Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 02-23-2015, 19:02   #1 (permalink)
Member: 143851
Thanks Meter: 162
Wink Sony d2005 dead after flash ,solved
how?
after flash totally dead,not reconized in setool or pc compignon.
The solution is:
1 in setool choose the flash files (app fsp elabl) .
2. in settings check signed mode + alternative bypass
2. click flash then ready .
3. hold volume - and connect the phone and keep holding the volume down
until he ask for click ready agin
4. release vol down and click ready it shall start flashing the phone.
5. wait to finish then enjoy your phone alive again
The Following 4 Users Say Thank You to ak0101 For This Useful Post:
Old 04-18-2015, 07:35   #2 (permalink)
tarunvishal's Avatar
Member: 308296
Thanks Meter: 152
its want qhsusb_bulk driver and not connect with setool
plz give me the solution
Thx in advance
The Following User Says Thank You to tarunvishal For This Useful Post:
Old 04-18-2015, 09:16   #3 (permalink)
Member: 308296
Thanks Meter: 152
ii solve this proble with this driver in setool
The Following 2 Users Say Thank You to tarunvishal For This Useful Post:
Old 05-27-2015, 13:42   #4 (permalink)
Member: 265098
Thanks Meter: 7
Originally Posted by ak0101 View Post
how?
The solution is:
thnx for the solution
The Following 3 Users Say Thank You to anoopme For This Useful Post:
Old 05-28-2015, 01:56   #5 (permalink)
Member: 520296
Thanks Meter: 7
thnx for the solution work 1000%
The Following 2 Users Say Thank You to faris2010 For This Useful Post:
Old 06-16-2015, 16:16   #6 (permalink)
Member: 125632
Thanks Meter: 233
do not use latest setool to flash this phone,,,it will make brick..that is v1.1418
i used v1.1408 worked great
RUNNING v 1.1408/01.13/UNI
CARD SERIAL 0001xxxx
USBFLASH DRIVER VERSION 02.02.00.05
SIGNED MODE (USING SERVER)
ALTERNATIVE SECURITY BYPASS ENABLED
CFG:110000000000
PLEASE ATTACH TURNED OFF PHONE NOW
PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ...
RUNNING S1_BOOT VER "S1_Boot_MSM8x10_0.45"
ACTIVE_COMP_AID : 0004
HWCONF_AID : 0004
LOADER_AID : 0004
BOOT_AID : 0004
DEVICE ID: 0585FE7C
FLASH ID: "0003/00000015"
LOADER VERSION: "MSM8X10_12"
PHONE IMEI : 355628064xxxxx
writing "N:\SETOOL\Flashes\SONY\D2005_Xperia_E1\20.1.A.0.4 7\20_1_A_0_47.APP_SW_FalconSS_GENERIC_1277_8886_S1 _SW_LIVE_B578_PID ...
Processing package
N:\SETOOL\Flashes\SONY\D2005_Xperia_E1\20.1.A.0.47 \20_1_A_0_47.APP_SW_FalconSS_GENERIC_1277_8886_S1_ SW_LIVE_B578_PID1_0005_MMC.S ...
BOOT UPDATE NOT REQUIRED
Processing ACPU files
PROCESSING: cache_S1-SW-LIVE-B578-PID1-0005-MMC.sin
PROCESSING: kernel_S1-SW-LIVE-B578-PID1-0005-MMC.sin
PROCESSING: fotakernel_S1-SW-LIVE-B578-PID1-0005-MMC.sin
SKIP: partition-image_S1-SW-LIVE-B578-PID1-0005-MBR.sin
no update files in package
writing "N:\SETOOL\Flashes\SONY\D2005_Xperia_E1\20.1.A.0.4 7\20_1_A_0_47.FSP_FalconSS_WORLD_i_1280_6712_S1_SW _LIVE_B578_PID1_0 ...
Processing package
N:\SETOOL\Flashes\SONY\D2005_Xperia_E1\20.1.A.0.47 \20_1_A_0_47.FSP_FalconSS_WORLD_i_1280_6712_S1_SW_ LIVE_B578_PID1_0005_MMC.R5B. ...
PROCESSING: userdata_S1-SW-LIVE-B578-PID1-0005-MMC.sin
PROCESSING: system_S1-SW-LIVE-B578-PID1-0005-MMC.sin
PROCESSING: amss_fs_1_S1-MODEMSW-LIVE-B578-PID1-0005-MMC.sin
PROCESSING: amss_fs_2_S1-MODEMSW-LIVE-B578-PID1-0005-MMC.sin
PROCESSING: amss_fsg_S1-MODEMSW-LIVE-B578-PID1-0005-MMC.sin
Processing update files
PROCESSING: cust-reset.ta
Writing TA unit 0002/08A4/000E
SKIP: simlock.ta
writing "N:\SETOOL\Flashes\SONY\D2005_Xperia_E1\20.1.A.0.4 7\20_1_A_0_47.ELABEL_FalconSS_elabel_d2005_row.201 403122110_1.SIN_F ...
Processing package
N:\SETOOL\Flashes\SONY\D2005_Xperia_E1\20.1.A.0.47 \20_1_A_0_47.ELABEL_FalconSS_elabel_d2005_row.2014 03122110_1.SIN_FILE_SET
PROCESSING: elabel-D2005-row_201403122110.1_20.1.A.0.47_S1-ELABEL-LIVE-B578-PID1-0004-MMC.sin
Elapsed: 699 secs.
The Following 2 Users Say Thank You to bcatlock1 For This Useful Post:
Old 06-16-2015, 18:44   #7 (permalink)
faizan15's Avatar
Member: 323959
Sonork: 100.1613721
Thanks Meter: 79
not work for me
CFG:110000000000
DETACH USB CABLE FROM PHONE
REMOVE BATTERY FROM PHONE
ATTACH TESTPOINT
PRESS "READY", THEN ATTACH USB CABLE TO PHONE
will use SAHARA protocol ...
REMOVE TESTPOINT NOW, THEN PRESS "READY"
PROCESSING ...
SERIAL NUMBER : 57B7D606
HARDWARE ID : 04000100E1108100
PRODUCT DETECTED: "MSM8210 OEM1 fused"
HASH :5A93232B8EF5567752D0CB5554835215D1C473502E6F1052A 78A6715B8B659AA
RUNNING S1_PRELOADER VER "MSM8X10_10"
HWCONF_AID : 0004
LOADER_AID : 0004
BOOT_AID : 0004
DEVICE ID: 06D6B757
FLASH ID: "0090/014A0005"
LOADER VERSION: "MSM8X10_10"
Can't get IMEI
writing "C:\Documents and Settings\Administrator\My Documents\Downloads\D2005\20_1_A_0_47\20_1_A_0_47. ELABEL_FalconSS_elabel_ ...
Processing package
C:\Documents and Settings\Administrator\My Documents\Downloads\D2005\20_1_A_0_47\20_1_A_0_47. ELABEL_FalconSS_elabel_d2005_ph.201 ...
PROCESSING: elabel-D2005-ph_201403041200.1_20.1.A.0.47_S1-ELABEL-LIVE-B578-PID1-0004-MMC.sin
MINOR ERROR [ FAC_CORE_SECMGR_-_ERR_ROOT_CERT_TYPE_CHECK, err: 0017 ]
error while uploading final HDR block
Break.
Elapsed: 22 secs.
The Following 2 Users Say Thank You to faizan15 For This Useful Post:
Old 07-04-2015, 23:29   #8 (permalink)
Member: 716894
Thanks Meter: 18
RUNNING v 1.1413/01.15/UNI
CARD SERIAL 00044831
CFG:110000000000
ATTACH TESTPOINT
PROCESSING ...
SERIAL NUMBER : 9CCE3005
HWCONF_AID : 0004
LOADER_AID : 0004
BOOT_AID : 0004
DEVICE ID: 0530CE9C
FLASH ID: "0015/01000001"
PHONE IMEI : 35384906926079
writing "D:\sony ericson\d2005\20_1_A_2_19.APP_SW_FalconSS_GENERIC_ 1277_8886_S1_SW_LIVE_B578_PID1_0005_MMC.SIN_FILE_S ET"
Processing package
WILL UPDATE BOOT TO : S1_BOOT_MSM8X10_0.45
PARSING: "DEVELOPMENT"
value OTP_LOCK_STATUS_1 : UNLOCKED, not match LOCKED
PARSING: "TEST_OEM0_008110E1"
value OTP_LOCK_STATUS_1 : LOCKED, match LOCKED
value OTP_DATA_1 : 00000100, not match 01000400
value IDCODE_1 : 008110E1, match 008110E1
PARSING: "PRECOMMERCIAL_008110E1"
value OTP_DATA_1 : 01000400, match 01000400
PROCESSING : dbi_S1-BOOT-TEST-B316-0001-MMC_PLATFORM-MSM8210-LIVE-HWID008110E1-SWID12-OEM1-AID4-DEBUG00_S1-BOOT-LIVE-B578-0004-M ...
PROCESSING : emmc_appsboot_S1-BOOT-TEST-B316-0001-MMC_PLATFORM-MSM8210-LIVE-HWID008110E1-SWID09-OEM1-AID4-DEBUG00_S1-BOOT-LIVE-B ...
PROCESSING : rpm_S1-RPMFW-TEST-B316-0001-MMC_PLATFORM-MSM8210-LIVE-HWID008110E1-SWID0A-OEM1-AID4-DEBUG00_S1-RPMFW-LIVE-B578-PID1 ...
PROCESSING : sbl1_PLATFORM-MSM8210-LIVE-HWID008110E1-SWID65-OEM1-AID4-DEBUG00_PLATFORM-MSM8210-LIVE-HWID008110E1-SWID00-OEM1-AID ...
PROCESSING : tz_S1-BOOT-TEST-B316-0001-MMC_PLATFORM-MSM8210-LIVE-HWID008110E1-SWID07-OEM1-AID4-DEBUG00_S1-BOOT-LIVE-B578-0004-MM ...
PROCESSING : Falcon_S1BootConfig_MiscTA_130820_1730.ta
Writing TA unit 0002/084F/003C
Writing TA unit 0002/08FD/0001
BOOT UPDATED
writing "D:\sony ericson\d2005\20_1_A_2_19.FSP_FalconSS_WORLD_i_128 0_0604_S1_SW_LIVE_B578_PID1_0005_MMC.R2B.SIN_FILE_ SET"
Processing package
SKIP: simlock.ta
Elapsed: 358 secs.
The Following 2 Users Say Thank You to lotfigsm2 For This Useful Post:
Old 09-29-2015, 21:22   #9 (permalink)
tattoum's Avatar
Member: 16625
Sonork: 1578753
Thanks Meter: 161
Originally Posted by faizan15 View Post
not work for me
CFG:110000000000
ATTACH TESTPOINT
PROCESSING ...
HWCONF_AID : 0004
LOADER_AID : 0004
BOOT_AID : 0004
DEVICE ID: 06D6B757
Can't get IMEI
Processing package
Break.
Elapsed: 22 secs.
hi, please tell me how did you solve your problem, ihave same situation as you
The Following 3 Users Say Thank You to tattoum For This Useful Post:
Old 10-28-2015, 11:17   #10 (permalink)
OXB
Crazy Poster
Member: 1109469
Thanks Meter: 3
But when I press and Vol - then plug micro USB, PC find driver name: "QHSUSB Bulk" , my sony not recognized PC, how do I do??
The Following 2 Users Say Thank You to OXB For This Useful Post:
Old 11-02-2015, 05:53   #11 (permalink)
Member: 974837
Thanks Meter: 5
its working, nice job sir!
The Following User Says Thank You to freezone2010 For This Useful Post:
Old 11-07-2015, 15:24   #12 (permalink)
BACK's Avatar
Member: 304574
Sonork: 100.1593675
Thanks Meter: 72
test point pic any one have plz share it
The Following 2 Users Say Thank You to BACK For This Useful Post:
Old 01-18-2016, 07:43   #13 (permalink)
way2unlock's Avatar
Member: 582682
Sonork: 100.1607124
Thanks Meter: 136
how?
After flash totally dead,not reconized in setool or pc compignon.
The solution is:
2. In settings check signed mode + alternative bypass
2. Click flash then ready .
3. Hold volume - and connect the phone and keep holding the volume down
4. Release vol down and click ready it shall start flashing the phone.
5. Wait to finish then enjoy your phone alive again
thanx for share solution
my phone is done with your step without testpoint jumper
my phone is live again tested done
The Following 3 Users Say Thank You to way2unlock For This Useful Post:
Old 03-16-2016, 08:53   #14 (permalink)
Member: 1663119
Sonork: iffi3
Thanks Meter: 213
need test point picture plz
The Following 2 Users Say Thank You to iffipower For This Useful Post:
Old 03-16-2016, 10:12   #15 (permalink)
moshman's Avatar
Member: 193192
Thanks Meter: 327
There is no testpoint.
When you are prompted to attach/detach testpoint - just press "READY"
The Following 2 Users Say Thank You to moshman For This Useful Post:
Page generated in 0.29512 seconds with 9 queries
