07-21-2010, 20:45 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: ARM Age: 39
Member: 202576 Status: Offline Thanks Meter: 19 | SeTool problems with U5i Vivaz!HELP! |
07-21-2010, 21:14 | #4 (permalink) |
Member: 202576 Status: Offline Thanks Meter: 19 | 22.07.2010 0:12:13 RUNNING v 1.085/UNI 22.07.2010 0:12:13 CARD SERIAL 000xxxxxxxxx 07.2010 0:12:13 USBFLASH DRIVER VERSION 02.02.00.05 22.07.2010 0:12:23 CFG:000000000000 22.07.2010 0:12:44 PROCEDURE WAS STOPPED BY USER 22.07.2010 0:12:45 Can't load ID loader ! 22.07.2010 0:12:46 Elapsed: 22 secs. 22.07.2010 0:12:55 CFG:000000000000 22.07.2010 0:14:08 PROCEDURE WAS STOPPED BY USER 22.07.2010 0:14:09 Can't load ID loader ! 22.07.2010 0:14:09 Elapsed: 73 secs. 22.07.2010 0:14:16 ERROR [FF] 22.07.2010 0:14:25 CFG:000000000000 22.07.2010 0:14:41 PROCEDURE WAS STOPPED BY USER 22.07.2010 0:14:43 Can't load ID loader ! 22.07.2010 0:14:43 Elapsed: 18 secs. 22.07.2010 0:14:48 CFG:000000000000 22.07.2010 0:15:08 PROCEDURE WAS STOPPED BY USER 22.07.2010 0:15:08 Can't load ID loader ! 22.07.2010 0:15:08 Elapsed: 19 secs. 22.07.2010 0:57:46 CFG:000000000000 |
07-21-2010, 21:42 | #6 (permalink) |
No Life Poster Join Date: Sep 2007 Location: algeria
Member: 591880 Status: Offline Thanks Meter: 561 | its not pc probleme its not driver probleme its not setool probleme you are the probleme man .i dont see use server in your log and to boot satio vivaz phone you need to check use server and connect turned off phone while holding "green" button try and see |
The Following User Says Thank You to algerienbox For This Useful Post: |
07-21-2010, 21:56 | #7 (permalink) |
Member: 202576 Status: Offline Thanks Meter: 19 | Are you kidding? I connect turned off phone while holding green button!iphone not identify !Read carefully my lasts post please.!!!!!Once again,I connect this phone to original SonyEricsson update tool by holding green button!!!! |
07-21-2010, 23:07 | #8 (permalink) |
Member: 202576 Status: Offline Thanks Meter: 19 | first-I trying in safe mode and then in normal mode,after, i didn't know how but I did it!))))))) 22.07.2010 2:20:27 RUNNING v 1.085/UNI 22.07.2010 2:20:27 CARD SERIAL 000xxxxxxxx 22.07.2010 2:20:27 USBFLASH DRIVER VERSION 02.02.00.05 22.07.2010 2:20:51 SIGNED MODE (USING SERVER) 22.07.2010 2:20:51 CFG:100010000000 22.07.2010 2:20:51 PLEASE ATTACH TURNED OFF PHONE NOW 22.07.2010 2:20:51 PRESS AND HOLD "GREEN" BUTTON... 22.07.2010 2:21:08 22.07.2010 2:21:08 EROM "R8A017" AID: 0001 22.07.2010 2:21:08 SOFTWARE AID: 0001 22.07.2010 2:21:08 SIMLOCK STATE: "NOT TAMPERED" 22.07.2010 2:21:08 LOADER AID: 0002 22.07.2010 2:21:17 FLASH ID: "00EC/0040" 22.07.2010 2:21:17 LOADER VERSION: "R4A012" 22.07.2010 2:21:17 22.07.2010 2:21:17 PHONE IMEI:0123320024xxxxx 22.07.2010 2:21:17 MODEL (from GDFS): U5i 22.07.2010 2:21:17 SOFTWARE VERSION: 1224-3329_R2B005 22.07.2010 2:21:18 CORE OS VERSION: 1224-4699_R2AK007 22.07.2010 2:21:18 CUSTOM VERSION: 1234-0087_R21A 22.07.2010 2:21:18 SERIAL NO: BX901MUE03 22.07.2010 2:21:18 Elapsed: 26 secs. 22.07.2010 2:23:03 SIGNED MODE (USING SERVER) 22.07.2010 2:23:03 CFG:100010000000 22.07.2010 2:23:04 bad username/password. 22.07.2010 2:23:06 CARD COUNTERS: FLASH 222, UNLOCK 66 22.07.2010 2:23:06 Elapsed: 3 secs. 22.07.2010 2:23:14 SIGNED MODE (USING SERVER) 22.07.2010 2:23:14 CFG:100010000000 22.07.2010 2:23:16 SERVER CREDITS LEFT/USED: 10/20 22.07.2010 2:23:18 CARD COUNTERS: FLASH 222, UNLOCK 66 22.07.2010 2:23:18 Elapsed: 3 secs. 22.07.2010 2:23:22 SIGNED MODE (USING SERVER) 22.07.2010 2:23:22 CFG:100010000000 22.07.2010 2:23:22 PLEASE ATTACH TURNED OFF PHONE NOW 22.07.2010 2:23:22 PRESS AND HOLD "GREEN" BUTTON... 22.07.2010 2:23:34 22.07.2010 2:23:34 EROM "R8A017" AID: 0001 22.07.2010 2:23:34 SOFTWARE AID: 0001 22.07.2010 2:23:34 SIMLOCK STATE: "NOT TAMPERED" 22.07.2010 2:23:34 LOADER AID: 0002 22.07.2010 2:23:44 FLASH ID: "00EC/0040" 22.07.2010 2:23:44 LOADER VERSION: "R4A012" 22.07.2010 2:23:44 22.07.2010 2:23:44 PHONE IMEI:01233200xxxxx 22.07.2010 2:23:44 Checking for signature... 22.07.2010 2:23:46 Waiting for calculation process... 22.07.2010 2:23:47 RESPONSE: "SUCCESS" [1048] 22.07.2010 2:23:48 GOT SEED:A4379D6F802C300030F13B82 22.07.2010 2:23:49 OMAP P96 AUTH PASSED 22.07.2010 2:23:50 GOT SEED:C549F9876F802C300030F13B 22.07.2010 2:23:50 CCPU P96 AUTH PASSED 22.07.2010 2:23:52 Unlock DONE 22.07.2010 2:23:52 Elapsed: 30 secs. 22.07.2010 2:24:04 SIGNED MODE (USING SERVER) 22.07.2010 2:24:04 CFG:100010000000 22.07.2010 2:24:06 SERVER CREDITS LEFT/USED: 9/21 22.07.2010 2:24:08 CARD COUNTERS: FLASH 222, UNLOCK 67 22.07.2010 2:24:08 Elapsed: 4 secs. Thenx All for reply! |
07-21-2010, 23:50 | #9 (permalink) |
Member: 591880 Status: Offline Thanks Meter: 561 | you dont read my post carefully your probleme is in seeting Code: you are the probleme man .i dont see use server in your log and to boot satio vivaz phone you need to check use server and connect turned off phone while holding "green" button Code: CFG:000000000000 Code: CFG:100010000000 |
12-13-2010, 11:37 | #10 (permalink) |
Freak Poster Join Date: May 2005 Age: 44
Member: 143156 Status: Offline Thanks Meter: 95 | \ Code: you are the probleme man .i dont see use server in your log and to boot satio vivaz phone you need to check use server and connect turned off phone while holding "green" button THANK U SIR |
09-03-2012, 07:57 | #11 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh Age: 34
Member: 1217931 Status: Offline Sonork: 100.1604251 Thanks Meter: 267 | u5i vivaz succesfull flash but heng log....... RUNNING v 1.1292/01.15/UNI CARD SERIAL 00134356 USBFLASH DRIVER VERSION 03.00.00.00 SIGNED MODE (USING SERVER) CFG:101000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "GREEN" BUTTON ... RUNNING S1_EROM VER "R8A017" EROM_AID : 0001 LOADER_AID : 0002 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 SIMLOCK STATE: "NOT TAMPERED" DEVICE ID: D47128460F03A074CCFCB3C8FB0553126D245D60 FLASH ID: "0020/0040" LOADER VERSION: "R4A012" PHONE IMEI : 35938703143669 writing "D:\SE-TOOL- Flash\u5_vivaz\U5a_AMERICA_CDF1233_9752.zip" Processing package D:\SE-TOOL- Flash\u5_vivaz\U5a_AMERICA_CDF1233_9752.zip Processing ACPU files PROCESSING: R10A_CDF_ROFS3_U5a_PERS_AR_1233_9752_S1_CUST_LIVE_ 263F_0001_XSR.software FILE FLASHED OK PROCESSING: R1AA006_APP_SW_KOKORO_CRASHDATA_1227_0058_S1_SW_LI VE_1F6D_0001_XSR.software FILE FLASHED OK PROCESSING: R2A014_APP_SW_KURARA_CCPU_GENERIC_1224_3329_S1_SW_ LIVE_1F6D_0001_SSW.software FILE FLASHED OK PROCESSING: R2AA006_USERDATA_FS_KURARA_GENERIC_1233_7836_S1_SW _LIVE_1F6D_0001_XSR.software FILE FLASHED OK PROCESSING: R2AA026_ROFS2_FS_KURARA_AMERICA_1232_1974_S1_SW_LI VE_1F6D_0001_XSR.software FILE FLASHED OK PROCESSING: R2AA029_CORE_OS_APP_SW_KURARA_SP2_GENERIC_1224_469 9_S1_SW_LIVE_1F6D_0001_XSR.software FILE FLASHED OK PROCESSING: R2AA029_ROFS1_APP_SW_KURARA_SP2_GENERIC_1224_4699_ S1_SW_LIVE_1F6D_0001_XSR.software FILE FLASHED OK Processing update files PROCESSING: 0906121409_HB109_Open_MiscTA_Restore.ta.gdfs writing TA var 0002/0899/0001 writing TA var 0002/0BB9/0006 writing TA var 0002/10CF/0010 PROCESSING: 0909230823_HB109_Open_TA_Restore.ta.gdfs writing TA var 0001/0063/0001 writing TA var 0001/0128/0001 writing TA var 0001/0143/0001 writing TA var 0001/0144/0001 writing TA var 0001/0145/0001 writing TA var 0001/0146/0001 writing TA var 0001/018F/0001 writing TA var 0001/0190/0001 writing TA var 0001/0191/0001 writing TA var 0001/0192/0001 writing TA var 0001/01A3/0001 writing TA var 0001/13BB/0001 PROCESSING: R10A_CDF_U5a_PERS_AR_1233_9752.ta.gdfs writing TA var 0001/0128/0001 writing TA var 0001/13BB/0001 PROCESSING: R10A_R2AA029_CDF_INFO_U5a_PERS_AR_1233_9752.ta.gdf s writing TA var 0002/08A2/0003 writing TA var 0002/089A/0010 writing TA var 0002/08AD/0011 writing TA var 0002/08B0/0011 writing TA var 0002/089C/0007 writing TA var 0002/08B1/0011 writing TA var 0002/089D/000E writing TA var 0002/0BB8/0001 writing TA var 0002/0BBA/000E Elapsed: 133 secs. |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
