Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 05-18-2010, 15:43   #31 (permalink)
Registered User
Member: 1026187
Sonork: 1585394
Thanks Meter: 46
hi dear friend ...
i have problem wih muy w910i the problem (no net work coverge )i flash the phone but no response will get out me from this problem
br
shahab sadi
Old 05-18-2010, 16:50   #32 (permalink)
roney_nexus's Avatar
Member: 288504
Sonork: .:100.1587032:.
Thanks Meter: 2,266
Originally Posted by Muneer_killer View Post
hi dear friend ...
br
shahab sadi
bro how to coming this pb (no net work coverge )
read FAQ all details there
thx...
Old 05-19-2010, 10:38   #33 (permalink)
sonu arya's Avatar
Member: 559113
Sonork: 100.1596477
Thanks Meter: 760
how i can use setool2 smartcard tool
For registration
card serial 000xxxxx
got username dummy
activation error : bad username/password
Old 05-19-2010, 14:35   #34 (permalink)
Member: 288504
Thanks Meter: 2,266
For registration
got username dummy
How To Activate SETOOL Smart Card
Old 05-19-2010, 16:35   #35 (permalink)
romeoluv56's Avatar
Member: 1170910
Thanks Meter: 76
I have k790i white display blinking & restart after few seconds
Flash many times using deferent files but no result...
SIGNED MODE (USING SERVER)
CFG:101000000000
ChipID:9900,EMP protocol:0301
BOOTROM MODE DETECTED
Speed:921600
OTP LOCKED:1 CID:51 PAF:1 IMEI:35220601802742
ACTIVE CID:52 COLOR:RED
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015
FLASH ID: 897E
writing "D:\D\Backup\SEtool DVD 1\Flash Files\K790\cid52\r8bf003\R8BF003_1250477_GENERIC_E V.ssw"
CURRENT FLASH FILE CID:52
SSW uses full hash, hash len is: 9200
Will flash 460 blocks...
writing "D:\D\Backup\SEtool DVD 1\Flash Files\K790\cid52\r8bf003\R8BF003_FS_S_ASIA_LEVAN_E V_RED_CID52.ssw"
SSW uses full hash, hash len is: 4580
Will flash 229 blocks...
LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
loader GDFS startup executed
loader FILESYSTEM startup executed
using GENERIC phone customization
tpa/preset/custom/C3_PCA_G3v2.cer
tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
tpa/preset/custom/customize.xml
tpa/preset/custom/DESKTOP_HOOK_2.itm
tpa/preset/custom/Entrust.net Root Certificate.cer
tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
tpa/preset/custom/FM_PICTURES_HOOK_3.itm
tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
tpa/preset/custom/FM_THEMES_HOOK_3.itm
tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
tpa/preset/custom/GAMES_HOOK_3.itm
tpa/preset/custom/GTE_CyberTrust_Root.cer
tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
tpa/preset/custom/Root.cer
tpa/preset/custom/SEMC_E2E_Root_CA.crt
tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
tpa/preset/custom/ThawtePremium.der
tpa/preset/custom/ThawteServerCA.cer
tpa/preset/custom/Utiroot.cer
tpa/preset/custom/VeriSignClass3Root.cer
tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
Phone detached
Elapsed: 533 secs.
After that i put the phone in recovery mode now phone doesnt boot, please help
best regards
Old 05-19-2010, 19:49   #36 (permalink)
Member: 288504
Thanks Meter: 2,266
best regards
must be chk for HW display & display flex etc.......
thx........
Old 05-19-2010, 23:07   #37 (permalink)
Member: 1307259
http://forum.gsmhosting.com/vbb/f30/...oblem-1004100/
Hi, I have been scouring the net for some time in search of an answer to this problem and finally decided to ask for help.
I have a W300i with broken 1, 2 and 3 buttons on the keypad.
This wouldn't be a huge problem (it just needs to be able to receive calls and operate as a Walkman) except that the phone lock code contains the number 3.
Is there anything I can do to change/reset the user code? I have tried various de-branding and unlocking techniques to no avail.
Thanks in advance
Old 05-20-2010, 06:13   #38 (permalink)
romeoluv56's Avatar
Member: 1170910
Thanks Meter: 76
thx........
but now the phone in recovery mode and phone now dont boot at all ?
Old 05-20-2010, 06:49   #39 (permalink)
Member: 288504
Thanks Meter: 2,266
u can service it & try again same to result i think hw pb thx......
Old 05-20-2010, 11:37   #40 (permalink)
mediapeople's Avatar
Member: 759477
Sonork: 100.1618763
Thanks Meter: 111
Bro help me unlock k 610 im cid 52 3 written on phone triyed with another flashes but error in unlock b coz bypass package not present for this phone what to do to make it unlock? confused
Old 05-20-2010, 13:16   #41 (permalink)
Member: 288504
Thanks Meter: 2,266
standalone patch unlock method via alternative security bypass
1. select com/ufs/usb as interface
2. go to semc tab
3. select correct model
4. on settings tab, check "signed mode","alternative security bypass", "preloader security bypass"
5. back on semc tab
6. press unlock button
you can not use that method , if SCRC damaged ( IMEI mismatch in IDENTIFY output )
restoration files required for that method.
bypass packages required for that method.
please read FAQ post about alternative security bypass.
Old 05-20-2010, 13:28   #42 (permalink)
saeed ahmed's Avatar
Member: 997212
Sonork: 100.1590912
Thanks Meter: 42
how to unlock sony errircson without sim card its possible yes or no? then yes, how to unlock without sim or Motorola test card i have only setool
Old 05-20-2010, 13:40   #43 (permalink)
Member: 646256
Thanks Meter: 63
1 make identify and remember the flash cid (not otp cid)
2 goto empty fill tab and perform recovery ( setting signed mode)
3 flash the corresponding erom convertion to cid in 1 (setting none)
Old 05-20-2010, 14:08   #44 (permalink)
Member: 288504
Thanks Meter: 2,266
yes possible bro......just full unlock......need 1 credit....
2. go to semc tab
4. on settings tab, check "signed mode","do full unlock instead usercode reset"
5. back on semc tab
that is recommended method for unlocking such phones.
you can not repair damaged SCRC via that method.
Old 05-20-2010, 14:13   #45 (permalink)
..::\/\/::..'s Avatar
Member: 1294131
Sonork: 16919899
Thanks Meter: 579
w580 belu disply plz help i m change disply
but sam problem
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.27342 seconds with 10 queries
