12-04-2012, 13:33 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | sony ericsson LT18I unlock problems with setool see logs DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" qcReceivePacket: can't get packet start. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 68 secs. |
The Following User Says Thank You to fokal2008 For This Useful Post: |
12-04-2012, 15:12 | #3 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 531113 Status: Offline Thanks Meter: 22 | SAME FOR ME DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" qcReceivePacket: can't get packet start. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 53 secs. |
05-05-2014, 11:34 | #9 (permalink) | |
Junior Member Join Date: May 2014
Member: 2180146 Status: Offline Thanks Meter: 0 | unlock Quote:
I cannot unlock sony service because unlock allowed:NO. Guys at the XDA Forum told me i can buy NCK code, but the code will never change NO to YES. Because this, i cannot use sony's website to unlock my phone.(i haven't got fastboot!) Can you give me more information about that? | |
12-09-2014, 13:48 | #13 (permalink) |
No Life Poster Join Date: May 2004
Member: 64957 Status: Offline Thanks Meter: 100 | before buying code check if u r phone is blacklisted.once entering code network try will become 0 if its blocked.it happened to me.had 5 tries just entering the code on 6th try it said phone unlocked but no service i checked the counter its 0 now.so far no solution. |
