02-23-2015, 19:02 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Tirana Age: 43
Member: 143851 Status: Online Thanks Meter: 162 | Sony d2005 dead after flash ,solved after flash totally dead,not reconized in setool or pc compignon. The solution is: 1 in setool choose the flash files (app fsp elabl) . 2. in settings check signed mode + alternative bypass 2. click flash then ready . 3. hold volume - and connect the phone and keep holding the volume down until he ask for click ready agin 4. release vol down and click ready it shall start flashing the phone. 5. wait to finish then enjoy your phone alive again |
The Following 4 Users Say Thank You to ak0101 For This Useful Post: |
05-27-2015, 13:42 | #4 (permalink) | |
Freak Poster Join Date: Apr 2006
Member: 265098 Status: Offline Thanks Meter: 7 | Quote:
The Following 3 Users Say Thank You to anoopme For This Useful Post: |
06-16-2015, 16:16 | #6 (permalink) |
No Life Poster Join Date: Mar 2005 Location: wales uk
Member: 125632 Status: Offline Thanks Meter: 233 | do not use latest setool to flash this phone,,,it will make brick..that is v1.1418 i used v1.1408 worked great RUNNING v 1.1408/01.13/UNI CARD SERIAL 0001xxxx USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "S1_Boot_MSM8x10_0.45" ACTIVE_COMP_AID : 0004 HWCONF_AID : 0004 LOADER_AID : 0004 BOOT_AID : 0004 DEVICE ID: 0585FE7C FLASH ID: "0003/00000015" LOADER VERSION: "MSM8X10_12" PHONE IMEI : 355628064xxxxx writing "N:\SETOOL\Flashes\SONY\D2005_Xperia_E1\20.1.A.0.4 7\20_1_A_0_47.APP_SW_FalconSS_GENERIC_1277_8886_S1 _SW_LIVE_B578_PID ... Processing package N:\SETOOL\Flashes\SONY\D2005_Xperia_E1\20.1.A.0.47 \20_1_A_0_47.APP_SW_FalconSS_GENERIC_1277_8886_S1_ SW_LIVE_B578_PID1_0005_MMC.S ... BOOT UPDATE NOT REQUIRED Processing ACPU files PROCESSING: cache_S1-SW-LIVE-B578-PID1-0005-MMC.sin PROCESSING: kernel_S1-SW-LIVE-B578-PID1-0005-MMC.sin PROCESSING: fotakernel_S1-SW-LIVE-B578-PID1-0005-MMC.sin SKIP: partition-image_S1-SW-LIVE-B578-PID1-0005-MBR.sin no update files in package writing "N:\SETOOL\Flashes\SONY\D2005_Xperia_E1\20.1.A.0.4 7\20_1_A_0_47.FSP_FalconSS_WORLD_i_1280_6712_S1_SW _LIVE_B578_PID1_0 ... Processing package N:\SETOOL\Flashes\SONY\D2005_Xperia_E1\20.1.A.0.47 \20_1_A_0_47.FSP_FalconSS_WORLD_i_1280_6712_S1_SW_ LIVE_B578_PID1_0005_MMC.R5B. ... Processing ACPU files PROCESSING: userdata_S1-SW-LIVE-B578-PID1-0005-MMC.sin PROCESSING: system_S1-SW-LIVE-B578-PID1-0005-MMC.sin PROCESSING: amss_fs_1_S1-MODEMSW-LIVE-B578-PID1-0005-MMC.sin PROCESSING: amss_fs_2_S1-MODEMSW-LIVE-B578-PID1-0005-MMC.sin PROCESSING: amss_fsg_S1-MODEMSW-LIVE-B578-PID1-0005-MMC.sin Processing update files PROCESSING: cust-reset.ta Writing TA unit 0002/08A4/000E SKIP: simlock.ta writing "N:\SETOOL\Flashes\SONY\D2005_Xperia_E1\20.1.A.0.4 7\20_1_A_0_47.ELABEL_FalconSS_elabel_d2005_row.201 403122110_1.SIN_F ... Processing package N:\SETOOL\Flashes\SONY\D2005_Xperia_E1\20.1.A.0.47 \20_1_A_0_47.ELABEL_FalconSS_elabel_d2005_row.2014 03122110_1.SIN_FILE_SET Processing ACPU files PROCESSING: elabel-D2005-row_201403122110.1_20.1.A.0.47_S1-ELABEL-LIVE-B578-PID1-0004-MMC.sin no update files in package Elapsed: 699 secs. |
The Following 2 Users Say Thank You to bcatlock1 For This Useful Post: |
06-16-2015, 18:44 | #7 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Pakistan Age: 33
Member: 323959 Status: Offline Sonork: 100.1613721 Thanks Meter: 79 | not work for me SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use SAHARA protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : 57B7D606 HARDWARE ID : 04000100E1108100 PRODUCT DETECTED: "MSM8210 OEM1 fused" HASH :5A93232B8EF5567752D0CB5554835215D1C473502E6F1052A 78A6715B8B659AA PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_PRELOADER VER "MSM8X10_10" ACTIVE_COMP_AID : 0004 HWCONF_AID : 0004 LOADER_AID : 0004 BOOT_AID : 0004 DEVICE ID: 06D6B757 FLASH ID: "0090/014A0005" LOADER VERSION: "MSM8X10_10" Can't get IMEI writing "C:\Documents and Settings\Administrator\My Documents\Downloads\D2005\20_1_A_0_47\20_1_A_0_47. ELABEL_FalconSS_elabel_ ... Processing package C:\Documents and Settings\Administrator\My Documents\Downloads\D2005\20_1_A_0_47\20_1_A_0_47. ELABEL_FalconSS_elabel_d2005_ph.201 ... Processing ACPU files PROCESSING: elabel-D2005-ph_201403041200.1_20.1.A.0.47_S1-ELABEL-LIVE-B578-PID1-0004-MMC.sin MINOR ERROR [ FAC_CORE_SECMGR_-_ERR_ROOT_CERT_TYPE_CHECK, err: 0017 ] error while uploading final HDR block Break. Elapsed: 22 secs. |
The Following 2 Users Say Thank You to faizan15 For This Useful Post: |
07-04-2015, 23:29 | #8 (permalink) |
Insane Poster Join Date: Mar 2008 Location: tunis
Member: 716894 Status: Offline Thanks Meter: 18 | RUNNING v 1.1413/01.15/UNI CARD SERIAL 00044831 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use SAHARA protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : 9CCE3005 HARDWARE ID : 04000100E1108100 PRODUCT DETECTED: "MSM8210 OEM1 fused" HASH :5A93232B8EF5567752D0CB5554835215D1C473502E6F1052A 78A6715B8B659AA PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_PRELOADER VER "MSM8X10_10" ACTIVE_COMP_AID : 0004 HWCONF_AID : 0004 LOADER_AID : 0004 BOOT_AID : 0004 DEVICE ID: 0530CE9C FLASH ID: "0015/01000001" LOADER VERSION: "MSM8X10_10" PHONE IMEI : 35384906926079 writing "D:\sony ericson\d2005\20_1_A_2_19.APP_SW_FalconSS_GENERIC_ 1277_8886_S1_SW_LIVE_B578_PID1_0005_MMC.SIN_FILE_S ET" Processing package D:\sony ericson\d2005\20_1_A_2_19.APP_SW_FalconSS_GENERIC_ 1277_8886_S1_SW_LIVE_B578_PID1_0005_MMC.SIN_FILE_S ET WILL UPDATE BOOT TO : S1_BOOT_MSM8X10_0.45 PARSING: "DEVELOPMENT" value OTP_LOCK_STATUS_1 : UNLOCKED, not match LOCKED PARSING: "TEST_OEM0_008110E1" value OTP_LOCK_STATUS_1 : LOCKED, match LOCKED value OTP_DATA_1 : 00000100, not match 01000400 value IDCODE_1 : 008110E1, match 008110E1 PARSING: "PRECOMMERCIAL_008110E1" value OTP_LOCK_STATUS_1 : LOCKED, match LOCKED value OTP_DATA_1 : 01000400, match 01000400 value IDCODE_1 : 008110E1, match 008110E1 PROCESSING : dbi_S1-BOOT-TEST-B316-0001-MMC_PLATFORM-MSM8210-LIVE-HWID008110E1-SWID12-OEM1-AID4-DEBUG00_S1-BOOT-LIVE-B578-0004-M ... PROCESSING : emmc_appsboot_S1-BOOT-TEST-B316-0001-MMC_PLATFORM-MSM8210-LIVE-HWID008110E1-SWID09-OEM1-AID4-DEBUG00_S1-BOOT-LIVE-B ... PROCESSING : rpm_S1-RPMFW-TEST-B316-0001-MMC_PLATFORM-MSM8210-LIVE-HWID008110E1-SWID0A-OEM1-AID4-DEBUG00_S1-RPMFW-LIVE-B578-PID1 ... PROCESSING : sbl1_PLATFORM-MSM8210-LIVE-HWID008110E1-SWID65-OEM1-AID4-DEBUG00_PLATFORM-MSM8210-LIVE-HWID008110E1-SWID00-OEM1-AID ... PROCESSING : tz_S1-BOOT-TEST-B316-0001-MMC_PLATFORM-MSM8210-LIVE-HWID008110E1-SWID07-OEM1-AID4-DEBUG00_S1-BOOT-LIVE-B578-0004-MM ... PROCESSING : Falcon_S1BootConfig_MiscTA_130820_1730.ta Writing TA unit 0002/084F/003C Writing TA unit 0002/08FD/0001 BOOT UPDATED Processing ACPU files PROCESSING: cache_S1-SW-LIVE-B578-PID1-0005-MMC.sin PROCESSING: kernel_S1-SW-LIVE-B578-PID1-0005-MMC.sin PROCESSING: fotakernel_S1-SW-LIVE-B578-PID1-0005-MMC.sin SKIP: partition-image_S1-SW-LIVE-B578-PID1-0005-MBR.sin no update files in package writing "D:\sony ericson\d2005\20_1_A_2_19.FSP_FalconSS_WORLD_i_128 0_0604_S1_SW_LIVE_B578_PID1_0005_MMC.R2B.SIN_FILE_ SET" Processing package D:\sony ericson\d2005\20_1_A_2_19.FSP_FalconSS_WORLD_i_128 0_0604_S1_SW_LIVE_B578_PID1_0005_MMC.R2B.SIN_FILE_ SET Processing ACPU files PROCESSING: userdata_S1-SW-LIVE-B578-PID1-0005-MMC.sin PROCESSING: system_S1-SW-LIVE-B578-PID1-0005-MMC.sin PROCESSING: amss_fs_1_S1-MODEMSW-LIVE-B578-PID1-0005-MMC.sin PROCESSING: amss_fs_2_S1-MODEMSW-LIVE-B578-PID1-0005-MMC.sin PROCESSING: amss_fsg_S1-MODEMSW-LIVE-B578-PID1-0005-MMC.sin Processing update files PROCESSING: cust-reset.ta Writing TA unit 0002/08A4/000E SKIP: simlock.ta Elapsed: 358 secs. thnx for the solution work 1000% |
The Following 2 Users Say Thank You to lotfigsm2 For This Useful Post: |
09-29-2015, 21:22 | #9 (permalink) | |
No Life Poster Join Date: Oct 2002 Location: tunisia
Member: 16625 Status: Offline Sonork: 1578753 Thanks Meter: 161 | Quote:
The Following 3 Users Say Thank You to tattoum For This Useful Post: |
10-28-2015, 11:17 | #10 (permalink) |
Crazy Poster Join Date: Sep 2009
Member: 1109469 Status: Offline Thanks Meter: 3 | But when I press and Vol - then plug micro USB, PC find driver name: "QHSUSB Bulk" , my sony not recognized PC, how do I do?? |
The Following 2 Users Say Thank You to OXB For This Useful Post: |
01-18-2016, 07:43 | #13 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: EARTH Age: 42
Member: 582682 Status: Offline Sonork: 100.1607124 Thanks Meter: 136 | Quote:
my phone is done with your step without testpoint jumper my phone is live again tested done | |
The Following 3 Users Say Thank You to way2unlock For This Useful Post: |
