2- now here you need to press unlock button after evey 30 or 60 minutes coz no one now when your calculation will be completed, when completed then folllow the setool and you will get unlock phone within 20 minutes to 72 hours, it take 4 logs. |
10-16-2007, 14:42 | #26 (permalink) |
No Life Poster Join Date: Jul 2004 Location: YODAFON
Member: 75392 Status: Offline Sonork: 100.81199 Thanks Meter: 136 | K800 CID52, unlocked in less than 30 minutes Code: SERVER SUPPORT ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:3573150xxxxxxxxx CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok CSloader version: 070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009 Executing CSCA-based unlock. Asking for EROM signature... Waiting for calculation process... signature response "35731501866146 ADDED TO QUEUE,CHECK BACK LATER" (1) Error "35731501866146 ADDED TO QUEUE,CHECK BACK LATER" during signature calculation signoff ok signature calculation not done,err: 144 Elapsed:11 secs. SERVER SUPPORT ENABLED. SERVER CREDITS LEFT/USED: 10/20 CARD COUNTERS: FLASH 585, UNLOCK 1047 Elapsed:3 secs. SERVER SUPPORT ENABLED. SERVER CREDITS LEFT/USED: 10/20 CARD COUNTERS: FLASH 585, UNLOCK 1047 Elapsed:3 secs. SERVER SUPPORT ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35731501xxxxxxxxx CERT:RED FLASH CID:52 COLOR:RED MAPP CXC article: R1JC002 prgCXC1250212_ORANGE_WI MAPP CXC version: R1JC002 Language Package:ORANGE_GEN CDA article: CDA102511/108 CDA version: R4A Default article: cxc1250490 Default version: R1JC002 Network LOCKED Operator: 226-10 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed:2 secs. SERVER SUPPORT ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35731501xxxxxxxxxx CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok CSloader version: 070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009 Executing CSCA-based unlock. Asking for EROM signature... Waiting for calculation process... signature response "SUCCESS" (1038) signoff ok loader startup: executed loader GDFS startup: executed loader unlock: executed Backup security data... Erasing locks... DISCONNECT PHONE, FULLY TURN IT ON AND ATTACH AGAIN. BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM34 Open COM port OK phone ready to proceed. Connecting to server seed is:0055066E Phone succefully unlocked. USERCODE reset to "0000" Elapsed:112 secs. Last edited by huzsolt; 10-16-2007 at 14:51. |
10-16-2007, 15:42 | #30 (permalink) |
Cheater -Don't Deal with him- Join Date: Apr 2006 Location: Spain
Member: 260694 Status: Offline Thanks Meter: 16 | where i can find v0.913902?? hi i have setool3 and olso acess to the oficiel support , but i can't find v0.913902!! where can i download it?? |
Service db2010/db2020/pnx5230 cid52/cid53 using new setool2 (>=v0.914029) | Amir-SkillZ | Sony Ericsson | 68 | 12-31-2008 12:11 |
Seking Unlocker no need box, PDA PNX5230 DB3150 DB2020 DB2012 Permanent Unlock ! | ..::GsmHelp::.. | Service Products News & Updates | 0 | 05-24-2008 08:03 |
HOT HOT HOT VIDEO HOW TO FULL Permanent unlock CID52/CID53/PNX5230 by SETOOL | salim786 | SETool2 | 5 | 12-31-2007 13:13 |
