12-12-2018, 05:27 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 775581 Status: Offline Thanks Meter: 186 | J108a Cedar network unlock done. CARD SERIAL 00156659 USBFLASH DRIVER VERSION 03.02.00.00 CFG:000000000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP: LOCKED:1 CID:81 PAF:1 IMEI:01248600689367 CERT:RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 Model (from GDFS): J108a MAPP CXC article: R7EA011 prg1239-0153_APAC_HO MAPP CXC version: R7EA011 Language Package: TELSTRA CDA article: 1241-4310 CDA version: R10A Default article: 1239-0196 Default version: R7EA011 NETWORK LOCKED PROVIDER: 505-01 SECURITY UNITS BACKUP CREATED Elapsed: 8 seconds CFG:000000000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP: LOCKED:1 CID:81 PAF:1 IMEI:01248600689367 CERT:RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 Insert MEMORY CARD into phone Insert TEST SIM CARD into phone POWER ON phone After setup complete, POWER OFF phone Then proceed to Step 2 Elapsed: 9 seconds CFG:000000000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP: LOCKED:1 CID:81 PAF:1 IMEI:01248600689367 CERT:RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 Insert MEMORY CARD into phone Insert TEST SIM CARD into phone POWER ON phone Set "USB MODE" in phone settings to "File transfer" Copy file from CARD folder other\executor.b to : C:\Setool\backup\01248600689367 POWER OFF phone Then proceed to Step 3 Elapsed: 10 seconds CFG:000000000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP: LOCKED:1 CID:81 PAF:1 IMEI:01248600689367 CERT:RED Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM19 PHONE READY TO PROCEED EXECUTOR STARTED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM19 PHONE READY TO PROCEED GOT SEED: 00F7FD02 ACTIVATION COMPLETED. USERCODE RESET TO "0000" DO NOT DISCONNECT PHONE FROM CABLE UNTIL PHONE TURNS ON BY ITSELF Elapsed: 142 seconds |
The Following User Says Thank You to wong edan For This Useful Post: |
