Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 03-21-2010, 16:39   #1 (permalink)
nofear99's Avatar
Member: 1157693
Thanks Meter: 122
Question Sony Ericsson K310i all Locks Block......
How can i solve this problem with setool please tell me steps and also this kind of problem for other SE mobiles.......
Old 03-21-2010, 16:49   #2 (permalink)
roney_nexus's Avatar
Member: 288504
Sonork: .:100.1587032:.
Thanks Meter: 2,262
bro 1st time u post logs then i will try thx.........
Old 03-21-2010, 17:25   #3 (permalink)
green ghost's Avatar
Member: 703551
Thanks Meter: 68
Try to do full unlock no pacth unlock
Old 03-21-2010, 18:12   #4 (permalink)
nofear99's Avatar
Member: 1157693
Thanks Meter: 122
Question Here is info......
Here is the info of K310i its not taking any sim card not even Universal sim card............
plez tell me solution
RUNNING v0.915062/UNI
CARD SERIAL 00016710
PLEASE UPGRADE USBFLASH DRIVER 02.02.00.00
CFG:000000000000
ChipID:8040,EMP protocol:0301
PHONE STATE: "RETAIL"
FLASH CID: 0049
Speed:921600
FLASH ID:897E
OTP: LOCKED:1 CID:49 PAF:1 IMEI:35155901325207 CERT:RED
FLASH CID:49 COLOR:RED
Model (from GDFS):K310i
MAPP CXC article: R4DA044 prgCXC1250471_VODAFONE_DO
MAPP CXC version: R4DA044
Language Package: VFE_LIVE_1
CDA article: CDA102570/13
CDA version: R7A
Default article: cxc1250474
Default version: R4DA044
PROVIDER: 000-00
SIMLOCKS NOT DETECTED
USERCODE:0000
RESTORATION FILE NOT PRESENT
"R4DA044_CXC1250471_VODAFONE_DO"
YOU MUST PERFORM FULL FLASHING
WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED
Old 03-21-2010, 18:15   #5 (permalink)
karurosu316's Avatar
Member: 452143
Thanks Meter: 124
Settings: 4 and 5 + Unlock, full tested CID 49.
Old 03-21-2010, 19:42   #6 (permalink)
nofear99's Avatar
Member: 1157693
Thanks Meter: 122
Question I tried but there comes unlock failed.....
thanks when i tried there comes
CFG:000110000000
FLASH CID: 0049
Speed:921600
PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0
LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738
FLASH ID:897E
REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
THEN PRESS "READY"
STARTING BOOTLOADER...
INT LDRB2010_RESPIN_ID_LOADER_SETOOL2
LDRB2010_RESPIN_PRODLOADER_SETOOL2
FLASH ID:897E
FOUND VERSION "R4EA031_CXC1250466_GENERIC_DO"
can't open file "C:\Documents and Settings\Administrador\Ambiente de trabalho\SETOOLS\rest\R4EA031_CXC1250466_GENERIC_D O"
Setting up GDFS...
can't get packet start.
packet not acknowledged (17)
setGDFS_params failed
failed to setup GDFS
Unlock FAILED
here is locks info when i press read locks under locks tab
CFG:000000000000
FLASH CID: 0049
Speed:921600
FLASH ID:897E
THEN PRESS "READY"
FLASH ID:897E
Error while setting up GDFS.
Elapsed: 117 secs.
Old 03-21-2010, 20:50   #7 (permalink)
Member: 288504
Thanks Meter: 2,262
bro u can try to patch unlock it this setting
pls post ur result thx...
Old 03-21-2010, 21:01   #8 (permalink)
Super Moderator
THE CLASH's Avatar
Member: 173077
Sonork: 100.1594293
Thanks Meter: 2,386
You Have problem with the REST File.
Your Phone is Now Dead,,,,???
if so
Flash it with Same* main* to Repair.
Old 03-21-2010, 23:31   #9 (permalink)
Member: 240988
Thanks Meter: 45
5 LOCK CLOSED
1. go to emptyboard tab
2. select proper model
3. on settings, check "signed mode"
4. press recovery
5. after succeful recovery
6. on settings uncheck all
7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step
8. add to firmware area proper EROM (EROM CID >= OTP CID)
9. press flash
10. if needed,reflash phone on usual semc tab with needed settings.
Old 03-22-2010, 04:04   #10 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 1,550
Flash only this Main File inn Settings: Unlock after Flash then Flash
Sony Ericsson K310i LOCK TO NETWORK pece_21mk Old Ericsson Phones & Sony Phones 0 03-18-2010 21:52
SONY ERICSSON K310i flashing ub the phone is dead k310i files not available ub lilong_lee Universalbox 1 12-23-2009 02:39
Sony Ericsson K310i Security Lock mohit_kripalu01 Universalbox 5 07-17-2008 19:48
sony ericsson k310i purshottam_bapu Sony Ericsson Hardware Repair 1 10-17-2007 13:18
Unlock codes for sony ericsson k310i locked to vodafone mmjulian Sony Ericsson 1 05-08-2007 21:36
Page generated in 0.35092 seconds with 8 queries
