Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 10-08-2011, 18:46   #1 (permalink)
wisdom001's Avatar
Member: 676315
Thanks Meter: 120
Lightbulb Setool update problem
whenever i want to update my setool box it show server error 32 what does it mean i have purchase 20 logs to update my box what i my going to do, please help me member or setool team
Old 10-08-2011, 19:00   #2 (permalink)
indikait's Avatar
Member: 241637
Sonork: 100.1620549
Thanks Meter: 396
Setool2 Card Update, Information, TroubleShooting. [ READ FIRST POST ]
WARNING !!!
As there is too much "blocked" setool2 GEMALTO TOP cards,we investigated issue and found problem.
due to errors in controller firmware ( or due to incompatibility between smartcard/controller firmware/motherboard usb controller )
all smartcard readers i know, which are based on CY7C63001 are failed to send long data packet to/from smartcard.
it happens on some systems only, it can happen not immediately, but on "affected" system it happens always, earlier or later.
due to that, smartcard will receive WRONG command and SETOOL2 WILL BE "BLOCKED".
THAT IS NOT RELATED TO "BLOCKED CARDMANAGER" ISSUE ( ERROR #6982 )
i can not find ANY solution to that problem, other than NOT using Cypress CY7C63001-based readers with setool2 cards.
here is few pictures of AFFECTED readers:
you can also identify such reader by smartcard reader name and driver name:
if you will use that readers, your setool2 smartcard WILL BE BLOCKED - and i will unblock such card ONLY ONCE.
my strong recommendation is use om****y-based readers, like that:
they are working 100% on any system.
of course, usage of latest setool2 version is ABSOLUTE requirement.
QUESTIONS AND ANSWERS
q:
What is card update? which card need to be updated?
a:
SmartCard update required to use 1.107 and following setool2 versions.
All SEtool cards with serial numbers till 177500 must be updated.
q:
how to update setool2 card ? what do i need ?
a:
to update setool2 card, you need valid setool2 account, normal internet connection ( NOT proxy ), open TCP ports 443,1934
put updater ( updater.zip ) in setool2 directory, it will auto read settings from setool2.ini.
Or extract it to any desired directory and fill username,password,server manually.
server address is:
srv01.dontexist.com
if you do not have valid setool2 account, use special updater account:
username=updater
password=updater
on "operations" tab select with mouse click reader with setool2 card.
( remove all smartcards from pc except setool2 one in order to avoid misunderstanding )
you will get "Ready to work" text.
press "update card" button only after you get that.
if your setool2 card not activated ( you can NOT use setool2 version > 1.01 )
you need 20 credits for initial card update.
Credits will be discounted AUTOMATICALLY WITHOUT CONFIRMATION.
if your card eligible for update, you will see following text:
setool2 SmartCard updater [x.xx]
server read: "srv01.dontexist.com"
username read: "update_test"
Please click on reader with setool2 SmartCard.
Ready to work
SmartCard update started.....
CARD SERIAL: 12345678
Checking with server...
setool2 card not activated, credits will be used......
Uploading......................................... ...................................
Update completed
you will get usual "no credits" message in case if you do not have needed credits amount.
in time after time, we will update setool2 smartcard, corresponding notice will be posted in news.
for normal update you do not need any credits, but valid setool2 account required.
if your card eligible for normal update, you will see following text:
Ready to work
Checking with server.........
Update completed
if card already updated, you will get following text:
cmd err: [request denied]
if you getting that text and your card NOT updated, you should post request in that thread with
- your account username
- setool2 card original serial
admin will check issue and write resolution.
if you will get next error message :
Ready to work
CARD IS BLOCKED.
RECOVERY SERIAL: xxxxxxxxxxxxxxxx
auth #0 err: [request denied]
if you getting that text, you should post request in that thread with
- reported recovery serial
most bad thing that can happen:
if you will get next results
CARD SERIAL: 00xxxxxxx
auth #1 err: 6982
that means your card was permanently tampered by some tools and you stuck to v1.106
nothing can be done at all.
please note, that after initial update you can only use setool2 version >= v1.107
q:
how to activate LGTool ? what do i need ?
a:
to activate LGTool, you need valid setool2 account, normal internet connection ( NOT proxy ), open TCP ports 443,1934
you do not need to have setool2 credits on account.
put attached updater in setool2 directory ( it will auto read settings from setool2.ini )
or extract it to any desired directory and fill username,password,server manually.
server address is:
srv01.dontexist.com
Then press "Activate LGTool" button
if your card eligible for activation, you will get next text:
Ready to work
LG application activated
Old 10-08-2011, 19:01   #3 (permalink)
indikait's Avatar
Member: 241637
Sonork: 100.1620549
Thanks Meter: 396
Make sure turn off your fire wall protection!!!
Old 10-08-2011, 20:39   #4 (permalink)
wisdom001's Avatar
Member: 676315
Thanks Meter: 120
i will try and post reply tomorrow
Old 10-09-2011, 11:23   #5 (permalink)
Member: 141547
Thanks Meter: 3
i have problem to setool no boot for these modile sk 17i
and st18i
Old 10-09-2011, 11:50   #6 (permalink)
wisdom001's Avatar
Member: 676315
Thanks Meter: 120
tried but the same server error 32 what is the problem please help me somebody,what does error 32 means and how to reolve this problem.,this is my first time of activating setool box i have the 20 logs to do the activation please help me setool team or member
Old 10-09-2011, 12:38   #7 (permalink)
wisdom001's Avatar
Member: 676315
Thanks Meter: 120
problem solved thank's
Old 10-11-2011, 21:02   #8 (permalink)
Cheater -Don't Deal with him-
Member: 498158
Thanks Meter: 20
cmd err: [request denied]how to explaine this am a reseller and i have many box to update for customer with credit nothing done what can i do help pls
Old 10-12-2011, 08:58   #9 (permalink)
Danish Shafiq's Avatar
Member: 1118710
Sonork: 100.1604414
Thanks Meter: 4,970
It's Means ur Card Already Activated bro.no need to update ur card now..
Old 10-18-2011, 04:19   #10 (permalink)
Member: 144781
how come u solve your problem? please share it, i have the same problem
Old 01-25-2015, 19:17   #11 (permalink)
Member: 2316987
Thanks Meter: 6
Helo, please I just bought fusion box with setool activated, how do I know the serial number in other to activate lgtool, please I need your help. Thanks
Old 01-25-2015, 20:03   #12 (permalink)
Member: 541042
Thanks Meter: 519
Here is not LGTOOL Support Forum
Old 12-11-2015, 08:09   #13 (permalink)
Registered User
Member: 246286
Thanks Meter: 14
how to solve my problem?
Ready to work
RECOVERY SERIAL:
internal card error: DEAD
Old 12-11-2015, 16:16   #14 (permalink)
moshman's Avatar
Member: 193192
Thanks Meter: 327
Ready to work
RECOVERY SERIAL:
Check with another card reader, if that fails buy new card
Old 09-15-2017, 18:03   #15 (permalink)
imrangsmali's Avatar
Member: 2503555
Thanks Meter: 90
hi all setool user i have new user please help me
hi
my CARD SERIAL: 00065046
please check my card is ok or not ok
blocked or clear please replay me
very long time user again
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 08:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-21-1999 19:43
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.26342 seconds with 9 queries
