09-24-2012, 18:44 | #1 (permalink) |
Freak Poster Join Date: Feb 2011 Location: Northern Ireland
Member: 1514899 Status: Offline Thanks Meter: 49 | Sony Ericsson wt19i unlock problem I have a problem with Sony wt19i. I checked 3 tabs, number 1,2 and 5. I have credits, but I get the following message when trying to unlock it: DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" qcReceivePacket: can't get packet start. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 60 secs. Why is that? Best Regards |
09-24-2012, 19:04 | #2 (permalink) |
Member: 1514899 Status: Offline Thanks Meter: 49 | PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_EROM VER "R9B031" EROM_AID : 0001 LOADER_AID : 0001 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 DEVICE ID: 71125C24E3FB1DB798E8C2FB3A60EDE789A18D61 FLASH ID: "0098/00B3" LOADER VERSION: "R4A069" PHONE IMEI : 35263805****** MODEL (from GDFS): WT19i SOFTWARE VERSION: 1250-5829_4.0.2.A.0.62 CUSTOM VERSION: 1261-5367_R5D FILESYSTEM VERSION: WORLD-i_4.0.2.A.0.62 SERIAL NO: YT9001E1QS Elapsed: 19 secs. I tried a few times wit TP and still no joy. Any Ideas?? |
09-24-2012, 19:18 | #3 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,437 | If you can not unlock, it is a new security and not supported. anyway you can report here the YearWeek on the sticker, it should be grater than 12w14 |
The Following User Says Thank You to :Aishur: For This Useful Post: |
09-24-2012, 19:44 | #4 (permalink) | |
Member: 1514899 Status: Offline Thanks Meter: 49 | Quote:
Does it mean that it can't be unlocked with Setool? Any other Solution? The counter is blocked so I can't insert the code. Maybe there is a solution to reset the counter for this phone? Thanks for Help. Best Regards | |
09-24-2012, 19:55 | #5 (permalink) |
Member: 1315677 Status: Offline Thanks Meter: 1,437 | only sony service centers can help you (high security level access) Wait for a new server, if it will come (no eta) Best regards |
09-24-2012, 20:40 | #6 (permalink) | |
No way to write the code( I have it) like with Nokia phones? No way to reset counter? No other tool that could support this new security? Thanks Best Regards | |
