Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 08-30-2014, 13:28   #1 (permalink)
syandi's Avatar
Member: 1675927
Sonork: syandi_cell
Thanks Meter: 25
sony Lt26w: Advice on correct Files..
Night sir can I flash sony lt26w with firmware sony lt26 file from support because my phone google acount now... Please help
Old 08-30-2014, 13:50   #2 (permalink)
dust2dust's Avatar
Member: 1284799
Sonork: 100.1649097
Thanks Meter: 138
use version 6.2.B.1.96
Old 08-30-2014, 13:51   #3 (permalink)
syandi's Avatar
Member: 1675927
Sonork: syandi_cell
Thanks Meter: 25
Anyone pleaase solution .. I don't want my phone is brick
Old 08-30-2014, 13:59   #4 (permalink)
syandi's Avatar
Member: 1675927
Sonork: syandi_cell
Thanks Meter: 25
Are your sure my phone its okey if I flash with that version.because I don't firmware lt26w
Old 08-30-2014, 14:49   #5 (permalink)
syandi's Avatar
Member: 1675927
Sonork: syandi_cell
Thanks Meter: 25
Hello anyone can give me solution
Old 08-30-2014, 16:59   #6 (permalink)
ch wajid's Avatar
Member: 2203737
Sonork: 1656500
Thanks Meter: 462
Hard Reset SONY XPERIA SP SONY XPERIA ACRO S LT26w
1, Hard Reset SONY XPERIA SP SONY XPERIA ACRO S LT26w with Flashtool applications:
Flashtool in the applications from Sony can be download from Sony website.
Flashtool software need to installed in you computer and ready with USB data cable
Make sure SONY XPERIA ACRO S LT26w battery is charge properly or full charge
Power off SONY XPERIA ACRO S LT26w
Boot SONY XPERIA ACRO S LT26w to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
Follow the menu at you computer display, it is easy to understand the steps.
2, Hard Reset SONY XPERIA ACRO S LT26w with Hardware Key Button:
Make sure the battery fully charge
Do not forget to backup all important data
Turn off the SONY XPERIA ACRO S LT26w
Press and Hold together: Power Button + Volume Up Button for several seconds
Follow the menu at LCD screen to continue the hard reset SONY XPERIA ACRO S LT26w
3,Sony Xperia LT26w Google Pattern Unlock Done bey code
Click On Emergency Call Type Below Code
*#*#7378423#*#*
Click on Customiztion Settings
Click on Reset Customiztion Settings
Click on
Reset Customiztion Settings and reboot
The Following User Says Thank You to ch wajid For This Useful Post:
Old 08-30-2014, 17:34   #7 (permalink)
syandi's Avatar
Member: 1675927
Sonork: syandi_cell
Thanks Meter: 25
not work for this phone
The Following User Says Thank You to syandi For This Useful Post:
Old 08-30-2014, 17:37   #8 (permalink)
ch wajid's Avatar
Member: 2203737
Sonork: 1656500
Thanks Meter: 462
bro try to flash with setool
Old 08-30-2014, 17:41   #9 (permalink)
Crazy Poster
Member: 2075753
Sonork: 1647349
Thanks Meter: 67
working test bey me
*#*#7378423#*#*
Click on
working test bey me
The Following User Says Thank You to wajid4friends For This Useful Post:
Old 08-30-2014, 17:48   #10 (permalink)
dust2dust's Avatar
Member: 1284799
Sonork: 100.1649097
Thanks Meter: 138
imposible to flash lower version if your bootloader is still Locked, so if you dont know what to do then you can use Sony Update Service without any problem. SEUS is your last option.
Old 08-30-2014, 17:58   #11 (permalink)
dust2dust's Avatar
Member: 1284799
Sonork: 100.1649097
Thanks Meter: 138
Use LT26W only do not attemp with other file youll brick your phone
i guess 6.2.B.1.96 is the last version
The Following 2 Users Say Thank You to dust2dust For This Useful Post:
Old 08-30-2014, 18:35   #12 (permalink)
syandi's Avatar
Member: 1675927
Sonork: syandi_cell
Thanks Meter: 25
please link to download file ftf sir thx
Old 04-20-2018, 11:04   #13 (permalink)
Member: 2203321
Thanks Meter: 46
Worry no more! Do you have Uni-Android Tool?
Go to Sony, Functions and select your option.
Page generated in 0.21935 seconds with 8 queries
