03-12-2009, 19:56 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: London
Member: 722656 Status: Offline Sonork: 100.1584918 Thanks Meter: 294 | solve "loader GDFS startup failed, that is fatal" now how i fixed these phone??? very easy just use the old version of software like V0.914035 and identify it. and the problem is solved. so try it and post result if it works for you so that your other friends dont need to go through TP which is not easy. hope works for all of you as well......... 3/12/2009 3:19:11 PM v0.915034/UNI 3/12/2009 3:19:11 PM CARD SERIAL: 00086217 3/12/2009 3:19:11 PM Loaded 51 flash descriptors 3/12/2009 3:19:23 PM Open COM port OK 3/12/2009 3:19:33 PM PROCEDURE WAS STOPPED BY USER 3/12/2009 3:19:33 PM Can't load ID loader ! 3/12/2009 3:19:33 PM Elapsed: 10 secs. 3/12/2009 3:20:00 PM ChipID:9900,EMP protocol:0301 3/12/2009 3:20:00 PM 3/12/2009 3:20:00 PM PHONE STATE: "RETAIL" 3/12/2009 3:20:00 PM FLASH CID: 0052 3/12/2009 3:20:00 PM Speed:115200 3/12/2009 3:20:00 PM Flash ID check:897E 3/12/2009 3:20:00 PM Flash props sent ok 3/12/2009 3:20:01 PM OTP: LOCKED:1 CID:51 PAF:1 IMEI:3xxxxxxxxxxxxxxxx CERT:RED 3/12/2009 3:20:01 PM FLASH CID:52 COLOR:RED 3/12/2009 3:20:31 PM no ack during gdfs_readvar ! 3/12/2009 3:20:31 PM SCRC READ FAILURE 3/12/2009 3:20:31 PM Elapsed: 44 secs. 3/12/2009 3:22:55 PM Processing script "D:\Softwears\1 unlocking drivers backup\setool V41\v0.915016\v0.915034\gdfs_in_ssw_format\db2020\ W880_GDFS_SSW.ssw"... 3/12/2009 3:22:57 PM PROCEDURE WAS STOPPED BY USER 3/12/2009 3:22:57 PM FAILED TO SETUP PHONE 3/12/2009 3:22:57 PM Elapsed: 2 secs. 3/12/2009 3:23:32 PM Will write GDFS now. 3/12/2009 3:23:39 PM PROCEDURE WAS STOPPED BY USER 3/12/2009 3:23:39 PM FAILED TO SETUP PHONE 3/12/2009 3:23:39 PM Elapsed: 6 secs. 3/12/2009 3:24:18 PM SIGNED MODE (USING SERVER) 3/12/2009 3:24:23 PM ChipID:9900,EMP protocol:0301 3/12/2009 3:24:24 PM 3/12/2009 3:24:24 PM PHONE STATE: "RETAIL" 3/12/2009 3:24:24 PM FLASH CID: 0052 3/12/2009 3:24:24 PM Speed:115200 3/12/2009 3:24:24 PM Flash ID check:897E 3/12/2009 3:24:24 PM Flash props sent ok 3/12/2009 3:24:24 PM OTP: LOCKED:1 CID:51 PAF:1 IMEI:3xxxxxxxxxxxxxxxxxx CERT:RED 3/12/2009 3:24:24 PM FLASH CID:52 COLOR:RED 3/12/2009 3:24:54 PM no ack during gdfs_readvar ! 3/12/2009 3:24:54 PM SCRC READ FAILURE 3/12/2009 3:24:54 PM Elapsed: 36 secs. 3/12/2009 3:57:05 PM Will backup GDFS now. 3/12/2009 3:57:11 PM PROCEDURE WAS STOPPED BY USER 3/12/2009 3:57:11 PM FAILED TO SETUP PHONE 3/12/2009 3:57:12 PM Elapsed: 6 secs. 3/12/2009 3:57:15 PM Will backup GDFS now. 3/12/2009 3:57:20 PM ChipID:9900,EMP protocol:0301 3/12/2009 3:57:20 PM 3/12/2009 3:57:20 PM PHONE STATE: "RETAIL" 3/12/2009 3:57:20 PM FLASH CID: 0052 3/12/2009 3:57:20 PM Speed:921600 3/12/2009 3:57:20 PM OTP: LOCKED:1 CID:51 PAF:1 IMEI:3xxxxxxxxxxxxxxxxxx CERT:RED 3/12/2009 3:57:20 PM FLASH CID:52 COLOR:RED 3/12/2009 3:57:21 PM PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 3/12/2009 3:57:22 PM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 3/12/2009 3:57:22 PM Flash ID check:897E 3/12/2009 3:57:22 PM Flash props sent ok 3/12/2009 3:57:22 PM phone CID not supported in that mode 3/12/2009 3:57:22 PM Elapsed: 6 secs. 3/12/2009 3:57:29 PM SIGNED MODE (USING SERVER) 3/12/2009 3:57:29 PM Will backup GDFS now. 3/12/2009 3:57:38 PM ChipID:9900,EMP protocol:0301 3/12/2009 3:57:38 PM 3/12/2009 3:57:38 PM PHONE STATE: "RETAIL" 3/12/2009 3:57:38 PM FLASH CID: 0052 3/12/2009 3:57:38 PM Speed:921600 3/12/2009 3:57:38 PM OTP: LOCKED:1 CID:51 PAF:1 IMEI:3xxxxxxxxxxxxxxx CERT:RED 3/12/2009 3:57:38 PM FLASH CID:52 COLOR:RED 3/12/2009 3:57:39 PM PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 3/12/2009 3:57:39 PM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 3/12/2009 3:57:39 PM Flash ID check:897E 3/12/2009 3:57:39 PM Flash props sent ok 3/12/2009 3:57:42 PM LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 3/12/2009 3:57:42 PM loader startup: executed 3/12/2009 3:57:42 PM GDFS startup failed (1D) 3/12/2009 3:57:42 PM loader GDFS startup failed, that is fatal 3/12/2009 3:57:42 PM Elapsed: 12 secs. 3/12/2009 3:58:03 PM SIGNED MODE (USING SERVER) 3/12/2009 3:58:03 PM ALTERNATIVE SECURITY BYPASS ENABLED. 3/12/2009 3:58:03 PM PRELOADER SECURITY BYPASS ENABLED. 3/12/2009 3:58:03 PM Will backup GDFS now. 3/12/2009 3:58:13 PM ChipID:9900,EMP protocol:0301 3/12/2009 3:58:13 PM 3/12/2009 3:58:13 PM PHONE STATE: "RETAIL" 3/12/2009 3:58:13 PM FLASH CID: 0052 3/12/2009 3:58:13 PM Speed:921600 3/12/2009 3:58:14 PM OTP: LOCKED:1 CID:51 PAF:1 IMEI:3xxxxxxxxxxxxxxxxxxx CERT:RED 3/12/2009 3:58:14 PM FLASH CID:52 COLOR:RED 3/12/2009 3:58:14 PM PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 3/12/2009 3:58:15 PM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 3/12/2009 3:58:15 PM Flash ID check:897E 3/12/2009 3:58:15 PM Flash props sent ok 3/12/2009 3:58:17 PM LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 3/12/2009 3:58:17 PM loader startup: executed 3/12/2009 3:58:17 PM GDFS startup failed (1D) 3/12/2009 3:58:17 PM loader GDFS startup failed, that is fatal 3/12/2009 3:58:17 PM Elapsed: 14 secs. 3/12/2009 4:00:03 PM SIGNED MODE (USING SERVER) 3/12/2009 4:00:03 PM ALTERNATIVE SECURITY BYPASS ENABLED. 3/12/2009 4:00:03 PM PRELOADER SECURITY BYPASS ENABLED. 3/12/2009 4:00:03 PM Processing script "C:\Documents and Settings\abc\Desktop\Read_Security_Units.txt"... 3/12/2009 4:00:12 PM ChipID:9900,EMP protocol:0301 3/12/2009 4:00:13 PM 3/12/2009 4:00:13 PM PHONE STATE: "RETAIL" 3/12/2009 4:00:13 PM FLASH CID: 0052 3/12/2009 4:00:13 PM Speed:921600 3/12/2009 4:00:13 PM OTP: LOCKED:1 CID:51 PAF:1 IMEI:3xxxxxxxxxxxxxxxx CERT:RED 3/12/2009 4:00:13 PM FLASH CID:52 COLOR:RED 3/12/2009 4:00:14 PM PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 3/12/2009 4:00:14 PM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 3/12/2009 4:00:14 PM Flash ID check:897E 3/12/2009 4:00:14 PM Flash props sent ok 3/12/2009 4:00:16 PM LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 3/12/2009 4:00:16 PM loader startup: executed 3/12/2009 4:00:16 PM GDFS startup failed (1D) 3/12/2009 4:00:16 PM loader GDFS startup failed, that is fatal 3/12/2009 4:00:17 PM Elapsed: 13 secs. logs from old version of software: 3/12/2009 6:11:37 PM v0.914035/UNI 3/12/2009 6:11:37 PM CARD SERIAL: 00086217 3/12/2009 6:11:37 PM Loaded 51 flash descriptors 3/12/2009 6:11:51 PM ChipID:9900,EMP protocol:0301 3/12/2009 6:11:51 PM 3/12/2009 6:11:51 PM PHONE IS RED RETAIL PRODUCT 3/12/2009 6:11:51 PM FLASH CID detected:52 3/12/2009 6:11:51 PM Speed:921600 3/12/2009 6:11:51 PM Flash ID check:897E 3/12/2009 6:11:51 PM Flash props sent ok 3/12/2009 6:11:51 PM OTP LOCKED:1 CID:51 PAF:1 IMEI:35777401413227 CERT:RED 3/12/2009 6:11:51 PM FLASH CID:52 COLOR:RED 3/12/2009 6:11:53 PM 3/12/2009 6:11:53 PM Model:W880i 3/12/2009 6:11:53 PM MAPP CXC article: R6BC002 prgCXC1250640_GENERIC_AI 3/12/2009 6:11:53 PM MAPP CXC version: R6BC002 3/12/2009 6:11:53 PM Language Package:MEDITERR 3/12/2009 6:11:53 PM CDA article: CDA123456/123 3/12/2009 6:11:53 PM CDA version: R2A 3/12/2009 6:11:53 PM Default article: cxc1250651 3/12/2009 6:11:53 PM Default version: R6BC002 3/12/2009 6:11:53 PM PROVIDER: 000-00 3/12/2009 6:11:53 PM SIMLOCKS NOT DETECTED 3/12/2009 6:11:53 PM 3/12/2009 6:11:53 PM RESTORATION FILE NOT PRESENT 3/12/2009 6:11:53 PM "R6BC002_CXC1250640_GENERIC_AI" 3/12/2009 6:11:53 PM YOU MUST PERFORM FULL FLASHING 3/12/2009 6:11:53 PM WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED 3/12/2009 6:11:53 PM 3/12/2009 6:11:53 PM BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE 3/12/2009 6:11:53 PM 3/12/2009 6:11:53 PM SECURITY UNITS BACKUP CREATED. 3/12/2009 6:11:53 PM Elapsed: 7 secs. and the phone is working like a charm have fun |
The Following 15 Users Say Thank You to sniper007 For This Useful Post: |
03-14-2009, 08:01 | #9 (permalink) |
No Life Poster Join Date: Nov 2008 Location: UAE
Member: 890592 Status: Offline Sonork: 100.1581951 Thanks Meter: 4,429 | Here Se Tools Version v0.914035 Download link.. http://rapidshare.com/files/12178576..._v0.914035.rar |
03-14-2009, 08:26 | #10 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 334773 Status: Offline Thanks Meter: 92 | sir im using this version only v0.914035. but same complaint only plz help me v0.914035/UNI CARD SERIAL: 00092716 Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35726502502986 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed Loader refused to start GDFS services,error is:29 loader GDFS startup failed, that is fatal Elapsed: 9 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35726502502986 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed Loader refused to start GDFS services,error is:29 loader GDFS startup failed, that is fatal Elapsed: 8 secs. |
03-14-2009, 08:36 | #11 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: In my body
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | Quote:
03-14-2009, 08:40 | #13 (permalink) |
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | Tested & worked 100% ..... v0.914035/UNI CARD SERIAL: xxxxxxxxxx Loaded 51 flash descriptors Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35469101023452 CERT:RED FLASH CID:49 COLOR:RED Model:K510i MAPP CXC article: R4EA031 prgCXC1250231_GENERIC_CO MAPP CXC version: R4EA031 Language Package:S_ASIA_LEVAN CDA article: CDA102459/110 CDA version: R3A Default article: cxc1250246 Default version: R4EA031 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE NOT PRESENT "R4EA031_CXC1250231_GENERIC_CO" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Links here, http://www.4shared.com/get/52148690/...79457D595.dc90 http://rapidshare.com/files/12185499..._v0.914035.exe BR. |
loader GDFS startup failed, that is fatal | abuzarkhurram | SETool2 | 18 | 07-18-2009 14:36 |
K550 cannot flash show me " loader fs startup failed, that is fatal" | svchost | SETool2 | 3 | 03-04-2009 17:37 |
Cannot flash K800i "loader fs startup failed, that is fatal"???? | svchost | SETool2 | 5 | 01-17-2009 02:11 |
w830 gdfs startup failed,that is fatal | kirta | SETool2 | 3 | 01-09-2009 10:02 |
FIXED ~loader GDFS startup failed, that is fatal~ | TDKI | SETool2 | 6 | 09-26-2008 13:51 |
