11-15-2010, 18:21 | #1 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 821762 Status: Offline Thanks Meter: 17 | Setool Kill J10i2 AFTER UNLOCK !!!! CFG:100011000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0080 OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403060000 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation Backup security data... Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM27 PHONE READY TO PROCEED. GOT SEED:00FD761E ACTIVATION COMPLETED. USERCODE RESET TO "0000" Unlock DONE After Unlock INSERT CORRECT SIM CARD Any Solution??? |
11-15-2010, 18:33 | #2 (permalink) |
No Life Poster Join Date: Mar 2009
Member: 998084 Status: Offline Sonork: 100.1652656 Thanks Meter: 265 | Code: SIGNED MODE (USING SERVER) CFG:100011000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0080 OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403060000 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation Backup security data... Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM27 PHONE READY TO PROCEED. GOT SEED:00FD761E ACTIVATION COMPLETED. USERCODE RESET TO "0000" Unlock DONE After Unlock INSERT CORRECT SIM CARD Any Solution??? in setting tab (signed mode, full unlock, disable flash mode activation) and press unlock |
11-15-2010, 18:36 | #4 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,439 | Please check also your brain is dead or not and pay attention to the last point (5th) http://forum.gsmhosting.com/vbb/6548809-post3.html |
The Following User Says Thank You to :Aishur: For This Useful Post: |
11-15-2010, 18:45 | #7 (permalink) |
Member: 821762 Status: Offline Thanks Meter: 17 | 5. when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. THX All 4 help ;] |
The Following User Says Thank You to turboflashing For This Useful Post: |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
