Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 11-20-2017, 12:22   #76 (permalink)
Member: 1468634
Thanks Meter: 15
thanksss amigo 100*100
Old 11-20-2017, 13:16   #77 (permalink)
Member: 789344
Thanks Meter: 8
can not login to support forum
# Copyright (c) 1993-2009 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
#      102.54.94.97     rhino.acme.com          # source server
#       38.25.63.10     x.acme.com              # x client host
# localhost name resolution is handled within DNS itself.
#    127.0.0.1       localhost
#    ::1             localhost
192.162.139.82 setool.net
192.162.139.82 support.setool.net
192.162.139.82 files.setool.net
i had change it, still can,t access to support
i use pc with win7 64bit
help pleasse
Old 11-20-2017, 14:50   #78 (permalink)
Member: 689942
Thanks Meter: 312
Originally Posted by noure30 View Post
just copy this file hosts to path C:\Windows\System32\drivers\etc ...
or edit manually your hosts and put :
without #
Thanks for solution...100%%%
The Following User Says Thank You to celltellpb For This Useful Post:
Old 11-20-2017, 18:18   #79 (permalink)
Member: 1713296
Thanks Meter: 67
how to edit in windows 7 32 bit, its not working or saving file in host,
Old 11-21-2017, 02:16   #80 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
How can we access via mobile ?
Sent from my iPhone X
Old 11-21-2017, 05:26   #81 (permalink)
Member: 342298
Thanks Meter: 5
not work for me
not work for me this solution, please help me...
Old 11-21-2017, 15:47   #82 (permalink)
Member: 1026122
Sonork: 100.1640842
Thanks Meter: 184
please search "host" file location
eg: in windows xp c/windows/system32/drivers/etc
like that check the file location and open it on notepad
then add in the last line
save and restart the computer
Thats it
The Following User Says Thank You to sky_finder For This Useful Post:
Old 11-21-2017, 15:49   #83 (permalink)
Member: 1026122
Sonork: 100.1640842
Thanks Meter: 184
go to the property and add full control permission for every one
Tx
Old 11-22-2017, 08:22   #84 (permalink)
Member: 2781311
thanks for the host file,now it work
Old 11-22-2017, 10:16   #85 (permalink)
Member: 718848
Thanks Meter: 3
i tested it on win7 32 and win xp its not working for me and support file not opening
Old 11-22-2017, 12:26   #86 (permalink)
\/\/imran's Avatar
Member: 1178314
Sonork: 100.1603064
Thanks Meter: 891
Host file edit solution .
(1) Press the Windows key.
(2) Type Notepad in the search field.
(3) In the search results, right-click Notepad and select Run as administrator.
(4) From Notepad, open the following file:
c:\Windows\System32\Drivers\etc\hosts
(5) Make the necessary changes to the file.
(6) Click File > Save to save your changes.
The Following 4 Users Say Thank You to \/\/imran For This Useful Post:
Old 11-22-2017, 15:08   #87 (permalink)
Member: 839770
Thanks Meter: 24
Originally Posted by the_laser View Post
server IP changed, i don't know when DNS records will be updated, meanwhile put following strings into your
"%windir%\System32\drivers\etc\hosts" file :
note, that you must run notepad or whatever text editor as administrator in order to save this file.
Thank you The Laser, all working well and no problem at all
Old 11-22-2017, 18:23   #88 (permalink)
sant's Avatar
Member: 339859
Thanks Meter: 21
thanks working....
Old 11-23-2017, 09:40   #89 (permalink)
Member: 718848
Thanks Meter: 3
not working for me why?my system is win7 32 and xp
Old 11-23-2017, 11:08   #90 (permalink)
noure30's Avatar
Member: 261437
Sonork: no
Thanks Meter: 922
The Following User Says Thank You to noure30 For This Useful Post:
Page generated in 0.37543 seconds with 10 queries
