Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 11-14-2009, 11:57   #1 (permalink)
Boshko_Alfa's Avatar
Member: 472933
Sonork: 100.1590967
Sony Ericsson W302 don't boot for unlock, identify and flash. But phone work ok
when i try to identify i set com 3, press identify and when i connect phone - only charging, when i press power - phone power on.
also in unlocking.
cable, box and com port is OK :/
when i press sign mode in settings and press unlock - then phone boot and log is:
SIGNED MODE (USING SERVER)
CFG:100000000000
PROCEDURE WAS STOPPED BY USER
Can't load ID loader !
Elapsed: 19 secs.
CFG:000000000000
FAILED TO SETUP PHONE
Elapsed: 65 secs.
CFG:100000000000
PLEASE ATTACH TURNED OFF PHONE NOW
PRESS "POWER ON" BUTTON SHORTLY...
EROM "R7A021" AID: 0001
SOFTWARE AID: 0001
SIMLOCK STATE: "NOT_TAMPERED"
LOADER AID: 0002
FLASH ID: "00EC/220C"
LOADER VERSION: "R3A011"
PHONE IMEI:35489503261793
USERLOCK RESET TO "0000"
TOTAL CALL TIME RESET
Elapsed: 17 secs.
where is the problem with this phone?
Old 11-14-2009, 12:06   #2 (permalink)
jepetu's Avatar
Member: 181633
You have to use USB cable and connect phone by pressing 2+5 buttons...
Old 11-14-2009, 13:06   #3 (permalink)
Member: 1026122
No problem In Ur Phone...
if U want to unlock this set U must TICK..Sign mode and Perform Full unlock instead of User code.......
Also U need a Valid user account and password for this operation.....
U can Use Com port perfectly ......No need to use USB....
Hope will Solve Ur problem...
Old 11-15-2009, 09:52   #4 (permalink)
StRaNgE PeRsOn's Avatar
Member: 391445
Sonork: 100.1583575
also in unlocking.
NEW LOCOSTO< NEPTUNE phones require signed mode for booting and flashing purpose !!!
The Following User Says Thank You to StRaNgE PeRsOn For This Useful Post:
Old 11-15-2009, 09:55   #5 (permalink)
Member: 631286
Problem Not In Phone Bro Click On Singmode And Eletranate bAYPASS iTS oK
Old 11-15-2009, 16:56   #6 (permalink)
Member: 257603
Sonork: 100.1605284
If its old security it will be done without credit and if it new security it will consume one credit just tick sign mode and unlock instead unlock.
Old 11-15-2009, 17:00   #7 (permalink)
Member: 472933
Sonork: 100.1590967
but i want to flash this phone with serbian language, not to unlock.
Old 11-16-2009, 09:07   #8 (permalink)
Member: 391445
Sonork: 100.1583575
Attach to USB cable while holding 'C',
Remember to tick signed mode
Old 11-24-2009, 01:37   #9 (permalink)
chatfan's Avatar
Member: 866321
Sonork: 100.1581211
Here the real solution:
Check in settings SIGNED MODE + ENABLE ALTERNATIVE.....just two of these.....
Now, holding C key connect cable and everything will be fine, the problem is that UNLOCK not WORK for this model exactly without using SERVER.....so you have to use credits, cause all W302 are NEW SECURITY......
Follow my instructions and you'll see....same happened to me few days ago...just using SERVER can be done.....
Besides, when you see this:
this mean NEW SECURITY.....
here screen shot:
The Following User Says Thank You to chatfan For This Useful Post:
Old 11-24-2009, 01:40   #10 (permalink)
chatfan's Avatar
Member: 866321
Sonork: 100.1581211
My friend, this W302 is not A2 platform, it's ODM...not work with 2+5 combination
regards,
Old 02-10-2011, 06:10   #11 (permalink)
MIRPUR AJK's Avatar
Member: 725834
After flash display white but phone work ok. Before flash display work ok. Any sol? Unlocker_001 Chinese Miracle & PinFinder 2 01-27-2010 19:36
server is still down for pack 4 and 5, but 123 is ok. baig65 FuriouS TeaM Products 1 09-11-2009 13:34
Problem 7390 don't boot for unlock unlockermovil MT-BOX 3 03-04-2009 19:49
6260 White Screen But Phone Work OK AswanX Nokia Hardware & Hardware-Repair Area 4 09-16-2007 04:52
Samsung R2xx cable for unlock (SanTel) and flash m.com VLSI, Conexant, Skyworks and Old Models 25 04-24-2002 00:31
Page generated in 0.32095 seconds with 11 queries
