02-10-2011, 14:31 | #1 (permalink) |
Registered User Join Date: Nov 2010 Location: FRANCE
Member: 1454779 Status: Offline Thanks Meter: 2 | setool help me |
02-10-2011, 14:46 | #4 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Romania
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | If you want you can connect to the box too but have to select box com port in left site down of software and use cable arrived with the box. For unlock is better to use USB cable DCU-60. First make identify of phone to see if you have rest file. If not you have to flash phone before unlock with use server and alternative security bypas enabled. For unlock select USB on software and select use server and alternative secutity bypas enable and press unlock. BR. |
02-10-2011, 14:48 | #5 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Punjab , INDIA
Member: 153805 Status: Offline Thanks Meter: 325 | Here is simple guide for Setool.It is not my work just copy & paste UNLOCKING OF A1-BASED PDA PHONES if you want to UNLOCK NEW SECURITY phone - check "use server" and enter your login/password. please check FAQ article about credit consumptions for your phone. press unlock button and insert cable to phone, while holding appropriate key on phone. follow program directions. if you want to UNLOCK OLD SECURITY phone - UNCHECK "use server". BE SURE you have latest REST files. now, you need install drivers for flashing. for that, poweron smartphone in fw update mode. - for p990/m600 press and hold "@" on TURNED OFF phone, then attach dcu60. - for w950 press and hold "C" on TURNED OFF phone, then attach dcu60. windows will ask you for a drivers. drivers in %setool2 dist%\drivers\Smartphone_Drivers now, when all preparations finished - press unlock button and insert cable to phone,while holding appropriate key on phone. follow program directions. CHARGE: qualcomm-based S1 phones (ANDROID smartphones) full unlock via server - x credits required ( unlock disabled for public ) E10 x10MINI CHIPSET QSD7227 E15 XPERIA X8 CHIPSET QSD7227 G700 CHIPSET DB2001 G900 CHIPSET DB2001 M1 ASPEN CHIPSET QSD7227 M600 CHIPSET DB2001 P990 CHIPSET DB2001 P1 CHIPSET DB2001 U1_SATIO CHIPSET OMAP3430 U5_VIVAZ CHIPSET OMAP3430 U8_VIVAZ PRO CHIPSET OMAP3430 U20_X10 MINI PRO CHIPSET QSD7227 W950 CHIPSET DB2001 W960 CHIPSET DB2001 X10 MINI PRO CHIPSET QSD8250 SEMC A1 CID 16,29,36,37 1. select com/ufs as interface 2. go to semc tab 3. select correct model 4. on settings tab, uncheck all settings. 5. back on semc tab 6. press unlock button that CID is obsolete and upgrade to CID 49 via writing corresponing EROM recommended. you can not use USB as interface for such phones with CID. recovery operation supported for such phones, damaged EROM can be restored without problems. no any special files required for such phones. CID 49 standalone method 1. select com/ufs/usb as interface 2. go to semc tab 3. select correct model 4. on settings tab, uncheck all settings. 5. back on semc tab 6. press unlock button you can not use USB as interface, if SCRC damaged ( IMEI mismatch in IDENTIFY output ) restoration files required for that method. that files could be downloaded from support area or created automatically : place main part of unsupported firmware in firmware area,press identify and attach phone with unsupported firmware. CSCA method 1. select com/ufs/usb as interface 2. go to semc tab 3. select correct model 4. on settings tab, check "signed mode" 5. back on semc tab 6. press unlock button that is not recommended method for unlocking such phones, slow and useless. you can not repair damaged SCRC via that method. recovery operation not supported for such phones, reset operation should be used in order to repair damaged EROM. you can repair damaged GDFS, damaged SCRC standalone for such phones. CID 50,51,52,53 standalone patch unlock method via alternative security bypass 1. select com/ufs/usb as interface 2. go to semc tab 3. select correct model 4. on settings tab, check "signed mode","alternative security bypass", "preloader security bypass" 5. back on semc tab 6. press unlock button you can not use that method , if SCRC damaged ( IMEI mismatch in IDENTIFY output ) restoration files required for that method. bypass packages required for that method. please read FAQ post about alternative security bypass. server-based patch unlock method via alternative security bypass ( can be used only for CID 50,51 ) 1. select com/ufs/usb as interface 2. go to semc tab 3. select correct model 4. on settings tab, check "signed mode","alternative security bypass" 5. back on semc tab 6. press unlock button you can not use that method , if SCRC damaged ( IMEI mismatch in IDENTIFY output ) that is obsolete method and left for historic reasons, it will be completely removed in nearest versions. restoration files required for that method. CSCA method 1. select com/ufs/usb as interface 2. go to semc tab 3. select correct model 4. on settings tab, check "signed mode" 5. back on semc tab 6. press unlock button that is recommended method for unlocking such phones. recovery operation not supported for such phones, server-based reset operation should be used in order to repair damaged EROM,damaged GDFS, damaged SCRC. CHARGE: db2000 cid17/cid41/cid42/cid54 (lg3g) db2000 cid24 (old sharp 3g) full unlock is free patch unlock is free db2000 cid16 full unlock is free patch unlock is free full unlock via server - 1 credits db2000/db2010 cid29 full unlock is free patch unlock is free full unlock via server - 1 credits db2000/db2010 cid36 full unlock is free patch unlock is free full unlock via server - 1 credits db2000/db2010 cid49 full unlock is free patch unlock is free reset mode (repair erom) - 1 credits full unlock via server - 1 credits db2020 cid49 patch unlock standalone - free (required setool2 >=v0.914033) reset mode (repair erom) - 1 credits Full unlock 6+0=6 credits required ( please use reset mode ) db2010 cid50 patch unlock standalone - free (required setool2 >=v0.914033) reset mode (repair erom) - 1 credits full unlock - 1 credits db2010/db2020/pnx5230 cid51 patch unlock standalone - free (required setool2 >=v0.914033) reset mode (not applicate for pnx5230) (repair erom) - 1 credits Full unlock 6+0=6 credits required ( please use reset mode ) db2020 cid52 patch unlock is free reset mode (repair erom) - 1 credits Full unlock 6+0=6 credits required ( please use reset mode ) db2010/pnx5230 cid52 patch unlock is free (required setool2 >=v0.914029) reset mode (not applicate for pnx5230) (repair erom) - 1 credits Full unlock 6+0=6 credits required ( please use reset mode ) db2000 cid53 reset mode - 1 credits Full unlock 6+0=6 credits required ( please use reset mode ) db2010/db2020/pnx5230 cid53 patch unlock is free (required setool2 >=v0.914029) reset mode (not applicate for pnx5230) (repair erom) - 1 credits Full unlock 6+0=6 credits required ( please use reset mode ) J300 CHIPSET DB2010 K300 CHIPSET DB2010 K310 CHIPSET DB2010 K320 CHIPSET DB2012 K500/F500/K508 CHIPSET DB2010 K510 CHIPSET DB2010 K530 CHIPSET DB2020 K550 CHIPSET DB2020 K600/V600/K608 CHIPSET DB2000 K610/K618/V630 CHIPSET DB2020 K700 CHIPSET DB2010 K750/D750 CHIPSET DB2010 K770 CHIPSET DB2020 K790 CHIPSET DB2020 K800 CHIPSET DB2020 K810/K818 CHIPSET DB2020 S500 CHIPSET DB2020 S700 CHIPSET DB2010 S710 CHIPSET DB2010 T650 CHIPSET DB2020 W200 CHIPSET DB2012 W300 CHIPSET DB2010 W350 CHIPSET PNX5230 W380 CHIPSET PNX5230 W550/W600 CHIPSET DB2010 W580 CHIPSET DB2020 W610 CHIPSET DB2020 W660 CHIPSET DB2020 W700 CHIPSET DB2010 W710 CHIPSET DB2020 W800 CHIPSET DB2010 W810 CHIPSET DB2010 W830 CHIPSET DB2020 W850 CHIPSET DB2020 W880/W888 CHIPSET DB2020 W900 CHIPSET DB2000 Z310 CHIPSET PNX5230 Z500 CHIPSET DB2010 Z520/Z525 CHIPSET DB2010 Z530 CHIPSET DB2010 Z550 CHIPSET DB2010 Z555 CHIPSET PNX5230 Z610 CHIPSET DB2020 Z710 CHIPSET DB2020 Z800/V800 CHIPSET DB2000 Z1010 CHIPSET DB2000 SEMC A2 UNLOCKING OF A2 PHONES CID 49,51,52,53 standalone usercode reset 1. select proper model 2. on settings, check "signed mode" 3. back to semc a2 tab, press unlock CID 49,51,52,53 standalone full reset-based unlock 1. select proper model 2. select needed domain (leave "current" for no change) 3. on settings, check "signed mode","use alternative security bypass" 4. back to semc a2 tab, press unlock that method can fix damaged SCRC and fixing SEMCBOOT automatically. that is preferred method for such phones. server-based full signature unlock 1. select proper model 2. on settings, check "signed mode","do full unlock instead usercode reset",fill login details 3. back to semc a2 tab, press unlock that method can not fix SCRC. CID 80,81 server-based full signature unlock 1. select proper model 2. on settings, check "signed mode","do full unlock instead usercode reset",fill login details 3. back to semc a2 tab, press unlock that method can not fix SCRC. if s1 signature server offline, you can not use quick (without modem drivers) unlock. instead, you should : 1. select proper model 2. on settings, check "signed mode", "do full unlock instead usercode reset", "disable flash mode activation for semc a2 phones", fill login details 3. back to semc a2 tab, press unlock 4. when prompted, install phone modem drivers (they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite) 5. when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. CID 54,60,185,186 standalone full unlock 1. select proper model 2. on settings, check "signed mode" 3. back to semc a2 tab, press unlock that method can fix SCRC. that is preferred method to unlock such phones. CHARGE: db3150 (a2 platform) cid49,51,52 full standalone unlock is free Full unlock 6+0=6 credits required ( please use unlock using altbypass ) db3150 (a2 platform) cid53 reset mode - 1 credits Full unlock 6+0=6 credits required ( please use unlock using altbypass ) db3200 (a2 platform) cid49,51,52 full standalone unlock is free Full unlock 6+0=6 credits required ( please use unlock using altbypass ) db3200 (a2 platform) cid53 reset mode - 1 credits Full unlock 6+0=6 credits required ( please use unlock using altbypass ) db3200 (a2 platform) cid80,cid81 Full unlock 6+0=6 credits required db3210 (a2 platform) cid49,51,52 full standalone unlock is free Full unlock 6+0=6 credits required ( please use unlock using altbypass ) db3210 (a2 platform) cid53 reset mode - 1 credits Full unlock 6+0=6 credits required ( please use unlock using altbypass ) db3210 (a2 platform) cid80,cid81 Full unlock 6+0=6 credits required db3350 (a2 platform) cid53 reset mode - 1 credits Full unlock 6+0=6 credits required ( please use unlock using altbypass ) db3350 (a2 platform) cid80,cid81 Full unlock 6+0=6 credits required C510 CHIPSET DB3210 C702 CHIPSET DB3150 C901 CHIPSET DB3210 C902 CHIPSET DB3150 C903 CHIPSET DB3210 C905 CHIPSET DB3210 F100_JALOU CHIPSET DB3200 G502 CHIPSET DB3150 G705 CHIPSET DB3210 J10_ELM CHIPSET DB3350 J20_HAZEL CHIPSET DB3350 J105_NAITE CHIPSET DB3200 J108_CEDAR CHIPSET DB3350 K630/V640 CHIPSET DB3250 K660 CHIPSET DB3150 K850 CHIPSET DB3150 T700 CHIPSET DB3150 T707 CHIPSET DB3200 T715 CHIPSET DB3210 U10_AINO CHIPSET DB3350 U100_YARI CHIPSET DB3350 W20_ZYLO CHIPSET DB3350 W508 CHIPSET DB3200 W595 CHIPSET DB3150 W705 CHIPSET DB3210 W715 CHIPSET DB3210 W760 CHIPSET DB3150 W890 CHIPSET DB3150 W902 CHIPSET DB3150 W910 CHIPSET DB3150 W980 CHIPSET DB3150 W995 CHIPSET DB3210 X5_XPERIA_PURENESS CHIPSET DB3350 Z750 CHIPSET DB3150 Z770 CHIPSET DB3150 Z780 CHIPSET DB3150 SEMC ODM UNLOCKING OF SEMC S1-BASED ODM PHONES server-based full signature method 1. select correct model 2. on settings, check "signed mode", "do full unlock instead of usercode reset" 3. back to odm tab 4. press unlock that method can fix damaged security zone. that method depends of external service, so it can be offline any time. standalone patch method 1. select correct model 2. uncheck all settings 3. back to odm tab 4. press unlock note, that such method will work only for old security locosto-based phones. if you will get error while attempting to do that method - you have new security phone and should try other methods. server-based patch method 1. select correct model 2. on settings, check "signed mode", "use alternative security bypass" 3. back to odm tab 4. press unlock that method can not fix security zone. that method is standalone in setool2 versions, greater than 1.0 user code reset 1. select correct model 2. on settings, check "signed mode" 3. back to odm tab 4. press unlock note,that some old firmware not support usercode reset, so if standart code will not work after reset, reflash phone with latest firmware. CHARGE: calypso lite/arima (ODM phones) patch unlock is free no unlock via server locosto-based S1 phones (ODM phones) patch unlock via server - 1 credit required full unlock via server - 4 credits required (when signature server works) ( during promo ) neptune-based S1 phones (ODM phones) patch unlock via server - 1 credit required full unlock via server - 4 credits required (when signature server works) ( during promo ) F305 CHIPSET NEPTUNE J110 CHIPSET CALYPSO J120 CHIPSET CALYPSO J132 CHIPSET LOCOSTO J220 CHIPSET ARIMA J230 CHIPSET ARIMA K200 CHIPSET CALYPSO K220 CHIPSET CALYPSO K330 CHIPSET LOCOSTO R300 CHIPSET LOCOSTO R306 CHIPSET LOCOSTO S302 CHIPSET NEPTUNE S312 CHIPSET NEPTUNE T250 CHIPSET LOCOSTO T270 CHIPSET LOCOSTO T280 CHIPSET LOCOSTO T303 CHIPSET LOCOSTO W100 SPIRO CHIPSET PNX6513 W205 CHIPSET LOCOSTO W302 CHIPSET NEPTUNE W395 CHIPSET NEPTUNE Z250 CHIPSET LOCOSTO Z300 CHIPSET ARIMA Z320 CHIPSET LOCOSTO |
03-15-2012, 21:19 | #6 (permalink) |
Freak Poster Join Date: Jan 2005 Location: mexico city Age: 52
Member: 106488 Status: Offline Thanks Meter: 24 | please refund mi log RUNNING v 1.1203/01.12/UNI CARD SERIAL 00035667 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID:E900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,35662803354625] OTP LOCKED:1 CID:81 PAF:1 IMEI:35662803354625 CERT:RED ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE Unlock FAILED Elapsed: 6 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:E900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,35662803354625] OTP LOCKED:1 CID:81 PAF:1 IMEI:35662803354625 CERT:RED LDR:2010-03-02 18:01 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:01 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA USERCODE RESET TO "0000" Unlock DONE Elapsed: 12 secs. CFG:000000000000 ChipID:E900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,35662803354625] OTP LOCKED:1 CID:81 PAF:1 IMEI:35662803354625 CERT:RED LDR:2010-03-02 18:01 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:01 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Unlock DONE Elapsed: 10 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID:E900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,35662803354625] OTP LOCKED:1 CID:81 PAF:1 IMEI:35662803354625 CERT:RED ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE Unlock FAILED Elapsed: 8 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:E900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,35662803354625] OTP LOCKED:1 CID:81 PAF:1 IMEI:35662803354625 CERT:RED LDR:2010-03-02 18:01 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:01 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] server error:remote dongle not available Unlock FAILED Elapsed: 15 secs. SIGNED MODE (USING SERVER) CFG:100010000000 credits consumption for full signature unlock: S1 v1 xx credits ( OFFLINE ) S1 v2 xx credits ( OFFLINE ) S1 OPEN 05 credits ( OFFLINE FOR AID 004 PHONES) A1 phones 05 credits A2 phones 05 credits S1 v2 alternative bypass unlock 02 credits S1 v2 alternative bypass repair 05 credits W100,W150 codes 05 credits You can not unlock that phones When S1 v1,S1 v2 servers offline: j108 cid81, u1/u5/u8 aid 004, F305,J132,K330,R300,R306,S302,S312,T250,T280,T303, W205,W302, W395,Z250,Z320 phones with damaged security zone, F305,J132,K330,R300,R306,S302,S312,T250,T280,T303, W205,W302, W395,Z250,Z320 aid 004, w100,w150 full unlock, ck13,ck15,wt13. current setool2 version: 1.1203 SERVER CREDITS LEFT/USED: 1/59 CARD COUNTERS: FLASH 951, UNLOCK 256 Elapsed: 6 secs. |
03-15-2012, 21:35 | #7 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,439 | it is not fair to refund your credits because you do NOT know how to unlock a2 cid81 CFG:100010000000 is wrong here are 4 easy steps 1 tick 1+5+6 2 press unlock and follow instructions if needed the drivers are located at \setool\drivers\modem_drivers 3 when setool shows 'Unlock DONE', don't remove the cable/battery until the phone fully restarts by itself 4 that is all 3 easy steps ps: no extra credits are needed while the signature is in your pc. |
The Following User Says Thank You to :Aishur: For This Useful Post: |
03-18-2012, 11:24 | #9 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Free Palestine
Member: 330579 Status: Offline Thanks Meter: 67,515 | Quote:
http://forum.gsmhosting.com/vbb/f473...nlock-1316975/ Regards | |
05-29-2012, 12:17 | #10 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | w902 unlocked done.. Code: Model (from GDFS):W902 29.05.2012 14:08:08 MAPP CXC article: R3EA036 prg12067421_GENERIC_PT 29.05.2012 14:08:08 MAPP CXC version: R3EA036 29.05.2012 14:08:08 Language Package: ADRIATIC 29.05.2012 14:08:08 CDA article: 1230-8107 29.05.2012 14:08:08 CDA version: R2A 29.05.2012 14:08:08 Default article: 1206-7411 29.05.2012 14:08:08 Default version: R3EA036 29.05.2012 14:08:08 PROVIDER: 226-10 29.05.2012 14:08:08 Network LOCKED 29.05.2012 14:08:08 29.05.2012 14:08:09 Elapsed: 29 secs. 29.05.2012 14:08:29 SIGNED MODE (USING SERVER) 29.05.2012 14:08:29 ALTERNATIVE SECURITY BYPASS ENABLED 29.05.2012 14:08:29 PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") 29.05.2012 14:08:29 CFG:110000000000 29.05.2012 14:08:37 ChipID:C900,EMP protocol:0401 29.05.2012 14:08:37 BOOTROM MODE DETECTED 29.05.2012 14:08:37 OTP DBG: [1,52,1,35705302299687] 29.05.2012 14:08:39 OTP LOCKED:1 CID:52 PAF:1 IMEI:35705302299687 CERT:RED 29.05.2012 14:08:45 LDR:2009-06-26 15:47 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A082 29.05.2012 14:08:47 LDR:2009-06-26 15:48 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A082 29.05.2012 14:08:57 GOT SEED:302F42B53480BD7225702A49 29.05.2012 14:08:58 P96 AUTH PASSED 29.05.2012 14:08:58 RESTARTING ... 29.05.2012 14:09:00 ChipID:C900,EMP protocol:0401 29.05.2012 14:09:00 BOOTROM MODE DETECTED 29.05.2012 14:09:00 OTP DBG: [1,52,1,35705302299687] 29.05.2012 14:09:02 OTP LOCKED:1 CID:52 PAF:1 IMEI:35705302299687 CERT:RED 29.05.2012 14:09:02 DEVICE KEY:60D7767F6DE92E5F4461C148B2613F7F (1) 29.05.2012 14:09:03 LDR:2009-06-26 15:54 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A082 29.05.2012 14:09:04 LDR:2009-06-26 15:54 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A082 29.05.2012 14:09:05 GOT SEED:08356BCB3480BD7225702A49 29.05.2012 14:09:06 P96 AUTH PASSED 29.05.2012 14:09:06 RESETTING SECURITY TO FACTORY STATE ... 29.05.2012 14:09:06 RESTARTING ... 29.05.2012 14:09:08 ChipID:C900,EMP protocol:0401 29.05.2012 14:09:09 BOOTROM MODE DETECTED 29.05.2012 14:09:09 OTP DBG: [1,52,1,35705302299687] 29.05.2012 14:09:11 OTP LOCKED:1 CID:52 PAF:1 IMEI:35705302299687 CERT:BROWN 29.05.2012 14:09:12 LDR:2010-03-02 17:56 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A096 29.05.2012 14:09:14 LDR:2010-03-02 17:56 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A096 29.05.2012 14:09:14 WRITING SEMCBOOT ... 29.05.2012 14:09:15 PREPARING SECURITY ... 29.05.2012 14:09:15 PHONE DOMAIN: "RED" 29.05.2012 14:09:15 WRITING CLEAR SIMLOCK UNITS ... 29.05.2012 14:09:15 SIMLOCK CODES SET TO "84822228" 29.05.2012 14:09:16 SIGNING ... 29.05.2012 14:09:16 DEVICE KEY RESTORED 29.05.2012 14:09:17 Unlock DONE 29.05.2012 14:09:17 Elapsed: 47 secs. 29.05.2012 14:11:35 SIGNED MODE (USING SERVER) |
07-18-2012, 11:26 | #11 (permalink) |
Freak Poster Join Date: Jun 2012 Location: valencia spain
Member: 1770619 Status: Offline Sonork: 100.1619675 Thanks Meter: 44 | SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 ChipID: 7100, EMP protocol: 0301 PHONE DOMAIN: "RETAIL" PHONE CID: 0049 SPEED: 921600 LDR: 050810 0923 NPA1CXC125871_PRODUCTION_ID_LOADER R2B OTP: LOCKED:1 CID:49 PAF:1 IMEI:35684200388423 CERT:RED CURRENT CID: 49 COLOR: RED FLASH ID: 200D Downgrading security ... ChipID: 7100, EMP protocol: 0301 PHONE DOMAIN: "RETAIL" PHONE CID: 0049 SPEED: 460800 RESET: 070703 1102 NPACXC125880_DB2000_CERTRESETLOADER_P4D GOT SEED: D0BFA5372180EA710570D45E P96 AUTH PASSED Restarting ... ChipID: 7100, EMP protocol: 0301 PHONE DOMAIN: "DEVELOPER" PHONE CID: 0049 SPEED: 460800 LDR: 050926 1421 NPA1CXC1250164_SEMC_PRODUCTION R2D CURRENT CID: 49 COLOR: BROWN Setting up GDFS ... WRITING CLEAR SIMLOCK UNITS ... SIMLOCK CODES SET TO "51557458" SIGNING ... Unlock DONE Elapsed: 30 secs. |
07-22-2012, 10:50 | #12 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Guangzhou, China
Member: 659181 Status: Offline Thanks Meter: 7,652 | Elapsed: 9 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID: E900, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35427803580524] OTP LOCKED: 1 CID: 53 PAF: 1 IMEI: 35427803580524 CERT: RED LDR: 2009-10-26 13:51 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A087 LDR: 2009-10-26 13:52 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A087 GOT SEED: 56670A893580E66735C0BA8D P96 AUTH PASSED RESTARTING ... ChipID: E900, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35427803580524] OTP LOCKED: 1 CID: 53 PAF: 1 IMEI: 35427803580524 CERT: RED DEVICE KEY: 49E290389D3A4F9C685A8D730DC25F3D (1) LDR: 2009-10-26 14:03 1202-0417_DB3210_RESET_LOADER_ACC_SDRAM_R2A087 LDR: 2009-10-26 14:04 1202-0416_DB3210_RESET_LOADER_APP_SDRAM_R2A087 GOT SEED: C851C7CB3580E66735C0BA8D P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE ... RESTARTING ... ChipID: E900, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35427803580524] OTP LOCKED: 1 CID: 53 PAF: 1 IMEI: 35427803580524 CERT: BROWN LDR: 2010-03-02 18:04 1202-0415_DB3210_PRODUCTION_LOADER_ACC_SDRAM_R2A096 LDR: 2010-03-02 18:04 1202-0414_DB3210_PRODUCTION_LOADER_APP_SDRAM_R2A096 WRITING SEMCBOOT ... PREPARING SECURITY ... PHONE DOMAIN: "RED" WRITING CLEAR SIMLOCK UNITS ... SIMLOCK CODES SET TO "13145348" SIGNING ... DEVICE KEY RESTORED Unlock DONE Elapsed: 42 secs. |
The Following 2 Users Say Thank You to Gsm-extreme For This Useful Post: |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
