Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 03-20-2020, 12:06   #1 (permalink)
Member: 2349975
Thanks Meter: 50
SONY ERICSSON K800i DEAD AFTER UNLOCK WITH SETOOL2 ANY SOLUTION?
Can some one with the required experience put me through on how to restore Sony Ericsson K800i locked to Orange that went dead after unlock with Setool2.
Old 03-20-2020, 12:32   #2 (permalink)
Member: 2349975
Thanks Meter: 50
See repair logs:
RUNNING v 1.1411/01.14/UNI
CARD SERIAL 00168053
USBFLASH DRIVER VERSION 03.00.00.00
SIGNED MODE (USING SERVER)
ALTERNATIVE SECURITY BYPASS ENABLED
CFG:110000110000
ChipID: 9900, EMP protocol: 0301
BOOTROM MODE DETECTED
SPEED: 115200
LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M
FLASH ID: 897E
OTP: LOCKED:1 CID:51 PAF:1 IMEI:3573150xxx0028
ACTIVE CID: 49 COLOR: BROWN
llbug: blk write fail.fatal
packet not acknowledged (21)
no ack during gdfs_readvar !
SCRC READ FAILURE
Elapsed: 8 secs.
CFG:110000110000
SPEED: 115200
CURRENT CID: 49 COLOR: BROWN
LDR: DB2020 LOADER FOR SETOOL2
FLASH ID: 897E
Searching ...
IMEI handler determined.
Setting up GDFS ...
WRITING CLEAR SIMLOCK UNITS ...
SIMLOCK CODES SET TO "08605702"
SIGNING ...
Unlock DONE
Elapsed: 23 secs.
PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
CFG:110000110000
RESET MODE STARTED
SPEED: 115200
RESET: 070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA
FLASH ID: 897E
GOT SEED: 353643AD2380C37315C0D099
P96 AUTH PASSED
PHONE SUCCESSFULLY RESET TO DEVELOPER STATE
Elapsed: 41 secs.
Old 03-20-2020, 19:26   #3 (permalink)
Member: 9519
Thanks Meter: 2,000
1. go to emptyboard tab
2. select proper model
3. on settings, check "signed mode"
4. press recovery
5. after succeful recovery
6. on settings uncheck all
8. add to firmware area proper EROM
( eroms\db2020\DB2020EROM_CNV_RED53_BROWN_CID49_DB20 20.ssw )
9. press flash
10. if needed,reflash phone on usual semc tab with needed settings.
The Following 2 Users Say Thank You to the_laser For This Useful Post:
Old 03-23-2020, 15:32   #4 (permalink)
Member: 2349975
Thanks Meter: 50
4. press recovery
9. press flash
Thanks alot laser i did it successfully last week by:
1, click empty repair tab
2, check signed mode under setting
3. Press recovery and phone returned to factory setting seccessfully
4. Uncheck all items in setting tab
5. click empty repair tab and added gds(CID 53) and erom files (all from setool folder already in your pc) then press FLASH
6. Check Signed Mode and Customize after flash under setting
7. Load/add Main(CID 53) and FS file then press FLASH
Job done then power on phone now back to life
Page generated in 0.12778 seconds with 7 queries
