10-10-2011, 12:15 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: south africa Age: 34
Member: 573407 Status: Offline Thanks Meter: 15 | sonyericsson W580i not switching on after unlock CARD SERIAL 000 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:01157200602761 ACTIVE CID:49 COLOR:BROWN no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 5 secs. |
10-11-2011, 06:37 | #3 (permalink) |
Product Manager Join Date: Sep 2009 Location: Pakistan Age: 36
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | Try to Full Flash this set first if not solved then try 2 use reset method to solved ur problem 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after successful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. & Post result.. |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
