02-27-2014, 06:19 | #1 (permalink) | ||
Freak Poster Join Date: Jun 2007 Location: Philippines
Member: 536359 Status: Offline Sonork: 100.1654663 Thanks Meter: 57 | SO-03C Xperia Ray ( Unlocked ) SO-03C ( Xperia Ray ) unlocked procedure 1) SETOOL must be ( ACTIVATED ) 2) open ( SETOOL ) SOFTWARE 3) select ( PDA ) tab 4) select ( ST18_RAY ) ( Phone Type: ) 5) select Settings ( Check 1, 2, 5, 11 ) 6) back to ( PDA ) tab 7) connect ( TESTPOINT ) install ( Driver ) if needed 8) tick ( Unlock/Repair ) 9) follow instructions Quote:
04-23-2014, 15:51 | #3 (permalink) | |
Freak Poster Join Date: Aug 2007 Location: 2697b03f Age: 43
Member: 568700 Status: Offline Thanks Meter: 52 | Quote:
ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110000010 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" qcReceivePacket: can't get packet start. IF TESTPOINT DONE OK,THIS IS NOT SUPPORTED MCU REVISION FAILED TO SETUP PHONE Unlock FAILED Elapsed: 40 secs. HELP ME | |
