Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2007 Location: ATF Earth Age: 25
Member: 598395 Status: Offline Thanks: 616
| Sony Ericsson K550i RED Blink Repair Done By Setool3 v0.915016/UNI CARD SERIAL: 000XXXXX Loaded 51 flash descriptors TESTPOINT REPAIR STAGE #1 STARTED Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489301800151 CERT:N/A FLASH CID:51 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 PREPARING... ATTACH TP #1 AND PRESS "READY" RELEASE TP #1 AND PRESS "READY" TP #1 LOOKS OKAY DONE Elapsed: 45 secs. TESTPOINT REPAIR STAGE #2 STARTED Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 ATTACH TP #2 AND PRESS "READY" Trying to launch embedded bootloader... TP #2 LOOKS OKAY RELEASE TP #2 AND PRESS "READY" INT LDR B2020_PRELOADER_FOR_SETOOL2WRITING EROM... DONE Elapsed: 31 secs. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489301800151 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER Flash ID check:2019 Flash props sent ok writing C:\setool2g\gdfs_in_ssw_format\db2020\k550_gdfs_SS W.ssw CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is:640 Will flash 32 blocks... SSW loading returns:0 writing C:\setool2g\eroms\db2020\DB2020EROM_CNV_RED51_BROW N_CID49_DB2020.ssw CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is:80 Will flash 4 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED. Writing simlocks... ALL UNLOCK/LOCK CODES SET TO "11573726" Signing... control keys complete. full sig complete. Elapsed: 63 secs. Br, Sahil2007 Thanks SeTool3 Team. ![]() Last edited by Sahil2007; 11-23-2008 at 18:47. Reason: Remove Card SN Number |
| The Following User Says Thank You to Sahil2007 For This Useful Post: |
| | #2 (permalink) |
| Another Sony Ericsson K800i RED Blink Repair Done By Setool3 v0.915016/UNI CARD SERIAL: 000XXXXX Loaded 51 flash descriptors TESTPOINT REPAIR STAGE #1 STARTED Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35731501584831 CERT:N/A FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 PREPARING... ATTACH TP #1 AND PRESS "READY" RELEASE TP #1 AND PRESS "READY" TP #1 LOOKS OKAY DONE Elapsed: 39 secs. TESTPOINT REPAIR STAGE #2 STARTED Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 ATTACH TP #2 AND PRESS "READY" Trying to launch embedded bootloader... TP #2 INCORRECT OR STAGE #1 NOT EXECUTED PROCEDURE WAS STOPPED BY USER Elapsed: 23 secs. TESTPOINT REPAIR STAGE #2 STARTED Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 ATTACH TP #2 AND PRESS "READY" Trying to launch embedded bootloader... TP #2 LOOKS OKAY RELEASE TP #2 AND PRESS "READY" INT LDR B2020_PRELOADER_FOR_SETOOL2WRITING EROM... DONE Elapsed: 47 secs. SIGNED MODE (USING SERVER). Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35731501584831 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER Flash ID check:897E Flash props sent ok writing C:\setool2g\gdfs_in_ssw_format\db2020\K800_GDFS_SS W.ssw CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is:640 Will flash 32 blocks... SSW loading returns:0 writing C:\setool2g\eroms\db2020\DB2020EROM_CNV_RED52_BROW N_CID49_DB2020.ssw CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is:40 Will flash 2 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED. Writing simlocks... ALL UNLOCK/LOCK CODES SET TO "31626844" Signing... control keys complete. full sig complete. Elapsed: 60 secs. Br, Sahil2007 Thanks SeTool3 Team. |
| | #5 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2007 Location: I donot know what is the best Age: 40
Member: 581626 Status: Offline Thanks: 180
| thanx brother Sahil2007 for this usefull post and i hope you can help me: 1-how can i remove this protect material at the pins(testpoint) because i have w580 and it needed testpoint proccedure but the pins are protected with extra material like hard glue. 2- i have this cabel for test point: http://ucables.com/img/pics1/CABLE-S...-PO-R44828.jpg. can you explain to me how can i use it beginning with setool till the connections if possible .thanks indeed |
| | #6 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2005 Location: pondicherry,INDIA Age: 36
Member: 165982 Status: Offline Thanks: 86
| Quote:
hello sir, the cable u are having is the right one.just plug the cable in the usb port and don't care about the + and - pins.use only the tp pin. the other thing is, if the ic is glued means,u can use the above layer of the ic.u can see the test points with the use of microscope.the images are also in the tp images folder. thank u and all the best | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| w850i red blink successfully done by Setools | cool35 | SETool2 | 5 | 08-21-2010 08:11 |
| k550i red blinking repair sucsess by v1.0 | hanif007 | SETool2 | 5 | 03-19-2010 04:19 |
| Sony Ericsson U1i Satio Unlock Done By Setool3 | Sahil2007 | SETool2 | 2 | 03-08-2010 08:46 |
| Sony Ericsson W580i RED Blink Repair Done Without TP | Sahil2007 | SETool2 | 0 | 09-14-2009 19:01 |
| Sony Ericsson K800i RED Blink Repair Done By Setool3 | Sahil2007 | SETool2 | 0 | 11-24-2008 18:12 |
