Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2009 Location: India,Jaipur Age: 25
Member: 1189368 Status: Offline Sonork: 100.1614900 Thanks: 215
| sony lt15i arc UNLOCK problem ? SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" BUTTON ... RUNNING S1_EROM VER "R9A021" SOFTWARE AID: 0001 LOADER AID: 0001 FLASH ID: "002C/00B3" LOADER VERSION: "R4A069" PHONE IMEI:01268xxxxxxxx Checking for signature ... signature found, skipping calculation DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... qcReceivePacket: can't get packet data. Unlock FAILED |
| | #3 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2011
Member: 1599054 Status: Offline Sonork: 100.1605269 Thanks: 29
| Quote:
May be first in Bangladesh Lt15i unlock done by setool using testpoint. nedd more help tell here .... I will try to help u | |
| | #4 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2009 Location: UK
Member: 1033807 Status: Offline Thanks: 270
| try to connect the testpoints(even you can do by shorting with twizzer) then connect battery then press back button and connect cable thats all |
| | #5 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2001 Location: Sun Age: 34
Member: 4021 Status: Offline Thanks: 832
| Quote:
you did not install the drivers properly..... i presume that you just clicked next after it pop up... you have to direct it to your SETOOL FOLDER/drivers/usb flash drivers/ if done correctly it should show ZEUS... not qualcomm good luck! br | |
| | #7 (permalink) |
| how to unlock s1 android based phones using alternative security bypass using testpoint? a: first, that is ONLY applicable to phones, based on msm8255 chipset - lt15,mt15,r800, some upcoming models. Here is procedure. 1. prepare for testpoint operation. check testpoint location for your phone model in dist\docs\ open testpoint for access get some needle with wire, connect it to phone gnd ( battery minus ) or to usb cable shield, etc. 2. select proper phone model. on settings check signed mode, use alternative security bypass, do full unlock instead usercode reset fill login/password and check if account valid. press unlock when prompted, execute steps in EXACT order: remove cable from phone, remove battery from phone, attach testpoint press "ready" insert cable to phone, HOLDING TESTPOINT install drivers from dist\drivers\USBFlash_driver\ when prompted detach testpoint press "ready" phone will be unlocked.: |
| | #9 (permalink) | |
| Quote:
battery will be used in first time...when second step begain no need enter battery. total procedure is select proper phone model. [COLOR="Red"]on settings check signed mode, use alternative security bypass, do full unlock instead usercode reset fill login/password and check if account valid. press unlock when prompted, execute steps in EXACT order: remove cable from phone, remove battery from phone, attach testpoint press "ready" insert cable to phone, HOLDING TESTPOINT install drivers from dist\drivers\USBFlash_driver\ when prompted detach testpoint press "ready"[/COLOR] | |
| The Following User Says Thank You to DIGIT9ENG For This Useful Post: |
| | #10 (permalink) |
| RUNNING S1_EROM VER "R9A021" SOFTWARE AID: 0001 LOADER AID: 0001 FLASH ID: "002C/00B3" LOADER VERSION: "R4A069" PHONE IMEI:01268xxxxxxxx Checking for signature ... signature found, skipping calculation DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" BUTTON ... RUNNING S1_LOADER VER "R4A062" LOADER AID: 0001 FLASH ID: "002C/00B3" LOADER VERSION: "R4A069" FINALIZING ... Unlock DONE Elapsed: 90 secs. THANKS @DIGIT9ENG |
| The Following User Says Thank You to VIMAL_Jaipur For This Useful Post: |
| | #11 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2009 Location: spain
Member: 1040105 Status: Offline Thanks: 23
| hi, allwais the same answer PROCESSING... qcReceivePacket: canīt get packet start. FAILED TO SETUP PHONE. Unlock FAILIED FIRS QUESTION: first to all, i need to connect phone (with batery) in any mode to pc? thanks |
| | #12 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: INSIDE OCLHASHCAT
Member: 751235 Status: Offline Sonork: 100.1623281 Thanks: 35
| easy way is this remove cable from PC remove battery from phone, attach testpoint WITHOUT BATTERY AND CONNECT CABLE TO PC install drivers from dist\drivers\USBFlash_driver\ press "ready" when prompted detach testpoint press "ready" THATS ALL |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| Sim card sleep mode problem with 6130 | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 05-22-2012 11:13 |
| $50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 07-09-1999 22:08 |
