11-20-2017, 13:16 | #77 (permalink) |
Insane Poster Join Date: Jun 2008
Member: 789344 Status: Offline Thanks Meter: 8 | can not login to support forum Code: # Copyright (c) 1993-2009 Microsoft Corp. # # This is a sample HOSTS file used by Microsoft TCP/IP for Windows. # # This file contains the mappings of IP addresses to host names. Each # entry should be kept on an individual line. The IP address should # be placed in the first column followed by the corresponding host name. # The IP address and the host name should be separated by at least one # space. # # Additionally, comments (such as these) may be inserted on individual # lines or following the machine name denoted by a '#' symbol. # # For example: # # 102.54.94.97 rhino.acme.com # source server # 38.25.63.10 x.acme.com # x client host # localhost name resolution is handled within DNS itself. # 127.0.0.1 localhost # ::1 localhost 192.162.139.82 setool.net 192.162.139.82 support.setool.net 192.162.139.82 files.setool.net i had change it, still can,t access to support i use pc with win7 64bit help pleasse |
11-21-2017, 15:47 | #82 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | please search "host" file location eg: in windows xp c/windows/system32/drivers/etc like that check the file location and open it on notepad then add in the last line 192.162.139.82 setool.net 192.162.139.82 support.setool.net 192.162.139.82 files.setool.net save and restart the computer Thats it |
The Following User Says Thank You to sky_finder For This Useful Post: |
11-22-2017, 12:26 | #86 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1178314 Status: Offline Sonork: 100.1603064 Thanks Meter: 891 | Host file edit solution . (1) Press the Windows key. (2) Type Notepad in the search field. (3) In the search results, right-click Notepad and select Run as administrator. (4) From Notepad, open the following file: c:\Windows\System32\Drivers\etc\hosts (5) Make the necessary changes to the file. (6) Click File > Save to save your changes. |
The Following 4 Users Say Thank You to \/\/imran For This Useful Post: |
11-22-2017, 15:08 | #87 (permalink) | |
Freak Poster Join Date: Aug 2008 Location: bandung, indonesia
Member: 839770 Status: Offline Thanks Meter: 24 | Quote:
Thank you The Laser, all working well and no problem at all | |
11-23-2017, 11:08 | #90 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Tunisia
Member: 261437 Status: Offline Sonork: no Thanks Meter: 922 | 192.162.139.82 setool.net 192.162.139.82 support.setool.net 192.162.139.82 files.setool.net |
The Following User Says Thank You to noure30 For This Useful Post: |
