03-30-2013, 04:37 | #1 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 330197 Status: Offline Thanks Meter: 19 | Setools Not Support Xperia E Dual C1605???? CARD SERIAL ********** USBFLASH DRIVER VERSION 03.00.00.00 SIGNED MODE (USING SERVER) CFG:100000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "R10D030" ACTIVE_COMP_AID : 0002 HWCONF_AID : 0002 LOADER_AID : 0002 BOOT_AID : 0002 FATAL ERROR [ SIN_header_verification_failed, err: 0019 ] error while uploading HDR block LOADER NOT STARTED FAILED TO SETUP PHONE Elapsed: 29 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... i select with st26 but flash failed.my phone can on.just pattern lock only |
04-18-2013, 12:34 | #5 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | you can use st21 as model for st23,st21i2 or vise versa you can use st26 as model for c150x, c160x or vise versa make sure you flashing all required files : app,elabel,fsp cdf is internal storage contents, flashing is only required if internal storage file system damaged beyond repair by OS tools. |
The Following 3 Users Say Thank You to the_laser For This Useful Post: |
11-22-2013, 19:38 | #6 (permalink) |
Freak Poster Join Date: Jul 2010
Member: 1356821 Status: Offline Thanks Meter: 85 | i have same probleme PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "R10D030" ACTIVE_COMP_AID : 0002 HWCONF_AID : 0002 LOADER_AID : 0002 BOOT_AID : 0002 FATAL ERROR [ SIN_header_verification_failed, err: 0019 ] error while uploading HDR block LOADER NOT STARTED FAILED TO SETUP PHONE Unlock FAILED Elapsed: 9 secs. |
11-22-2013, 19:58 | #7 (permalink) |
Member: 1356821 Status: Offline Thanks Meter: 85 | Cool this time work i have only change usb port 2.0 and try with a orginal sony cable to a usb port 3.0 and tatata the phone was unlocked SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "R10D030" ACTIVE_COMP_AID : 0002 HWCONF_AID : 0002 LOADER_AID : 0002 BOOT_AID : 0002 DEVICE ID: BCCB443BF273AF4DD4F6886EAFE31015DE8EDC41 FLASH ID: "0003/00000015" LOADER VERSION: "R5D030" PHONE IMEI : 35960805213719 Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1520] REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED WARMING UP ... CHECKING ROOT ACCESS ... GETTING ROOT ACCESS ... PROCESSING ... C1505 [7e466194] FINALIZING ... Unlock DONE Elapsed: 268 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED |
