05-18-2010, 09:59 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Bangladesh
Member: 881225 Status: Offline Sonork: 100.1678282 Thanks Meter: 80 | Setool team plz help se w810 packet not acknowledged (18) format cmd response not received Elapsed: 51 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 loader prologue returns invalid status PROCEDURE WAS STOPPED BY USER Elapsed: 9 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 RESET:070703 1100 NPACXC125870_DB2010_CERTRESETLOADER_P5F FLASH ID: 2019 GOT SEED:18BBABF621804F6C158035ED P96 AUTH PASSED OTP LOCKED:1 CID:49 PAF:1 IMEI:35540701971608 CERT:BROWN PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 25 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 skipping empty loader... FAILED TO SETUP PHONE Elapsed: 1 secs. |
05-18-2010, 15:04 | #3 (permalink) |
Member: 881225 Status: Offline Sonork: 100.1678282 Thanks Meter: 80 | RUNNING v 1.05/UNI CARD SERIAL 00053377 PLEASE UPGRADE USBFLASH DRIVER 01.01.00.0C FILE RECOGNIZED AS CUSTOMIZATION PACKAGE. MODEL:Helen CDA: CDA102494/44 CDA REV: R1A VARIANT:EUROPE_5 LANGUAGE: EN FR DE IT SIGNED MODE (USING SERVER) CFG:100000001000 ChipID:8040,EMP protocol:0301 OBSOLETE EROM,FORCING "RETAIL" PHONE STATE OBSOLETE EROM,FORCING "CID49" PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 FLASH ID: 2019 OTP LOCKED:1 CID:49 PAF:1 IMEI:35540701971608 CERT:RED ACTIVE CID:49 COLOR:BROWN IMEI MISMATCH ! GDFS IMEI:04857555048575 Model (from GDFS):W810i MAPP CXC article: R4DB005 prgCXC1250321_ORANGE_HN MAPP CXC version: R4DB005 Language Package: S_ASIA_LEVAN CDA article: CDA102555/110 CDA version: R2A Default article: cxc1250324 Default version: R4CE012 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 SEARCH:G:\Setool--3\Flash File\Flash File\Sonyerission\w810i\cid49\R4EA031_1250316_GENE RIC_HN.ssw.cry SEARCH:G:\Setool--3\Flash File\Flash File\Sonyerission\w810i\cid49\R4EA031_EUROPE_2_fs. ssw.cry RESTORATION FILE NOT PRESENT "R4DB005_CXC1250321_ORANGE_HN" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 57 secs. SIGNED MODE (USING SERVER) CFG:100000001000 ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0049 Speed:921600 FLASH ID: 2019 OTP LOCKED:1 CID:49 PAF:1 IMEI:35540701971608 CERT:BROWN ACTIVE CID:49 COLOR:BROWN IMEI MISMATCH ! GDFS IMEI:04857555048575 Model (from GDFS):W810i MAPP CXC article: R4DB005 prgCXC1250321_ORANGE_HN MAPP CXC version: R4DB005 Language Package: S_ASIA_LEVAN CDA article: CDA102555/110 CDA version: R2A Default article: cxc1250324 Default version: R4CE012 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 SEARCH:G:\Setool--3\Flash File\Flash File\Sonyerission\w810i\cid49\R4EA031_1250316_GENE RIC_HN.ssw.cry SEARCH:G:\Setool--3\Flash File\Flash File\Sonyerission\w810i\cid49\R4EA031_EUROPE_2_fs. ssw.cry RESTORATION FILE NOT PRESENT "R4DB005_CXC1250321_ORANGE_HN" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 11 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0049 skipping empty loader... FAILED TO SETUP PHONE Elapsed: 3 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0049 skipping empty loader... FAILED TO SETUP PHONE Elapsed: 3 secs. THAT ACTION IS ILLEGAL,IF YOU DOING IT FOR ANY PURPOSE, OTHER THAN REPAIR PHONE CFG:000000110000 ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0049 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35540701971608 CERT:BROWN LDRB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID: 2019 Searching... OTP IMEI CHECK NOT FOUND Setting up GDFS... IMEI MISMATCH !!!! POSSIBLE STOLEN PHONE !!!!! ORIGINAL IMEI:35540701971608 CURRENT IMEI:04857555048575 WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "24432000" SIGNING... Unlock FINISHED Elapsed: 76 secs. CFG:000000110000 ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0049 Speed:921600 FLASH ID: 2019 OTP LOCKED:1 CID:49 PAF:1 IMEI:35540701971608 CERT:BROWN ACTIVE CID:49 COLOR:BROWN Model (from GDFS):W810i MAPP CXC article: R4DB005 prgCXC1250321_ORANGE_HN MAPP CXC version: R4DB005 Language Package: S_ASIA_LEVAN CDA article: CDA102555/110 CDA version: R2A Default article: cxc1250324 Default version: R4CE012 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 SEARCH:G:\Setool--3\Flash File\Flash File\Sonyerission\w810i\cid49\R4EA031_1250316_GENE RIC_HN.ssw.cry SEARCH:G:\Setool--3\Flash File\Flash File\Sonyerission\w810i\cid49\R4EA031_EUROPE_2_fs. ssw.cry RESTORATION FILE NOT PRESENT "R4DB005_CXC1250321_ORANGE_HN" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 9 secs. CFG:000000110000 ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0049 Speed:921600 FLASH ID: 2019 OTP LOCKED:1 CID:49 PAF:1 IMEI:35540701971608 CERT:BROWN ACTIVE CID:49 COLOR:BROWN Model (from GDFS):W810i MAPP CXC article: R4DB005 prgCXC1250321_ORANGE_HN MAPP CXC version: R4DB005 Language Package: S_ASIA_LEVAN CDA article: CDA102555/110 CDA version: R2A Default article: cxc1250324 Default version: R4CE012 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 SEARCH:G:\Setool--3\Flash File\Flash File\Sonyerission\w810i\cid49\R4EA031_1250316_GENE RIC_HN.ssw.cry SEARCH:G:\Setool--3\Flash File\Flash File\Sonyerission\w810i\cid49\R4EA031_EUROPE_2_fs. ssw.cry RESTORATION FILE NOT PRESENT "R4DB005_CXC1250321_ORANGE_HN" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 9 secs. CFG:000000110000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 2 secs. CFG:000000110000 ChipID:8040,EMP protocol:0301 OBSOLETE EROM,FORCING "RETAIL" PHONE STATE OBSOLETE EROM,FORCING "CID49" PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 FLASH ID: 2019 OTP LOCKED:1 CID:49 PAF:1 IMEI:35540701971608 CERT:RED ACTIVE CID:49 COLOR:BROWN Model (from GDFS):W810i MAPP CXC article: R4DB005 prgCXC1250321_ORANGE_HN MAPP CXC version: R4DB005 Language Package: S_ASIA_LEVAN CDA article: CDA102555/110 CDA version: R2A Default article: cxc1250324 Default version: R4CE012 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 SEARCH:G:\Setool--3\Flash File\Flash File\Sonyerission\w810i\cid49\R4EA031_1250316_GENE RIC_HN.ssw.cry SEARCH:G:\Setool--3\Flash File\Flash File\Sonyerission\w810i\cid49\R4EA031_EUROPE_2_fs. ssw.cry RESTORATION FILE NOT PRESENT "R4DB005_CXC1250321_ORANGE_HN" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 12 secs. SIGNED MODE (USING SERVER) CFG:100000001000 ChipID:8040,EMP protocol:0301 OBSOLETE EROM,FORCING "RETAIL" PHONE STATE OBSOLETE EROM,FORCING "CID49" PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35540701971608 CERT:RED FLASH ID: 2019 writing "G:\Setool--3\Flash File\Flash File\Sonyerission\w810i\cid49\R4EA031_1250316_GENE RIC_HN.ssw.cry" CURRENT FLASH FILE CID:49 Converting firmware... SSW uses dynamic hash, dynamic hash len is: 344 HDR block not accepted,error: 0E Elapsed: 9 secs. PLZ HELP |
The Following User Says Thank You to shahalom007 For This Useful Post: |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
