09-29-2011, 07:14 | #16 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: jamshedpur Age: 38
Member: 59185 Status: Offline Sonork: 100.1593175 Thanks Meter: 4,911 | Quote:
read this post . http://forum.gsmhosting.com/vbb/7610403-post5.html | |
09-29-2011, 07:42 | #17 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: India\China
Member: 561947 Status: Offline Sonork: 100.1580399 Thanks Meter: 948 | Quote:
pls check it & read faq. http://forum.gsmhosting.com/vbb/f473...tool3-1343127/ | |
11-04-2011, 14:37 | #18 (permalink) |
No Life Poster Join Date: May 2003
Member: 29652 Status: Offline Thanks Meter: 43 | RUNNING v 1.1201/01.11/UNI CARD SERIAL 00010051 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... qcReceivePacket: can't get packet data. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 45 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 4 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... qcReceivePacket: can't get packet data. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 33 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... qcReceivePacket: can't get packet data. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 151 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... qcReceivePacket: can't get packet data. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 47 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... qcReceivePacket: can't get packet data. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 35 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... qcReceivePacket: can't get packet data. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 33 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... qcReceivePacket: can't get packet data. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 27 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... qcReceivePacket: can't get packet data. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 59 secs. |
11-06-2011, 15:38 | #20 (permalink) |
No Life Poster Join Date: Apr 2010 Location: NICE MOBILES Age: 35
Member: 1293519 Status: Offline Sonork: 100.1596500 Thanks Meter: 169 | how to unlock s1 android based phones using alternative security bypass using testpoint? a: first, that is ONLY applicable to phones, based on msm8255 chipset - lt15,mt15,r800, some upcoming models. Here is procedure. 1. prepare for testpoint operation. check testpoint location for your phone model in dist\docs\ open testpoint for access get some needle with wire, connect it to phone gnd ( battery minus ) or to usb cable shield, etc. 2. select proper phone model. on settings check signed mode, use alternative security bypass, do full unlock instead usercode reset fill login/password and check if account valid. press unlock when prompted, execute steps in EXACT order: remove cable from phone, remove battery from phone, attach testpoint press "ready" insert cable to phone, HOLDING TESTPOINT install drivers from dist\drivers\USBFlash_driver\ when prompted detach testpoint press "ready" phone will be unlocked.: |
09-20-2014, 13:05 | #24 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: England
Member: 193192 Status: Offline Thanks Meter: 327 | Quote:
q: i'm trying to unlock msm8x55-based phone, i'm sure that procedure done properly, but i'm always receive error: qcReceivePacket: can't get packet start a: bad luck, that is mcu with fixed security flaw and you can not unlock,repair trim area, repair semcboot, rebuild hwconfig using altbypass method. | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
