05-21-2008, 05:58 | #2 (permalink) |
Crazy Poster Join Date: Mar 2008 Location: GSM
Member: 732319 Status: Offline Thanks Meter: 56 | you are in dream sorry dear copy paste here from any other forum than be happy to create sticky post its not the matter post contains any language/words its a big joke in forum no rules on other side some forums have so hard rules user easily use forums with out mistakes/distrubance and i know may be administrators ready for my ban after this post but truth is truth sorry for my all words plz sorry |
05-21-2008, 07:44 | #3 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Bosnia, Kiseljak Age: 41
Member: 85694 Status: Offline Thanks Meter: 48 | Yes, unlock procedure is very easy, so why make sticky something that child can do... So, bro, if you get some problems with unlocking, PM me and I will be glad to help you. BR |
05-21-2008, 08:44 | #4 (permalink) |
No Life Poster Join Date: Mar 2007 Location: SL3;HTC DesireHD DIRECT UNLOCk Age: 44
Member: 476287 Status: Offline Sonork: 100.1587961 Thanks Meter: 834 | retsart the system open settol soft 1. select correct phone model 2. go to settings tab, 3. check BOTH "signed mode (using server) 4 , "patch otp<>gdfs check in firmware 5 enable alternative security bypass 6 unlock after flash then go back to sony ericsson and click on flash |
05-21-2008, 08:45 | #5 (permalink) |
Member: 476287 Status: Offline Sonork: 100.1587961 Thanks Meter: 834 | second phone done color silver this is the log the other one is black SIGNED MODE (USING SERVER). ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35975701579381 CERT:RED FLASH CID:53 COLOR:RED Model:K800i Brand:O2 UK prepay MAPP CXC article: R8BF003 prgCXC1250210_GENERIC_WI MAPP CXC version: R8BF003 Language Package:EUROPE_2 CDA article: CDA102511/100 CDA version: R9A Default article: cxc1250490 Default version: R8BF003 PROVIDER: 234-10 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 7 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35975701579381 CERT:RED FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:2019 Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM164 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 Trying to launch embedded bootloader... INT LDRB2020_PRELOADER_FOR_SETOOL2 Flash ID check:2019 Flash props sent ok FOUND: R8BF003_CXC1250210_GENERIC_WI Restore from:R8BF003_CXC1250210_GENERIC_WI Searching... IMEI handler determined. IMEI change not allowed in program settings. full sig complete. USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. Unlock DONE Elapsed: 235 secs. |
Video Unlock Db2020 Cid53 With Setool | Aishur | SETool2 | 48 | 12-07-2011 06:12 |
Video Unlock Db2020 Cid53 With Setool | Aishur | SETool2 | 10 | 08-21-2008 05:07 |
DBSS v3.2. DB2020 CID53 Standalone permanent unlock & GDFS repair | GSM Dream | DreamBox | 65 | 04-30-2008 07:58 |
DB2020 CID53 unlocking no box needed (for non box owner) | reactos | Sony Ericsson | 17 | 04-01-2008 12:30 |
