01-25-2011, 10:11 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: india Age: 43
Member: 397892 Status: Offline Sonork: 100.1609899 Thanks Meter: 190 | sony ericsson w850i not power on identified logs: >>>>> Elapsed: 20 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:49 PAF:1 IMEI:35240101263884 CERT:N/A FLASH CID:51 COLOR:RED Model (from GDFS):K700 MAPP CXC article: R1GB001 prgCXC1250200_GENERIC_CY MAPP CXC version: R1GB001 Language Package: EUROPE_4 CDA article: CDA102568/13 CDA version: R2A Default article: cxc1250489 Default version: R1ED001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R1GB001_CXC1250200_GENERIC_CY" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED |
01-25-2011, 10:21 | #2 (permalink) | |
Registered User Join Date: Dec 2006 Location: Shakar Garh To Kmk.Gujranwala Age: 12
Member: 407063 Status: Offline Thanks Meter: 2,133 | Quote:
Download Br naeem | |
01-25-2011, 10:22 | #3 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 696136 Status: Offline Thanks Meter: 210 | Hello, 1st perform correct reset procedure like this. CID 50,51,52,53 that is so-called reset procedure. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. If this not work than change lcd and post result. BR |
01-25-2011, 16:21 | #5 (permalink) | ||
Member: 397892 Status: Offline Sonork: 100.1609899 Thanks Meter: 190 | Quote: Quote:
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
