10-05-2016, 11:10 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: india Age: 36
Member: 690456 Status: Offline Sonork: 1587650 Thanks Meter: 117 | Sony z5 anti theef lock protaction |
10-05-2016, 12:14 | #3 (permalink) |
Freak Poster Join Date: Nov 2015 Location: Pakistan/UAE/WorldWide Age: 29
Member: 2488504 Status: Offline Sonork: 100.1663349 Thanks Meter: 210 | Remove protected screen sony MXTP new lock Sony The time ranges from 25 to 15 seconds, depending on the model. The xperia M4 is what it is as long (easier) then you must be fast in every procedure and when the time runs out the lock screen and then shown it takes restart to continue or repeat step not finished. 1. Format the first device 2- set the language for the access to add guest mode on the screen it is normal the screen is black and not display the language options then restart up to show the initial settings options. complete the settings (language settings etc ..) should complete until the end that opens the menu the end time will show the protective screen to restart unit to continue, or go to the next step. 3- In the protected screen enable one wifi network, after already one authenticates Wi-Fi network does not restart the machine and knife Step 3 4- Enable guest mode. click on 2x power at the blue screen puche you notify and click on the doll (top right) the end time will show the protective screen device restart and continue! 5- Add new account to PlayStory the end time will show the protective screen device restart and continue! 6- Make a shortcut menu settings to the first screen, so already point the end time will show the protective screen device restart and continue! 7- Attention latter step can only be done once. If the time runs out to repeat. reset the machine go into menu and reset the device starts again from step 1 Please settings and click on safety and open the proteção_my_experia, click Enable, and then click Disable protection. 8 in this step the device already has no lock but the bill is still in the device. 9- knife login with the new account, enable and disable, then knife a total device reset the menu settings, backup and reset |
The Following User Says Thank You to motorola. For This Useful Post: |
