08-12-2013, 16:04 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: kuruman
Member: 646368 Status: Offline Thanks Meter: 113 | Xperia z c6603 cant connect Phone is dead,only showing red light when connect to computer.computer also installed drivers.(not sure if it is the correct drivers installed) USING V1.1299. HERE IS ERROR MESSAGE. RUNNING v 1.1299/01.11/UNI CARD SERIAL 001XXXXX USBFLASH DRIVER VERSION 03.00.00.00 CFG:000000000000 llbug: [\\?\USB#Vid_0fce&Pid_d18b#5&1a08ba1f&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: ... CAN'T LOAD IDENTIFICATION LOADER. Elapsed: 7 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110001000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... llbug: [\\?\USB#Vid_0fce&Pid_d18b#5&1a08ba1f&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: ... CAN'T LOAD IDENTIFICATION LOADER. Elapsed: 3 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110001000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... llbug: [\\?\USB#Vid_05c6&Pid_f006#5&1a08ba1f&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: ... CAN'T LOAD IDENTIFICATION LOADER. Elapsed: 5 secs. HOW TO SOLVE PLEASE ASSIST. |
12-30-2013, 08:46 | #5 (permalink) | ||
Freak Poster Join Date: Nov 2007 Location: Azerbaijan
Member: 622715 Status: Offline Thanks Meter: 82 | Quote:
05-23-2014, 21:52 | #6 (permalink) |
Freak Poster Join Date: Mar 2013 Location: Barcelona, Spain Age: 39
Member: 1894707 Status: Offline Sonork: 100.1658432 Thanks Meter: 51 | only way I could flash it is by removing the battery, but it is still dead.. when I connect without battery in normal mode, it asks for S1 Fastboot Driver |
10-25-2014, 01:31 | #9 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | me too, c6502 after remove battery connector, it flash ok b4 always: llbug: [\\?\USB#VID_05C6&PID_F006#5&1046fd30&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: ... FAILED TO SETUP PHONE after disconnect internal battery: RUNNING S1_BOOT VER "S1_Boot_Lagan_1.1.1_1" ACTIVE_COMP_AID : 0001 HWCONF_AID : 0001 LOADER_AID : 0001 BOOT_AID : 0001 DEVICE ID: 00A7B447 FLASH ID: "0003/00000015" LOADER VERSION: "APQ8064_39" |
10-25-2014, 01:47 | #10 (permalink) |
Member: 60899 Status: Offline Thanks Meter: 792 | but c6502 still not working only red blink 3x pse help RUNNING v 1.1408/01.15/UNI USBFLASH DRIVER VERSION 03.00.00.00 SIGNED MODE (USING SERVER) CFG:100000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... llbug: [\\?\USB#VID_05C6&PID_F006#5&1046fd30&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: ... FAILED TO SETUP PHONE Elapsed: 5 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... llbug: [\\?\USB#VID_05C6&PID_F006#5&1046fd30&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: ... FAILED TO SETUP PHONE Elapsed: 5 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "S1_Boot_Lagan_1.1.1_1" ACTIVE_COMP_AID : 0001 HWCONF_AID : 0001 LOADER_AID : 0001 BOOT_AID : 0001 DEVICE ID: 00A7B447 FLASH ID: "0003/00000015" LOADER VERSION: "APQ8064_39" PHONE IMEI : 35538705095263 writing "C:\gsm\Lazer\c6502\10_5_1_A_0_283.APP_SW_Odin_GEN ERIC_1266_7597_S1_SW_LIVE_5CA3_PID1_0002_MMC.SIN_F ILE_SET" Processing package C:\gsm\Lazer\c6502\10_5_1_A_0_283.APP_SW_Odin_GENE RIC_1266_7597_S1_SW_LIVE_5CA3_PID1_0002_MMC.SIN_FI LE_SET BOOT UPDATE NOT REQUIRED Processing ACPU files PROCESSING: cache_S1-SW-LIVE-5CA3-PID1-0002-MMC.sin PROCESSING: apps_log_S1-SW-LIVE-5CA3-PID1-0002-MMC.sin PROCESSING: kernel_S1-SW-LIVE-5CA3-PID1-0002-MMC.sin PROCESSING: fotakernel_S1-SW-LIVE-5CA3-PID1-0002-MMC.sin SKIP: partition-image_S1-SW-LIVE-5CA3-PID1-0002-MBR.sin PROCESSING: rpm_S1-RPMFW-LIVE-5CA3-PID1-0002-MMC.sin no update files in package writing "C:\gsm\Lazer\c6502\10_5_1_A_0_283.ELABEL_Odin_ela bel_c6502_row.201303251525.SIN_FILE_SET" Processing package C:\gsm\Lazer\c6502\10_5_1_A_0_283.ELABEL_Odin_elab el_c6502_row.201303251525.SIN_FILE_SET Processing ACPU files PROCESSING: elabel-c6502-row_201303251525_10.5.1.A.0.283_S1-CUST-LIVE-5CA3-PID1-0001-MMC.sin no update files in package writing "C:\gsm\Lazer\c6502\10_5_1_A_0_283.FSP_Odin_GLOBAL _HSPA_1275_0938_S1_SW_LIVE_5CA3_PID1_0002_MMC.R3D. SIN_FILE_SET" Processing package C:\gsm\Lazer\c6502\10_5_1_A_0_283.FSP_Odin_GLOBAL_ HSPA_1275_0938_S1_SW_LIVE_5CA3_PID1_0002_MMC.R3D.S IN_FILE_SET Processing ACPU files PROCESSING: userdata_S1-SW-LIVE-5CA3-PID1-0002-MMC.sin PROCESSING: system_S1-SW-LIVE-5CA3-PID1-0002-MMC.sin PROCESSING: amss_fs_1_S1-MODEMSW-LIVE-5CA3-PID1-0002-MMC.sin PROCESSING: amss_fs_2_S1-MODEMSW-LIVE-5CA3-PID1-0002-MMC.sin PROCESSING: amss_fs_3_S1-MODEMSW-LIVE-5CA3-PID1-0002-MMC.sin Processing update files PROCESSING: cust-reset.ta Writing TA unit 0002/08A4/000E SKIP: simlock.ta Elapsed: 282 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... llbug: [\\?\USB#VID_05C6&PID_F006#5&1046fd30&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: ... CAN'T LOAD IDENTIFICATION LOADER. Elapsed: 7 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "S1_Boot_Lagan_1.1.1_1" ACTIVE_COMP_AID : 0001 HWCONF_AID : 0001 LOADER_AID : 0001 BOOT_AID : 0001 DEVICE ID: 00A7B447 FLASH ID: "0003/00000015" LOADER VERSION: "APQ8064_39" PHONE IMEI : 35538705095263 MODEL (from GDFS): C6503 SOFTWARE VERSION: 1266-7597_10.5.A.0.230 CUSTOM VERSION: 1270-5681_R1D FILESYSTEM VERSION: BRAZIL-LTE_10.5.A.0.230 SERIAL NO: EP731522BY Elapsed: 9 secs. |
03-17-2016, 17:59 | #14 (permalink) |
No Life Poster Join Date: Jun 2005 Location: India ( Punjab ) / China Age: 38
Member: 154749 Status: Offline Sonork: 100.92483 Thanks Meter: 1,048 | i am sorry for interrupt in so old thread , but for C6603 you need to remove battery then flash it and better use latest version of files , and these phones done flash without battery , so when you gonna power up make sure its detect the charge if setool show flash ok done because with me one unit same issue , battery was damn down and took some minutes to just show charge so this post for future people also , make charge before you do anything after flash make proper charge , if setool shows flash ok mean ok Regards |
