06-18-2011, 10:36 | #1 (permalink) |
Freak Poster Join Date: Jan 2011
Member: 1482280 Status: Offline Sonork: 100.1600954 Thanks Meter: 23 | signature calculation not done,err: 144 Unlock FAILED RUNNING v 1.107/UNI CARD SERIAL 00058077 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 18/12 CARD COUNTERS: FLASH 226, UNLOCK 193 credits consumption for full signature unlock: S1 v1 4 credits ( OFFLINE ) S1 v2 10 credits ( OFFLINE ) S1 OPEN 6 credits ( AID 004 OFFLINE ) A1 phones 6 credits A2 phones 6 credits ( DO NOT USE FOR J108 ) by codes 4 credits current setool2 version: 1.107 Elapsed: 8 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110010000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,01248500961919] OTP LOCKED:1 CID:81 PAF:1 IMEI:01248500961919 CERT:RED ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE Unlock FAILED Elapsed: 14 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01248500961919 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... Waiting for calculation process... remote dongle not available signature calculation not done,err: 144 Unlock FAILED Elapsed: 19 secs. |
06-18-2011, 10:44 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | if s1 signature server offline, you can not use quick (without modem drivers) unlock. instead, you should : 1. select proper model 2. on settings, check "signed mode", "do full unlock instead usercode reset", "disable flash mode activation for semc a2 phones", fill login details 3. back to semc a2 tab, press unlock 4. when prompted, install phone modem drivers (they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite) 5. when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. you can not unlock last SEMC A2 phone ( j108 ) with CSCA method. you MUST flash r7cXXX firmware version to be able unlock w20 phone with CSCA method. WBR sahil2000ind |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
06-22-2011, 08:25 | #4 (permalink) | |
Member: 1482280 Status: Offline Sonork: 100.1600954 Thanks Meter: 23 | Quote:
ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01248500961919 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... Waiting for calculation process... remote dongle not available signature calculation not done,err: 144 Unlock FAILED Elapsed: 14 secs. | |
06-22-2011, 08:52 | #5 (permalink) | |
[dir]2011-Jan-13 r7da056[dir]2011-Jan-13 r7da058[dir]2010-Oct-11 r7da062[dir]2010-Nov-05 r7da063[dir]2010-Nov-05 r7da065[dir]2010-Dec-01 r7ea011 | |
09-19-2013, 07:27 | #8 (permalink) |
Freak Poster Join Date: Apr 2013 Location: China
Member: 1919721 Status: Offline Thanks Meter: 10 | RUNNING S1_BOOT VER "R10AM003" ACTIVE_COMP_AID : 0001 HWCONF_AID : 0001 LOADER_AID : 0001 BOOT_AID : 0001 DEVICE ID: A401ED08 FLASH ID: "0045/00000090" LOADER VERSION: "R5F001" PHONE IMEI : 353861xxxxxxxx MODEL (from GDFS): LT30p SOFTWARE VERSION: 1262-6309_9.1.A.1.141 CUSTOM VERSION: 1268-3194_R1I FILESYSTEM VERSION: GLOBAL-HSPA_9.1.A.1.141 Network LOCK : 23433-* Network LOCK : 23430-* Network LOCK : 23431-* SERIAL NO: YT9103969B Elapsed: 10 secs. RUNNING S1_BOOT VER "R10AM003" ACTIVE_COMP_AID : 0001 HWCONF_AID : 0001 LOADER_AID : 0001 BOOT_AID : 0001 DEVICE ID: A401ED08 FLASH ID: "0045/00000090" LOADER VERSION: "R5F001" PHONE IMEI : 353861xxxxxxxx Checking for signature ... Waiting for calculation process ... remote dongle not available signature calculation not done,err: 144 Unlock FAILED Elapsed: 14 secs. |
09-19-2013, 08:44 | #9 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | NEW SONY PHONES UNLOCKING NOT SUPPORTED WITHOUT S1 SERVER S1 SERVER IS OFFLINE FOR ALL USERS ALSO U CAN TRY TO BUY ONLINE UNLOCKING CODE WBR sahil2000ind |
09-19-2013, 09:03 | #10 (permalink) | |
Member: 1919721 Status: Offline Thanks Meter: 10 | Try to Quote:
i got this lt30p wich setool has it in the list and i got credits spend a lot of money for this box and credtis also still dissapointed... When S1 will be again online? | |
09-19-2013, 09:08 | #11 (permalink) |
Member: 1919721 Status: Offline Thanks Meter: 10 | so basicly in this gsm world WITH box BOUGHT for 150$ + Activations + Credits spent another 75$ to unjoy unlocking We need an active moderator to announce this definive offline S1_ SO WE WONT F@KING buy credits next time~~~ |
09-19-2013, 09:11 | #12 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | U CAN USE CREDITS FOR OTHER OPERATIONS ALSO Code: short credits consumption list : Services OFFLINE S1 v1 xx credits S1 v2 xx credits S1 OPEN AID 004 xx credits CID81 A2 phones, FLASHMODE activation way xx credits Services ONLINE A1 phones 03 credits S1 OPEN 03 credits A2 phones, CSCA way 03 credits S1 v2 alternative bypass unlock/repair 01 credits S1 v2 alternative bypass STANDALONE activation 10 credits W100,W150 codes 01 credits You CAN NOT unlock next phones without S1 server: u1/u5/u8 aid 004, LoCosto,Neptune-based phones with damaged security zone, LoCosto,Neptune-based phones with loader AID 004, w100,w150 full unlock,ck13,ck15,wt13, any SONY phone, released from 2012 year current updater version: 0.95 current setool2 version: 1.1301 SERVER CREDITS LEFT/USED: 20/10 CARD COUNTERS: FLASH 449, UNLOCK 325 Elapsed: 8 secs. WBR sahil2000ind |
07-22-2014, 19:59 | #15 (permalink) |
Junior Member Join Date: May 2014
Member: 2187483 Status: Offline Thanks Meter: 1 | OTP: LOCKED:1 CID:81 PAF:1 IMEI:01248500658781 CERT:RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... Waiting for calculation process ... request denied. signature calculation not done,err: 144 Unlock FAILED j108i |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
