06-25-2007, 14:16 | #61 (permalink) | ||
Banned Join Date: May 2003 Location: www.CentralMobile.net/vbb
Member: 28188 Status: Offline Thanks Meter: 579 | Quote:
Understand that your phone is CID 52 not CID51. (here the cid reffers to the flash and not to the OTP) To unlock your phone with Setool you may need an another account for the new special server. is not it so easy to understand?? Best regards, Aishur | ||
06-25-2007, 14:36 | #62 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Pakistan
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | CID49, CID51, CID52 all are supported http://forum.gsmhosting.com/vbb/show...4&postcount=50 |
06-25-2007, 14:40 | #63 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: WestSide Age: 38
Member: 254137 Status: Offline Sonork: 1592525 Thanks Meter: 275 | Quote:
v0.91380089/UNI Card serial:000269xx Loaded 51 flash descriptors Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35462301015938 CERT:RED FLASH CID:49 COLOR:RED MAPP CXC article: R4EA031 prgCXC1250316_GENERIC_HN MAPP CXC version: R4EA031 Language Package:EUROPE_2 CDA article: CDA102494/145 CDA version: R3A Default article: cxc1250324 Default version: R4ED001 Network LOCKED Operator: 234-10 USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed:2 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35462301015938 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT Speed:921600 Trying to launch embedded bootloader... Embedded flashloader: COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 Flash ID check:897E Flash props sent ok FOUND: R4EA031_CXC1250316_GENERIC_HN Restore from:R4EA031_CXC1250316_GENERIC_HN Setting up GDFS... Clearing total time... Writing simlocks... ALL UNLOCK/LOCK CODES SET TO "32823404" Signing... control keys complete. full sig complete. Unlock Done Elapsed:54 secs. PS: Phone is not powering on. Please help, customer want to kille me. | |
06-25-2007, 15:44 | #66 (permalink) |
Member: 28188 Status: Offline Thanks Meter: 579 | hi the log seems correct. Reflash it (main+fs) example (R4GC010_1250316_GENERIC_HN + R4GC010_EUROPE_2_fs) Settings Complete phone after flash Unlock after flash DO FULL UNLOCK INSTEAD OF USERCODE RESET. Best Regards, Aishur |
06-25-2007, 16:44 | #68 (permalink) |
Member: 254137 Status: Offline Sonork: 1592525 Thanks Meter: 275 | now phone relocked and cant unlock it. v0.91380089/UNI Card serial:000269xx Loaded 51 flash descriptors Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35462301015938 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT Speed:921600 Trying to launch embedded bootloader... Embedded flashloader: COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 Flash ID check:897E Flash props sent ok FOUND: R4EA031_CXC1250316_GENERIC_HN Restore from:R4EA031_CXC1250316_GENERIC_HN writing D:\SE-TOOL\R4EA031_1250316_GENERIC_HN.ssw\R4EA031_125031 6_GENERIC_HN.ssw.cry CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:344 Will flash 344 blocks... SSW loading returns:0 writing C:\Documents and Settings\GsmWorkShop\Desktop\R4ED001_EUROPE_2_fs.s sw\R4ED001_EUROPE_2_fs.ssw.cry CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:161 Will flash 161 blocks... SSW loading returns:0 Setting up GDFS... Clearing total time... Writing simlocks... ALL UNLOCK/LOCK CODES SET TO "21457406" Signing... control keys complete. full sig complete. CSloader version: COMPACT_SEMC_FS_LOADER_SETOOL2_V26 loader startup: executed loader filesystem startup: executed loader GDFS startup: executed loader unlock: executed Flashing upgrade archive:\SE-TOOL\R4EA031_1250316_GENERIC_HN.ssw\R4EA031_125031 6_GENERIC_HN.ssw.cry CURRENT FLASH FILE CID:49 File archive consist of 10987 blocks. SFA block not accepted. (32/10985),error:01FF Elapsed:638 secs. Last edited by .:==di@bila==:.; 06-25-2007 at 17:01. |
06-26-2007, 15:16 | #71 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: esenler sevgiiletişim TR Age: 58
Member: 60560 Status: Offline Sonork: 100.89085 Thanks Meter: 134 | Quote:
BİGGGGGGGGGGG TNKSSS MY BRO.. SOLVED K800 | |
06-27-2007, 18:03 | #72 (permalink) |
Member: 254137 Status: Offline Sonork: 1592525 Thanks Meter: 275 | v0.91380089/UNI Card serial:000269xx Loaded 51 flash descriptors Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:3557850148xxxxx CERT:RED FLASH CID:51 COLOR:RED MAPP CXC article: R1JC002 prgCXC1250640_GENERIC_AI MAPP CXC version: R1JC002 Language Package:T_MOB_INT_A CDA article: CDA102719/19 CDA version: R9A Default article: cxc1250651 Default version: R1JC002 Operator: 234-30 RESTORATION FILE NOT PRESENT YOU MUST PERFORM FULL FLASHING FOR PATCH UNLOCK Elapsed:38 secs. RESTORE FILE NEEDED. |
06-27-2007, 18:55 | #73 (permalink) |
Member: 28188 Status: Offline Thanks Meter: 579 | Hi here is your restore file Rapidshare and Megaupload Next time, Don't waste your time. Choose another flash or the same :main+fs+ custom (optional) Settings 1 Complete phone after flash (only if the custom file were not selected) 2 Unlock after flash 3 Use server for CSCA unlock/flash 4 Enable alternative security bypass 5 Do full unlock instead of usercode reset. (not required in this case but I check it) Flash your phone, smoke a cigarette and Enjoy Best regards, Aishur |
06-27-2007, 23:01 | #74 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2002 Location: Tunisia Age: 44
Member: 18022 Status: Offline Sonork: 1574868 Thanks Meter: 192 | Best way to unlock CID52 phones (via patch or full unlock) is to use Davinci server !! cheaper,more secure and easy to use !! br |
again thanks setool team t280 hang repair with setool | kadricom | SETool2 | 1 | 04-03-2010 02:21 |
setool upgrade ****3012 setool card | gsm_eprom | Sony Ericsson | 0 | 01-30-2006 23:18 |
ITALIAN SETOOL MANUAL ( manuale setool in italiano ) | Dengel | Off Topic Zone | 10 | 06-27-2005 06:52 |
@SETOOL TEAM Big problam make SETOOL LG3G CABLE PLS HELP?? | Gsmfather.com | LG | 10 | 03-23-2005 12:06 |
